Indolentron
- Dec 10, 2005
My computer goes through fits of weird freezing. The cursor will work, but Firefox or whatever program will stop responding, while others still work briefly but soon stop responding as well. I can click on things on the task bar and the bar responds but programs wont open and right-click menus won't properly load frequent docs etc. I have to hard reboot, and the issue will often reoccur in 5-30 mins. Once in a blue moon, the computer will respond again after a minute or two, but in general it is permanently frozen. Spells of these freezes last an evening or two and the spells are usually weeks apart or longer.
My system is:
Intel Q6600, 2.4ghz
Abit IP35 Pro
Crucial Ballistix DDR2, 4gb
Radeon 6950 2gb
Intel 510 SSD, 120gb (system drive)
2x Seagate 320gb HDDs in RAID0
WD 1tb HDD
PCP&C 640W PSU
NOD32 Antivirus
I've had components overclocked at times, but the issue happens even if I go a very long time without doing so. Temps are fine.
Most of the system is pretty old, and the problem didn't start until sometime after I got the SSD last summer. I've had suspicions that it was related to getting the drive too full (>90%) but clearing off space doesn't immediately fix it, so I guess not. The only newer component is the video card (January) but I think the problem had already happened a few times before then.
Any ideas? I've found a few stories about Intel 510s freezing, but nothing that resolves this issue.
My system is:
Intel Q6600, 2.4ghz
Abit IP35 Pro
Radeon 6950 2gb
WD 1tb HDD
PCP&C 640W PSU
NOD32 Antivirus
