Selling Computer Parts
Rain-X
How do you guys recommendation on how to package computer parts to be sold. I didn't keep the anti-static bags the parts originally came in. What about with processors too?
Thanks.
You should be able to find some available online. While the risk is low, most people will be upset if not shipped in esd bags. Also check a local computer store. They will usually have some and may give them to you for free.
Processors should be put between two thick layers of foam an put in a box with a little bit of pressure to squeeze the two foam blocks together. All other items should be put in anti-static bags in a small box for each (or a bigger box for a quantity of items) and then All the parts should be put in a big box full of foam peanuts. This might seem like quite some work, but you will definately get good feedback and all this stuff is very easy to find. Foam @ your local homedepot, staples, officemax, etc. Also anti-static bags at you're local computer store (credit to zoobaby).
Not my words and I forgot who wrote it but I think this should help:
Processors:
Keep the littel blsiter packs that they come in.
Then take a small box (i usually use a box that checks come in) and pack it with peanuts, or paper, then write " fragile" on the packaging. Always get insurance on these
Motherboards:
More or less keep the original box and anti-static bag. If you are shipping retail, put it in the antistatic bag and load it with peanuts, for extra security, double box it and peanut that too. Also write fragile on it.
Video cards:
Same more or less as a motherboard, but make sure that nothing is rattling inside.
Harddrives:
These I find are the scariest to ship, they are quite heavy and with not enough support they will bounce around, i found to wrap it in bubble wrap and then put it in a box with peanuts and ship it out, Of course its inside a anti-static bag first.
RAM:
THe way i found to ship ram is to either keep it in its original packaging, or, take a dimetap box or similar, and then get some foam strips, slice the strips of foam so the RAM can fit inside, then close it off completely, shave the foam to fit to the box, wrap it with a brown paper bag and ship it out with " fragile" written on it.
Cases:
I havent shipped one so i dont. My guess is to keep the original packing and ship it like that.
I hope this help. As far as how to ship use: USPS or FEDEX Always get insurance for expensive things and make sure to get a tracking/delivery confirmation number.
For added security, also print your trade, and that both of you agreed on. Its kinda like a packing slip, also list what you shipped etc.
