Server Rebuild
darknite
So it's time to do some updates. The last few i've got some help for are running beautifully, so i'm here again.
Home File Server - Streaming between multiple devices, ps3, xbox, ipad, etc.
avi, mp4, mkv (anime)
Staying Under $400 before shipping
USA Kentucky
CPU, RAM, MOBO
Corsair TX750w PSU, All Hard Drives, 4 port SATA raid controller
6) Will you be overclocking?
No
No monitor - will install OS then remote in
within next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
RAID, SATA 6, Quiet-cool-stable (stays on 24/7)
WHS, but thinking about moving to a different OS
I currently have an ASUS A8N-E, 3GB RAM, AMD Athlon 64 3500 @ 2.2ghz, ATI Radeon 2600 Pro.
THe primary function of this PC is my lil home file server. I got it kinda jerry rigged because 2 fans have died, and some other things. So i'm trying to
upgrade to some more stability for the wife if i am gone. I remote in to keep it updated, move files, download, etc. So video isn't a huge deal.
I would like to stick with ASUS and Intel. They haven't let me down yet.
After a little bit of looking here is what i've got
[anchorlink=http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837]$145 [/anchorlink]ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
[anchorlink=http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078]$119[/anchorlink]Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32100
[anchorlink=http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314]$56[/anchorlink]G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
or
[anchorlink=http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568]$95[/anchorlink]G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM
[anchorlink=http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065]$31[/anchorlink]COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible with Intel 1366/1155/775 and AMD FM1/FM2/AM3+
$351 or $390 depending on RAM.
That motherboard is pretty much overkill for your needs. You should be fine with this mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131826
As for the CPU, I'd recommend the Core i3 3220 since it's slightly faster and uses slightly less power:
$124 - Intel Core i3-3220 CPU
RAM wise, that 8GB set is overpriced. You should not pay more than $50 for 8GB of RAM. That 16GB set is overkill. You should be fine with 4GB of RAM actually unless you're planning on running Virtual Machines or switching to ZFS.
What interface does that 4 port RAID controller use?
Since you aren't overclocking you really don't need to spend money on the Hyper 212+. Just use the stock HSF.
Seems i messed up my links. I like the hyper 212 cuz its quiet and i've used about 4 of them. But we will see.
I can agree with the board cpu change. I'd rather have a faster cpu and pretty basic board.
I'll look into the RAM a bit more
The sata card is PCI Express. Right now I have 2 drives connected to it.
