jazzman161
- Dec 6, 2004
Hey all. Need some help building a little server for my home. Any help would be greatly appreciated. First off, the questions:
3) Where do you live?
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
6) Will you be overclocking?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
10) Do you already have a legit and reusable/transferable OS key/license?
1) Server. Serving media files (tv shows, dvds, music)
2) I know the drives will add up but I'm trying to keep it around $500 not including any HDDs.
3) South Florida
4) CPU, RAM, PSU, Controller Card, SATA Hot Swap Rack, Mobo
5) I've got a LIAN LI Lancool PC-K10B sitting around I'd like to throw everything into. I've also got an external DVD drive for installing my OS if need be.
6) Nope
7) N/A
8) I'd like to build it within this month.
9) I'm thinking RAID (possibly) and thats about it.
10) Considering WHS
I'm thinking I could throw in 10 drives max into my Lian Li Case. (5 internals plus convert the 3 5.25" to 5 3.5" with the hot swap rack). Looking at 1.5TB or 2TB drives as they go on sale. Originally I was considering RAID but I'm thinking maybe just get an extra SATA card and back up 5 of the drives to the toher 5 using built-in back-up or Acronis True Image. This would accomplish the same as RAID1 and save me the cost of an expensive RAID-enabled sata controller card no? My biggest concern is how do I power all these drives? Select a PSU that has enough connectors?
So I'm thinking the following hardware:
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103255
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128342
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820134488
Hot Swap: http://www.newegg.com/Product/Product.aspx?Item=N82E16816133030
Lastly, I've got about 500 actual DVDs that I'd like to copy (exact image. no need to compress or anything). Any ideas on how to do this quickly? I'm thinking it'll take me months to do all 500. Thanks!
3) South Florida
6) Nope
7) N/A
10) Considering WHS
