Seedbox/HTPC - $1000
earnstaf
Would like have as much storage as possible and be fast enough to support multiple streams. Small and low energy draw are also bonuses but not requirements.
Will be seeding torrents and running Plex for HTPC.
$1000
US
Case, CPU, RAM (ECC?), Lots of HD, etc. No need for monitor or peripherals.
Nothing
6) Will you be overclocking?
No
N/A - will likely just manage via xterm or something.
ASAP.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Need some help here -- I'm guessing RAID and Gigabit NIC
Will be using something free -- either Linux or FreeNAS. Leaning towards Linux.
I've looked into similar requirement. You'll find that a mainstream i3, possibly Haswell Core i3-4130, is the best way to go. Sure you can get a Pentium G3220, G3420, or G3430, but the cost difference isn't much and if you need more CPU processing power in the future, the i3 will come in handy.
Do you already have a flash drive 4GB or larger?
All forget my last question. Here's what I recommend:
$130 - Intel Core i3-4130 CPU
$130 - ASRock Z87 Extreme4 Intel Z87 Motherboard w/free
$56 - Crucial CT102464BA1339 8GB DDR3 1333 RAM
$480 - 4 x Seagate Barracuda ST3000DM001 3TB 7200RPM SATA 6.0Gb/s Hard Drive
$80 - Seasonic G Series SSR-550RM 550W Modular PSU
$43 - NZXT Source 210 Elite White with Black Front Trim ATX Case
Total: $919 shipped
Notes:
- Yes that is 12TB of raw storage.
- That motherboard comes with a free 16GB flash drive if you buy it ASAP. In addition, it also has 8 SATA ports which fits perfectly with the case which can fit 8 hard drives as well.
- Honestly, you don't need a 550W PSU. However, that Seasonic is one of the cheapest better bang for the buck PSUs that's really efficient.
- If you need to add another 4 drives in the future, then I recommend this module:
$25 - Cooler Master STB-3T4-E3-GPc w/ 120mm Fan
