I'm a college student (now a senior) and being an IT major, I decided to create a server just for the experience and knowledge. It's running off an old Dell Dimension 8200 (P4 2.6, 768mb RD-RAM). I have it loaded with CS:S, Ventrilo, and FTP all running on Server2k3.
Since then (about 2 years ago), we have built a home theater system, and run an HTPC. Currently, we have 1TB of data and we're due for new drives. Instead of scattering the hard drives throughout three desktop machines, I figured now's the perfect time to upgrade the server and actually make use of it. I already have the CPU and the Case. The specs are below:
Lian-Li PC-65 (can fit 9HDD
Pentium Dual Core 1.6Ghz (Allendale I think)
2GB DDR2 800
XCILO 500W PSU
ASUS P5Q SE
Sapphire HD3450
Here are my goals:
1. Continue to run CS:S Server, Ventrilo and FTP. All of which are private and are only hitting a max of 5 people. FTP is RARELY used.
2. Store all my media files on here and stream over the network to the HTPC. I do not care about RAID
3. Want to setup automatic backups of our main desktop PCs on the network. This would include the HTPC OS drive, and two data drives on the gaming machines. I figured I'd use Acronis for this?
Now that brings me to my main question...what OS should I use? I have a legit copy of Server2k3, which is what I'm using now. However, I think it may be overboard for my needs, especially since products such as AVG will not work on it, do to it's server platform. This leaves me at a loss for things like anti-virus software.
I can either use Server2k3, XP Pro 32bit (both of which I have) or purchase WHS. What do you see as the best option? If it's WHS...whats better to backup the NETWORKED PCs? ACronis? Or WHS backup?
Finally, the specs above should be plenty for what I need, correct? I'm slightly worried that the CPU won't be enough, but once I upgrade my PC, I'll throw the E6600 in the server, if necessary.
Thanks!
2GB DDR2 800
XCILO 500W PSU
ASUS P5Q SE
Sapphire HD3450
Here are my goals:
Thanks!
