Senheiser PC350 | Powering Problem?
trenth
Hi everybody,
I'm looking to get these headphones.
Sennheiser PC350
http://www.newegg.com/Product/Product.aspx?Item=N82E16826106219&Tpk=sennheiser pc350
And right before I went to buy them I did a bit more checking and it turns out that there is some powering problems with them. If you don't have enough power to them, they'll sound like trash.
I was also thinking of purchasing this soundcard, as i'm sure onboard sounds like crap. :p(for me anyways)
Omega HT Striker 7.1
http://www.newegg.com/Product/Product.aspx?Item=N82E16829271001&Tpk=ht omega striker
But i'm not sure, if the soundcard will put out enough Ohm's to power the headphones the way there suppose to be powered. (All the way powered that way they sound the way they were suppose to)
Do you think it will power them?
If not, will the Omega HT Claro Halo work as it has the "Hi-Fi" headphone thing.
http://www.newegg.com/Product/Produ...cm_re=omega_claro_halo-_-29-271-004-_-Product
I'm not very good with audio things, so please try to explain "noobingly".
Regards,
TrentH
PS:
Thank you all for the help.
