londonandlawson
- Aug 25, 2006
I did the "mod" on mine where you remove the foam piece from behind the speaker but I don't know if there is a real difference, what do you think? And what effect would happen if I was to cover the whole grill with foam instead of the one small piece that comes with them out of the factory?
