Rattlin Bones
- Sep 29, 2009
Hi guys! New around here. Currently looking to make some upgrades to my 3200+ (754), 1GB RAM, 420w PSU system because it just isn't cutting it anymore. Hoping you can help me out, as I've been out of the computers game for several years.
CPU: People keep recommending the Phenom II X2 550 BE to me, so I presume that's the sweet spot for value right now. Do you agree?
Motherboard: My potential needs are mentioned in my questionnaire response. Gigabyte 770 is what's been recommended to me for non-CF. Anything better out there?
RAM: Here I'm clueless. Last time I bought RAM, there were no numbers appended to DDR. I imagine I want 2x2GB, but what generation, speed, and manufacturer? And is DDR3 backwards compatible with DDR2 boards? If it isn't, and the GB770 only supports DDR2, do I want to shell out for a DDR3-compatible board so that I'll have upgrade options in the future? Or should DDR2 hold me over until it will make sense to do a total-system upgrade?
HD: Don't need anything above 500GB unless the price is right. This will be the system's primary (and likely only) drive.
PSU: Totally clueless. Would love a specific brand and model recommendation. I presume 500-550w is enough for my current upgrade, but should I have more for when I eventually upgrade to DX11, and perhaps a 24" monitor?
Your recommendations and advice are very much appreciated. Thanks!
1) What will you be doing with this PC?
Gaming is likely the most hardware intensive thing I'll be doing.
For the components I'll be upgrading at this time, I'd like to spend under $600 CAD.
3) Where do you live?
Toronto, Canada. NCIX.com and NewEgg.ca are the big online guys. Local stores I've used are Infornec.ca, PCVillageCanada.com, and CanadaComputers.com.
4) What exact parts do you need for that budget?
CPU, Mobo, RAM, HD, PSU, OS.
5) If reusing any parts, what parts will you be reusing? List make and model.
Case (some decent Cooler Master), GPU (8800 GS 384MB), audio card (Audigy 2 ZS--unless onboard sound is as good), display (Viewsonic VX2025wm 20.1"), all other basic stuff.
6) Will you be overclocking?
Don't expect to. Have never tried it, due to fear of screwing something up. If you happen to tell me that it's super easy with the CPU/Mobo I wind up getting, I might give it a shot. But I won't be heartbroken if the components I select aren't OC-friendly. I do not want to have to mess with aftermarket cooling.
As mentioned, Viewsonic VX2025wm 20.1" (1680x1050) is my current. But I might want to upgrade to a 24" down the road. I don't intend to upgrade GPU until DX11 though, so this will probably be a consideration for that time. Might influence my current PSU decision, though? That's one area where I need your help.
I'd say within the next month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I don't think SLI/Crossfire will ever be viable for me, due to cost. Never messed with RAID. Only thing I'd like are at least two standard PCI slots for older devices and enough IDE whatsits so that I can use an old 80GB IDE drive for back-ups, if possible.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, XP Premium. But I want to make the jump to Vista + 7 upgrade or just 7, should I not upgrade until after its release.
