Semi-budget home server build :D
This is just a small, semi-budgeted home file server/nas build.
Main objective/usage for this server is to serve movies (including hd-dvd), music, pictures to all my client PCs over a gigabit network. I first installed Windows Server 2003 standard as the OS, but have no moved onto unRaid, which provides a backup for a single disk failure.
» The Hardware
LIAN LI PC-A16B (Good pictures and review here)
This case is comprised of 9 5.25" bays, which can house 9 internal HDDs using their 3in3 drive cage. Extra drive cages can be purchased separately if needed. Each of these cages has a fan in the front to draw in air over the hard drives.
But buying those would be a waste, as the reason for buying this case was it's ease of installation, its good looks, and of course, fitting it w/ hot-swap bays ;)​
Asus P5B-VM DO
This board was chosen because of 7 sata2 ports as well as an eSata port on the back, onboard video, gigabit lan. This board is also capable of RAID 0/1/0+1/5 on 6 of its 7 available sata ports, but won't be used by me. This is a full featured board in a small mATX package (which is another plus, takes up less space ;)).
Extra SATA controller cards can be bought if you run out of the 7 onboard sata ports.​
SeaSonic M12 500W
I've used SeaSonic in the past, and I continue to use them. They're dependable, quiet, and highly efficient. You don't really need a modular PSU, especially for a server build, but I like the clean look it offers.
Also, 500W should be more than enough, even if running 9-15 drives, as there is no gfx card, sound card, etc to be powered, and the cpu+hdd's will not be at 100% usage to draw that much wattage anyway.​
Athena Power Sata Back Plane
I came across many sata backplanes, but this was the cheapest of them all. Majority of them looked to be the same cage with a different face plate. The case has room for 3 of these cages, but I only bought 2 for now for my build.
Some of the other backplanes included AMS, SuperMicro, and ICY Dock. A Google Search lists many of the other brands available.​
Promise SATA300 TX4
A 4 port PCI sata2 controller card. It's cheap and adds more sata2 ports. Yes, it's PCI 2.2 based, but for a home server, it's more than enough bandwidth. If running any kind of software raid, PCI will slow it down b/c of its bandwidth limitations (due to it writing/reading parity information from all drives), so in that case you might want to consider a PCIe based controller card.​
Intel Core 2 Duo E4300
The cheapest Core 2 Duo processor I could find. :) Got it for about $100, and I believe the E4300's are being discontinued now.​
G.Skill 2GB DDR2 800
Compatible 2GB of RAM at a good price.​
Samsung Spinpoint 500GB
I've never used Samsung HDD's before, but these were hard to pass up for $100. They have good reviews and run cool and quiet.​
D-Link DGS-2208 Switch
I've had a D-Link DGL-4300 router for the past 2 years and it's been running flawlessly, so I decided to stick with D-Link for my gigabit switch. Good reviews and good price.​
There will not be a CD/DVD drive installed in this build, so I'm just going to grab a drive from one of my other PC's for the initial OS install. Other than that, just Artic Silver 5, some sata cables (10", 18"), and Cat6 network cables were purchased.
Here is the Newegg Wish List with most of the parts listed. Not all parts were purchased from newegg, Monoprice, Directron, and some other vendors were used. Pricegrabber comes in handy!
» Windows Server 2003 Standard - Installation
There's nothing much new about Windows install, I'm sure anyone building a server has installed a Windows OS before, its really straight forward.
When using hotswap and Intel's chipset sata ports, AHCI needs to be enabled on your motherboard. Also, drivers need to be installed using the F6 method before installing the OS (there is a workaround if you've already installed your OS and want to enabled AHCI). I slipstreamed Intel's Matrix Storage Manager and Promise SATA300 TX4 drivers into my OS Installation CD using nLite so I wouldn't have to deal with the F6 method, as I didn't have a floppy drive laying around.
For the OS install, I partitioned 30GB for the OS, and the rest for data. After installation, the latest chipset and lan drivers were gotten from their respective sites (both intel) and installed (which can also be integrated using nLite).
The drives were then formatted and shared so they would be available over the network.
» unRaid OS - Installation
I've never worked with Linux before, but this installation could not have gone any smoother. Basic instructions for creating a bootable usb flash drive and motherboard BIOS settings can be found here.
Before booting up the OS, take a sheet of paper and write down each serial number on the back of the HDDs and its location of where its going inside your case, it will help later when you're assigning the parity drive and disk drives, so they will show up logically according to its physical position of the drives in your case.
For example, in my situation, my parity drive is the first slot in the lower hot-swap bay, followed by disk1, disk2, disk3, disk4. Disk5 is the first drive in the top hot-swap bay, followed by disk6, disk7, and disk8. If I didn't know the serial numbers for the hard drives, I wouldn't have been able to assign them in that logical order.
You can now boot into unraid, and once its booted up, you can go to the web configuration through any of your client PCs web browser (http://tower is default which you can change). Now comes the part where you assign your parity drive and disk drives.
In my situation, I had a lot of data in my existing drives and I did not want to format my drives before I transferred all the data over to the unraid array. To do this, you need atleast 1 empty drive. I did NOT assign a parity drive at this time, instead i assigned and formatted the empty disk i had (disk1) and left the party drive as unassigned. At this time, you have a couple of options as to how you want to transfer your data from your NTFS drives over to your newly formatted unraid drive.
1. You could take the drive out, put it in a windows machine, and transfer all the files through the network share for disk1 that we just assigned to the array.
This is very tedious and I already had the drives installed in my hot-swap bays. This was not an option for me​
2. You mount your NTFS drives in linux and transfer all the files over.
Here we go, this is what I was looking for, and here are the steps to do exactly that (a sample wiki for this as well):
First, DO NOT assign the disk drives to the unraid array, instead write down their disk assignment slots. Remember the step above where we wrote down the serial numbers for each HDD, each of those serials will have a disk assignment slot in the drop down box of the disks page in the web config. For example, (sda, sdb, sdc, etc), write those down next to the serial numbers you wrote before.
Next, you need to telnet into your unraid box. Start -> Run and type in "telnet tower". This will bring up the telnet console and ask you for username, which is "root" by default. If you've assigned a password thru the web config, it will prompt you for that as well. In Vista, telnet is not loaded by default, you need to go to control panel and enable telnet client for vista.
Now, since the latest unraid doesn't load the NTFS kernel by default, you need to temporarily enable it by using the following command in the telnet console:
Code:
modprobe ntfs
It's time to mount one of the NTFS drives you have w/ the data you want to migrate by issuing the following commands (note: the array needs to be started for this to work with only disk1 assigned and we're assuming the NTFS disk we want to copy data from is labled as sdb)
Code:
mkdir /mnt/old_data
mount -r -t ntfs /dev/sdb1 /mnt/old_data
The first line simple creates a new folder, which you will mount your ntfs drive to, you don't have to name it old_data.
In the 2nd line, the -r flag mounts the drive as Read Only.
-t flag defines the type of the drive, in this case, ntfs
/dev/sdb1 says to mount the first partition of the drive, if you had multiple partitions you would need to come back to this step after you copied the files over from this partition. The basic format would be /dev/sdbx where x is the partition of the disk.
/mnt/old_data specifies where you want to mount the ntfs drive, which was the folder we just created
To copy the files, use the following commands:
Code:
cd /mnt/old_data
cp -r * /mnt/disk1
The first line changes directories to /mnt/old_data. You can view the contents of your mounted ntfs drive now by typing dir.
-r flag says to copy all files/folder recursively
* denotes everything in the old_data directory is to be copied
/mnt/disk1 is the destination of where to copy
Now, depending on how much data you have, this might take a while to copy, let it finish, after its done, you will again have access to the console prompt, type:
Code:
cd
umount /dev/sdb1
first line goes back to root level
umount (yes umount not uNmount) unmounts the mounted ntfs drive. You can now go to disk1 and check its contents.
One little quirk I had was that it marked all the files/folders I copied over as read only, to change this i had to chmod all folders/files in the directory, to do this type:
Code:
cd /mnt/disk1
chmod 755 *
This will change the read/write/execute attributes of all files/folders in the directory.
Now you can go back to your web config, stop the array, assign the NTFS disk you just copied your data off of, format it, and it will be added to the array.
You continue these steps for as many NTFS drives as you have data on that you need to transfer, copying one at a time. After all of it is done, you can then assign your parity drive and build the parity information. Remember the parity drive has to be the largest (or same size as the largest) drive in your array.
Another little quirk I ran into is that for user shares to work properly, top level folders need to be at a minimum...so instead of having all dvd folders as top level, i created a top level folder called DVDs moved all my dvds one level down, into that folder.
That was about it, pretty easy to setup and now i have the peace of mind that if one drive fails, i would not have to re-rip all my movies and not lose any data.
» Pictures
The build was pretty simple, and the case is simple amazing to work with and offers more than enough space. The Athena Power backplanes are also built very nicely, the hard drives slide into place w/o any effort.
All in all, this was a fun project w/o any hitches or bumps (touch wood) and hopefully will help someone along the way to their own server build or give then ideas.
Thanks
Not bad.
For my "budget" build I took a beat up old eatx case and stuck in 5 * "3 in 2" sata hot swap enclosures. I built it based on an asus am2 board that has a proprietary slot that gives you remote console over ethernet if you spend $60 on an add in card.
The board has 2 gig-e nics on pci-e bus and I ended up buying some lsi controllers on sale that are pci-x (it has 2 pci-x slots).
a be-2350 finishes it off (super low power cpu) as well as a left over antec 500W power supply.
Motherboard: $220
Controllers: $560 (16 sata ports)
hot swap enclosures; $250'ish
OS: FreeBSD :D
Case: Free (leftover from previous project)
Power supply: Free (leftover from previous project)
CPU+ Heatsink: $99
Drives: pulled from other non-used boxes, and added as budget allows
3 * 200G (OS, /data/nfs): nfs serving for unix boxes
5 * 400G (/data/samba): samba serving for winboxes
2 * 750G (/data/backups): rsnapshot backup drives
2 * 500G (/data/iscsi): iscsi images for windows & unix boxes (eg: remote mirroring)
That is a really nice setup, tons of room. I am going to be building a server soon with probably only about 1.5 TB of room. I will most likely be using Windows Home Server, it seems like it is a pretty straightforward OS, at least for my needs. I also agree with using nLite, it is amazing. I needed to use it to slipstream SP2 into my XP pro install, because I got so tired of installing SP2 over and over again.
yeh those drive cages really saves a lot of space, especially since only 2 sata power connectors are needed to power all 5 drives, less wiring :)
That saves some serious wiring! I did not even know that they made cages that only needed two power connectors!?
Thats pretty slick, looks very functional!
How loud are those Athena power enclosure things? And are the fans interchangeable?
Also, I noticed on the eggs website there are 3 molex and 2 sata power connectors on the back, do you actually need to use all?
I am really interested in this product.
Noise is relative. The fan on the back has a high and low mode. Most people have indicated that the high mode is louder then most fans in your average system. On low most say the fan is not any louder then other fans. You always have the option of modding the back plane and putting in a larger, quieter fan.
I have one of these branded by I-Star instead of Athena. They're fairly quiet.
No, even plugging one of them in is sufficient if your power supply is up to the task.
I like the Supermicro ones better. About the same price, an inch or so deeper, and a good deal louder, but the trays are nicer IMO and lock securely into place. I almost broke the I-Star enclosure trying to push one of the trays into it - the top half of it just bent up a half inch without much pressure at all.
They're still fine enclosures, but I prefer the Supermicro ones. YMMV.
I don't find them very loud, and I have them set at High fan speed. There's a small black switch to select the speed you want. The fans in the back are not interchangeable, it would have been a nice option to allow you to put your own 80mm fan.
As for the power connectors, it's recommended to either use 2 sata power connectors, 2 molex power connectors, or 1 sata and 1 molex power connector to power the 5 drives.
unhappy_mage,
yeh, drive cages are a plenty, just depends on how much you wanna spend. I haven't had a problem w/ mine and find them to be pretty sturdy, although I've never really had to push hard to get a drive into place, it slides in pretty effortlessly, u just have to line up the rails.
For those of you that may want/need a quieter solution, the LIAN LI PC-61 is significantly quieter than the A16. With "close" to the same capacity. I have to admit, when I put three of those Sata back planes in mine in was a lot quiter. But even then, it was twice as loud. (with the same hardware.)
But without a doubt, the A16 looks cooler. :p
Vey well thought out build. For serving movies I would definately consider RAID it will be faster for your clients and give you redundacy.
Other than that nice work.
You need a power plant in your room just to power the damn thing
i have now moved my OS to unRaid, original thread has been updated w/ info on how that went :)
Thank you!
I'm planning to build a similar setup in a few months and this will definitely help!
unRaid looks interstesting but 16 drive limit and the license fees are kinda limiting.
I'll have to play with it in vmware for a bit, for now I'll stick with freenas
me and another bud bought the 2-key version and split the cost, so it came to about $75/each.
yeh, 16 drive limit, i have 9 right now, w/ 2 more on the way :D, but after these 2, i'm gonna be set for a while and wait for multi TB hdd's.
well i have 16 drives right now, granted they are 320 and 500gb so i could always just replace them with bigger drives; however, atm 500gb drives are most efficient when it comes to price/storage ratio.
I like how they made the whole concept of replacing drives with bigger etc so easy, while it is possible to increase volume size in freenas it is a major pita of cli commands.
