daphatgrant
Fi-yah!
- Jun 15, 2003
Let me start by describing what my current "file server" is, I have a 1.4ghz T-bird, w/ 512mb ram, a 320gb hdd, and a 100/1000 net card that's connected to my router that I pull and store files on.
I have been meaning to replace this for quite some time and with the cheap price of 1tb hdds I figured why not do/start it now.
So... here are my questions:
1. do you recommend that I raid them in pairs? so it's drive A w/ backup, B w/ backup, etc
2. Or do you recommend that I raid and stripe them? so it's drives A-D striped using drives E-H as mirrors.
3. Do you recommend any specific RAID cards?
4. Is using 8 drives going to make this too complicated?, I am going to need at least 6 drives (need a min of 3TB's storage)
*The board that I am going to use has 2 different sets of SATA (150) ports that can be raided (2 different RAID controllers for a total of 4 drives between the 2 controllers). Since it is SATA I (150) I'd rather go with the newer SATA II (300).
I won't be accessing this frequently but on a 1-2 times a week basis. There is a good chance that I will install a wireless card so that I don't have to run cat5 to it.
I apologize if this is scattered but I have never looked into doing this before and at 8 drives I am not starting out easy.
Here is what I currently have:
Antec 900 case
*Abit IC7-G w/ 10/100/1000 built in lan
PV 2.8C
1GB PC3200
500GB hdd (OS)
DVD-ROM
Antec 900 case
PV 2.8C
1GB PC3200
500GB hdd (OS)
DVD-ROM
What I am going to start ordering:
(8) 1TB HDD's 4 for storage, 4 for backups
Corsair 1000HX PSU
1 or 2 raid cards
Corsair 1000HX PSU
1 or 2 raid cards
