Seeking Advice on New PC Build...
Jaxel
I do a lot of video editing and gaming. So I am trying to build a PC that can do both of these needs. I'm looking to build an efficient priced PC... I went with a quad-core to meet with my video encoding needs. Comments would be appreciated...
MOBO: ASUS P5E LGA 775 Intel X38 ATX Intel Motherboard
http://www.newegg.com/product/product.aspx?item=N82E16813131219
PROC: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor
http://www.newegg.com/product/product.aspx?item=N82E16819115017
CPUF: ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
http://www.newegg.com/product/product.aspx?item=N82E16835118003
MMRY: G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory
http://www.newegg.com/product/product.aspx?item=N82E16820231145
HDD1: Western Digital Raptor WD1500ADFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136012
HDD2: Seagate Barracuda 7200.10 ST3320620AS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/product/product.aspx?item=N82E16822148140
- I am getting three of these drives, hooked into RAID-0 to handle HD video capturing.
VID1: ASUS EAH3870X2/G/HTDI/1G Radeon HD 3870 X2
http://www.newegg.com/product/product.aspx?item=N82E16814121228
VID2: BlackMagic Intensity Pro
http://www.blackmagic-design.com/products/intensity/
Everything I havent mentioned is using the stuff I already have in my current PC: DVDRW drives, keyboard, mouse, monitor, printer, scanner, speakers.
So right now I am stuck at CASE and PSU. About how much power would be needed to keep this PC running? I was thinking of getting (this), but I wasn't sure about how it would fit in cases.
The cases I was interested in:
http://www.newegg.com/product/product.aspx?item=N82E16811163080
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112118
The only pros about the X38 chipset is that it has A) PCI-E 2.0 support which is pretty much useless since there aren't any cards out today that can fully saturate the AGP bus let alone PCI-E 1.1, B) Native Crossfire support which you don't need and C) better support for DDR3 RAM, which right now is horribly expensive.
So drop unless you really want to pay extra for essentially worthless features, drop down to a P35 mobo instead. Here are some other recommendations:
Abit IP35-E Intel P35 Motherboard - $90
Gigabyte GA-P35-DS3L Intel P35 Motherboard - $90
MSI P35 Neo2-FR Intel P35 ATX Motherboard - $119
Gigabyte GA-EP35-DS3R Intel P35 Motherboard - $127
DFI LanParty Dark P35-T2RS Intel P35 Motherboard - $150
Gigabyte GA-P35-DS3P Intel P35 Motherboard - $151
Abit IP35 Pro Intel P35 Motherboard - $170
Gigabyte GA-EP35-DS4 Intel P35 Motherboard - $176
Just to help you out: If you don't need RAID, more than 4 SATA ports or legacy ports, then the DS3L is a good choice. If you need 5 SATA ports, 2 eSATA ports, and a second PCI-E x16 port, then get the Neo2-Fr. If you want 8 SATA ports, RAID, and legacy ports and high overclocks, than the DS3R is a good choice. If you want the DS3R but need Firewire, then go for the DS3P. If you want a mobo with a ton of overclocking options, go with the LanParty. If you want something that can overclock pretty damn high along with eSATA ports and firewire connections, than the IP35 Pro.
Drop the Zalman HSF. There are much better HSF for the price out there like the Tuniq Tower and Ultima 90:
Tuniq Tower 120 HSF - $45
Thermalright Ultima-90 HSF - $46 & Panaflo FBA09A12M 92mm Fan - $3
Any of these power supplies would be enough for that rig:
Corsair 650TX 650W PSU - $140
Corsair 620HX 620W PSU - $139
Corsair 750TX 750W PSU - $156
PC Power & Cooling Silencer 750 Quad - $162
Thanks for the quick response...
Right out from the start, I plan on having 4 SATA hard drives (with 3 of them in RAID-0) and 2 IDE DVD drivers, and I dont want to rule out futher expansion. I also don't plan on doing much in the way of overclocking; probably just the CPU a small amount to draw that extra power. Legacy isn't an issue, the more USB the better, front panel connectors required, and I have no need for eSATA (nor do I know what it is). I only need 1 x16 port (for Radeon HD3870x2) and 1 x1 port (for Intensity Pro); and I don't plan on doing any Crossfire (which is why I am getting the 3870x2).
I've always preferred ASUS mobos, but you dont seem to recommend them... is there somethign wrong with them? I noticed the ASUS mobo I listed before doesn't even offer DDR3 and its an X38 chipset. If I had to chose something else, it would be Gigabyte. Which mobo would you recommend from my listed specifications? I'm thinking the GIGABYTE GA-EP35-DS3P, what is the difference between that the the GIGABYTE GA-P35-DS3P
As for the Tuniq Tower... will it fit in this case?
Is 750watts going to be enough for the Radeon HD3870x2 and the Intensity Pro? As well as the 4+ hard drives?
Okay... looking at the... PC POWER and COOLING Silencer 750 Quad PSU...
Shouldnt I get the... Crossfire Edition:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341011
not the... Black SLI Edition:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
? The Black one that you linked only has 6pin PCIe connectors, while the Crossfire one has 8pin PCIe conenctors as well... not to mention its $20 cheaper?
*EDIT* just looked it up... the Silencer 750 Quad is 180mm in depth; which is too big to fit in the Lian Li V1000. So it looks like I will be getting this: http://www.newegg.com/Product/Product.aspx?Item=N82E16817256016
Okay... I've decided to get the Cooler Master Cosmos case instead of the Lian Li? There are two models of the case, one is ESA and has a VGA side fan, the other doesn't; is that worth the extra $70?
As well, since I am going with a bigger case, I decided to get the PC Power & Cooling 750 Quad Crossfire PSU.
You can pick up the Silencer 750 Quad Black for ~$144 shipped here. That said, if you'd rather get the red, $150 shipped isn't a bad price at all. The black one does come with a pair of 4 to 6 pin PCIe power adapters though.
No, the $70 extra for ESA and the fan is not worth it. You don't have a 780i board so you won't have ESA support anyway.
DDR2-1000 is useless with a Q6600. Even OCed to 3.6Ghz all you need is DDR2-800. Faster RAM will offer no performance increase. This G.Skill kit saves you $15, but a $70 AR 4GB Adata kit would do just as well.
eSATA is external SATA, for use with external HDDs -- much faster than USB2.0.
If you're looking for an Asus board, I recommend the P5K-E.
The difference between the P35-DS3P and the EP35-DS3P is that the latter is more energy efficient, according to gigabyte (power savings). If you don't need firewire, you can drop down to the DS3R instead.
I was about to tell you to ditch the raptor, but its up to you. Here's my canned response to people seeking a raptor...
Avg Transfer Rate, Access Time: HDD info, Price I paid (except for raptor - twas a gift)
**note, these figures come from HDTune, a synthetic benchmark for HDDs.
112MB/s, 13.2ms: RAID0 'cuda's, 600GB total, $120 (ICH9R on P35-DS3R)
78MB/s, 08.2ms: WD Raptor WD1500ADFD 150GB, $160
76MB/s, 13.7ms: WD Caviar SE16 WD7500AAKS 750GB, $150
72MB/s, 15.4ms: Seagate Barracuda 7200.10 ST3250410AS 250GB, $65
68MB/s, 13.3ms: Seagate Barracuda 7200.10 ST3320620AS 320GB, $60
65MB/s, 13.7ms: Seagate Barracuda 7200.10 ST3320620AS 320GB, $80
65MB/s, 13.2ms: Seagate Barracuda 7200.10 ST3300620AS 300GB, $60
63MB/s, 13.4ms: WD Caviar SE16 WD5000AAKS 500GB, $100
62MB/s, 15.3ms: Samsung HD501LJ 500GB, $105
52MB/s, 14.0ms: WD Caviar SE16 WD2500KS 250GB, $70
As you can see, the 'cuda is twice the size and half the cost, for nearly the same avg transfer rate as the Raptor. Stick them in RAID0, and you've got an even more cost effective solution. Though, the seek time of the Raptor can't be beat. If you have cash to burn, do so on a Raptor if you really want it. Otherwise, there are better cost effective solutions depending on your needs these days.
Those Barracuda 7200.10 drives are loud and slow.
Consider spending the money on 2x 640GB WD6400AAKS instead. Each WD6400AAKS provides 1.5x the performance of the Seagate ST3320620AS with ~95MB/s average read in HD Tach. If you can't wait a few weeks for the release of the WD6400AAKS, you can get the new 320GB platter WD3200AAKS-00B3A0 from this ebay seller. It scores ~91MB/s average read in HD Tach and ~170MB/s with two in RAID0.
Did I mention you could put your ear to the WD6400AAKS and WD3200AAKS-00B3A0 and not hear a thing?
DVI IS hdmi. The only difference is hdmi carrys an anolog signal. the entire lineup of HD3k series comes with a DVI to HDMI converter, (which requires you to bridge audio which from time to time can be a bit of a problem). If your gonna use that anolog jack for something then sure, but, if your just in it for the hdmi, buy an HD3400 pro, its less then $100 and comes with one DVI -> hdmi converter. If you need more, just get an HDMI switch. Thats another $100, still well under the $350 price tag of that sucker.
and uhh, on the topic of hard drives, how about them 7200.11 cudas?
Still loud, but less noisy than the 7200.11. They're still quite slow in real-world applications compared to the competition (7200.11 = ES.2).
MrWizard, the purpose of the $350 Intensity Pro is for video capturing, not video-out. Right now its the only consumer level device that can capture high definition content.
I think I'll go with a single WD Caviar RE2 WD5001ABYS (instead of 2 cuda 320gb)... from what I hear, the ABYS line is better than the AAKS line.
Also, what advantage does a 32mb cache give over a 16mb cache?
None.
The primary factors affecting performance are (1) platter density, (2) cache and controller design -- but not size -- and (3) rotational speed. The denser the platters, the higher the throughput.
With hard drives, platter density is the equivalent of MHz and rotational speed is the equivalent of IPC.
The WD5001ABYS is not a fast drive because it uses smaller platters. Ideally, you want a drive with at least 250Gb platters and 300+GB would be preferable. Edit: I was thinking of the WD5000ABYS.
WD5001ABYS is 500gb... what do you mean by smaller platters? I assume it would have 2 platters at 250gb each right? Are you saying a WD3201ABYS would be better because it has a single 320gb platter instead of dual 250gb platters?
Or should I just get two WD3200AAKS and just call it a day? What about the 5000AAKS? Does it suffer from the same issues as the 5001ABYS?
The older WD5000ABYS was a three or four platter design. That's what I was thinking of when I made that comment. I don't know whether WD5001ABYS uses two 250GB platters or not. Judging from the Newegg reviews, it probably does.
I don't know whether the WD3201ABYS uses two 160GB platters or one 320GB platter. Western Digital started manufacturing drives with 320GB platters on January 21. Any 320GB Western Digital drive manufactured prior to that date uses 160GB platters.
As I mentioned above, Western Digital will ship the WD6400AAKS next month, and all of those will feature 320GB platters. If you are buying a 320GB drive, you'll want to confirm with the seller that it is indeed the new 320GB platter version.
Remember to click through the Newegg ad at the top of the page when you order please! They like to see big orders come through our forums. :)
Kyle,
Did you contact Miss Skinner @ WD to obtain the 6400AAKS and new version of the 3200AAKS? Or were you not interested in benchmarking the newest generation of hard drives?
I thought you were going to do that....
Okay... what about RAID?
The WD5001ABYS seems to be designed specifically for RAID Arrays... How is the WD6400AAKS expected to perform in RAID Arrays?
When is the WD6400AAKS coming? The page for it on WDC.COM has been deleted.
My understanding may be wrong, but AFAIK, the ABYS uses a slightly different mechanism to improve long-term reliability. It doesn't have anything to do with performance or RAID performance.
The WD6400AAKS should be the performance leader for RAID, at least until the 320GB version of the Western Digital Raptor ships this summer.
Here's the HD Tach for the new 320GB platter version of the WD3200AAKS.
PCMark05 Results
Code:
XP Startup:           11.114 MB/s
Application Loading:   7.991 MB/s
General Usage:         7.292 MB/s
Virus Scan:          116.577 MB/s
File Write:          101.494 MB/s
I have the drive suspended in rubber bands (Antec P150), which may affect access times slightly.
Edit: By request, here's the HDTune results:
