That's not what they are talking in the article you've linked - it's a different problem with C7 about the backplate interfering with motherboard components. I didn't have such a problem with my board but different boards might. It still doesn't solve the problem of screw length going way above 6.35 when screwed enough to apply proper tension.
Corruptedfile - there is a slot for second hard drive if you're using standard SFX power supply but it has same height as the first one. Also you won't fit it vertically since the case has 64mm of space there, however if you don't have too much cables you might fit it angled somehow down there but it's not an elegant solution. If you have blower or short gpu you could try mounting it like i did with my hard drive below the gpu upfront - unless your gpu blower fan is really thick out there you might fit the drive with rad while not blocking the blower inlet too much.
ODD slots are ugly and complicates the design... There exist like a million cases for ODD lovers already
Yup, they are a waste of space. Getting the case as close to 7L as possible while accommodating a full size GPU should be the #1 priority.
There are thousands of cases with ODD out there. Don't let one compromise the design of this case.
I for one couldn't care about having an optical drive in this thing...
I'm just hoping that the high-end Pascal cards (which hopefully are going to coincide with the release of this case) are actually going to be as small as Nvidia is showing - I would really love to have a "GTX 1080" and have room for a couple extra 2.5" hard drives.
I hope you know that the cards that we will get shouldn't be much more powerful than a 980 TI... at least the ones launching this year.
Of course I do. Nvidia is going to follow their typical release scheme - at least unless they believe they have something that could completely dominate the market to make up for Radeon cards getting HBM first.
They'll start by releasing the 1080, possibly coinciding with the 1080ti. Then they'll release the 1070. That card should be about 20% faster than a GTX 980ti. Yes, that's an optimistic prediction, but not entirely unreasonable considering how much of a performance upgrade the Fury got with HBM1.0.
That being said... none of that matters to me. I'm upgrading from a GTX 670 with a 1440p screen; the massive increase in VRAM alone will allow me to turn shadows back to ultra.
Here's why anybody looking forward to this amazing case should be eagerly awaiting Pascal nonetheless:
1) Heat Production. Pascal, based off of the 100% infallible, always-accurate Nvidia press release, is going to have double the performance per watt of Maxwell. Now, AMD managed that statistic when they moved to HBM, but they also had a pretty low bar to start with. Nonetheless, it's pretty much a given that the 250w cards of today will run even more efficiently. Sure, a lot of that performance-per-watt will be used as free performance to achieve that 20% performance increase... but imagine if a mid-high end card was 100W. That's about 60% of where a GTX 970 is right now - completely achievable. That brings with it even more benefits, such as:
2) Size. This one pretty much argues itself. We've seen Pascal at GTC 2014, and the PCB was perhaps 40% smaller than the standard "short" graphics cards of today. Now, there's been plenty of time in between that conference and now for Nvidia to royally screw the pooch, but unless they arbitrarily increase the size of the PCB, HBM allows for a significantly smaller card than was previously necessary. Combine that with the heat efficiency gained from a die shrink and from HBM, and there's zero reason the cooler needs to be larger than the card... not only that, but it gives manufacturers much more flexibility with their layouts - we could feasibly see a single-slot, mid-high card from a manufacturer. Galaxy and PowerColor have both made single-slot cards with a TDP over 100W; granted, not in the US market, but the technology is there nonetheless. (And several companies have made 970 Minis, with a 160w TDP, double-slot.) For those of us interested in SFF who can afford a double-slot cooler, we get a much larger heatsink, meaning fans can run far slower, resulting is far lower...
3) Noise. Lower heat means the fans don't have to run as quickly, which means far less noise... that's a very good thing when you're a SFF enthusiast and are looking to buy a case like this one, which is about as open as it can get. Noise-blocking is practically zip (Saper, I'd really be interested in a benchmark comparing noise with the panels on and off - or even any sort of subjective observations.), which means the noise our graphics cards produce is going to matter, a lot. You might say that any benefit from reduced heat will be negated by reduced size, requiring smaller, whiny-er fans, but that's not true. Why? Because the width of a PCI slot is standardized. I'm sure some companies will take advantage of Pascal's size and make low-profile cards, but for the rest of us, the size of the fans won't reduce at all. Just look at Asus's 970 mini. It has issues fitting into this case because it's slightly taller than standard. It's absolutely no leap of imagination to go from that to a 1080 mini that's taller than the PCB, but within "standard" height as it is now.
So really, we should all be looking forward to Pascal like nothing else. If you care at all about small form factor computers (And if not, why are you in this thread?), Pascal represents a huge leap in technology. In this particular case, it very well might allow a high-end graphics card and two extra storage drives that would previously have been mutually exclusive. In future cases, it allows the designer to cut another ~2-ish liters for free.
What does Pascal ultimately represent? Progression. As the technology improves, and Nvidia picks up Hybrid Memory Cube for Volta, it wouldn't surprise me to see their cards shrink again. It's a natural trend in technology; we now have supercomputers in our pockets, and the entire SFF community represents a trend towards small, efficient power. Anything that carries us further along our path can be nothing but a benefit.
Hey guys! I think they are in the process of ordering the 2nd prototype (black coated) from the manufacturer to verify the quality for repetitive orders so hang in there! I am also very interested in purchasing a couple of cases but lets not be so hasty as this process may take a week or two. Lets just hope everything goes well.When is the Sentry being released, and where can be purchased? I have 2 people that I will be buying cases for.
Cheers!
Sentry with GTX970 in horizontal position
Idle - 45.0 dB
Heaven - 47.5 dB (2.5dB increase over ambient SPL)
Photoview - 50.5 dB (5.5 dB)
OCCT - 48.5 dB (3.5 dB)
Sentry with GTX970 in vertical position
Idle - 45.5 dB (0.5 dB)
Heaven - 47.5 dB (2.5 dB)
OCCT - 46.5 dB (1.5 dB)
Sentry with R9-270X in horizontal position
Idle - 45.5 dB (0.5dB)
Heaven - 50.5 dB (5.5 dB)
Sentry with R9-270X in vertical position
Heaven - 46.5 dB (1.5 dB)
OCCT - 47.5 dB (2.5 dB)
Little update:
After some minor tweaks that enlarged the holes in the central wall for better cable management it occurs that now you should be able to fit 120mm cooler inside but there's some limits:
- Radiator + Fan thickness combined has to be 48mm max, so it looks like 32mm radiator + low profile 16mm thick fan.
- ITX sized gpu, max 175mm but if pcb is oversized then you'll need modded low profile PEG connector
- SFX 100mm long psu only
- power button removed from the front and plugged by something like black 16mm round plug
- some additional cable mess to manage by yourself
- either really tight bend of water cooling pipes or secondary hard drive slot in front of PSU obstructed
Also I'm not sure about the airflow for this AIO but it might be a positive thing for the gpu since it'll make the air move at the back of gpu. You'll have to see if that warm air from cpu cooling will make it better or worse for gpu.
Apologies for asking, however I was wanting to know you are planning to retain the "gloosy grainy" look in regards to the coating as seen here:
(I had noticed you mentioned requesting a sample of an even more grainy coating on the previous page)
Or you were/have tried a more 'desk friendly' flat matte look, perhaps something akin to this:
Don't be afraid to ask - we don't bite
Actually we're going even more into the grainy surface in the final product:
The one on the right is what you've seen for the black prototype and the left is what we've got picked for the production. Comes both in black and white of course.
It's a close-up photo and it isn't so much noticeable by naked eye but has nice feel in touch and is better for hiding small scratches, fingerprints etc.
I'm not sure what you mean as 'desk friendly' since the case stands on the rubber feet in both positions and the paint itself shouldn't scratch your desk.
If I provide the funds as a donation, for you to order in another case sample from the manufacturer in a plain non-grainy matte black so we can compare it with what you have now, would it be at all difficult?
However, with everything considered I'm only a single customer meaning my opinion doesn't hold much weight, and ultimately it is up to you both as the creators, as to what you want your product to look like.
While waiting for those we've got to figure out packaging.
Does that mean that some of these early units will soon be offered for sale?We have ordered first production batch of 25 units. Some of them will be sent as review samples. While waiting for those we've got to figure out packaging.
That depends how we are going to play this out. The thing is, while I could spend the money on 25 sets of metal parts its a whole different thing with all other pieces of the puzzle which are priced for orders of at least 100 pieces. It wouldn't be a problem if not for the risers and USB 3.0 cables which are quite a big part of the cost and paying upfront out of my pocket for 100 sets of them doesn't work out for my wallet :|
While I would want to give you those 20-24 "early bird" units straight from the shelf when packaged and ready it would also mean you'd have to either pay full unit price for those cables/risers if you'd want me to order 20 of them or wait a bit until we gather at least 100 orders or until we get some more spare funds to order those cables for stock.
(The submit button is presently blocked, however the 'early bird' options will disappear from the form once 20 people have submitted pre-orders for them.)
