- Aug 17, 2001
Is anyone else having issues getting new WUs?
I first noticed that my GPUs had stopped folding and am getting errors, and no my CPU has stopped and is getting the same errors when trying to get new work.
Code:
13:54:29:WARNING:WU00:FS02:Failed to get ID from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: No connection could be made because the target machine actively refused it.
13:54:34:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: No connection could be made because the target machine actively refused it.
13:54:34:WARNING:WU02:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: No connection could be made because the target machine actively refused it.
13:54:50:WARNING:WU00:FS02:Failed to get ID from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: No connection could be made because the target machine actively refused it.
13:54:50:ERROR:WU00:FS02:Exception: Could not get an assignment ID
13:54:55:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: No connection could be made because the target machine actively refused it.
13:54:55:ERROR:WU01:FS00:Exception: Could not get an assignment ID
13:54:55:WARNING:WU02:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: No connection could be made because the target machine actively refused it.
13:54:55:ERROR:WU02:FS01:Exception: Could not get an assignment ID
