VanGoghComplex
- Apr 5, 2016
My loop is a pain in the Asus to fill, drain, and bleed, and it's entirely my fault.
In the top rear of my case sits a Swiftech all-in-one radiator, reservoir, and pump. The res is tiny, the fill port is awkward and so positioned that bubbles don't easily escape when I'm attempting to bleed it.
What I'm considering is adding a tubular reservoir in the bottom front quadrant of my case, with both inlet and outlet tubes being positioned on the bottom. Its primary function would just be as an air trap. I know filling the loop would be a bit tricky, but once it's mostly filled, bleeding should be a lot simpler... right?
Has anyone ever done anything like this before?
