ObscureTerror
- Aug 29, 2007
I have a few questions, so I'll try to keep them as concise as possible:
1) I'm running ESET's Security Suite (NOD32) for a/v (it's firewall also turned on, though it's one of the worst firewalls) and using a D-Link gaming router (large NAT) as a firewall.
Is this a good set-up in terms of security and privacy for my home systems?
Windows firewall is off for certain reasons.
2) Please, no "fanboys" or "flame wars" regarding this question: what is all the "hate" towards/about ZoneAlarm?
I used it for many years, and it's ability to block inbound and outbound traffic seemed to offer a great deal of privacy.
I found it blocked countless attempts/IPs knocking at my back door, that I otherwise would have not known about.
I also never had ZA crash or otherwise cause any problems with any of my systems or other progs/games, as long as I allowed known safe software to install/run properly.
With these things in mind...
If my router/firewall is not enough along with ESS, would it not be a good idea to also have ZoneAlarm running as well, blocking any further possible intrusions? ZA would still detect "knocking" (among other things) and block it, even when using a hardware firewall.
I was running a different router (hardware firewall) back then, and I'm curious if there are things getting through my present router/hardware firewall that ZA would detect, just as with my old router. Only firewall prog I've used that has detected as much as it did.
So, I'm just curious about what some people who are knowledgeable with such things think about my situation and the ideas I'm putting forth, because I'm no security expert, though I know some things.
Oh, and I've tested my system through the ShieldsUp! site and it claims my system is "completely invisible" to the outside world, no "holes" anywhere, for whatever that's worth... no idea.
Thanks.
Thanks.
