peanuthead
- Feb 1, 2006
I presently have a CX750M performing flawlessly. Is there any reason to upgrade/side grade to a Seasonic X750?
I wouldn't go so far as "a massive upgrade", but the the Seasonic definitely has tighter voltage control and efficiency rating!
4790k at stock speed, light water cooling, couple of drives and a 270x
So you're doing to going to be doing Crossfire down the line with R9 290 cards or higher then? Because even with R9 270 Crossfire, 750W is still quite a bit overkill. In fact, you could go with GTX 970 SLI, R9 290 CFX, or GTX 780 SLI and still be well under 650W:I don't need it anywhere "yet". Future upgrades could utilize it.
The lower-end CX430 is fine. The non-modular CX750 was recently shown to be a shitty power supply:I've never had an issue with the CX line. Good inexpensive PS for what it is.
Corsairs CX stuff is like their left over piece of crap stuff they salvaged together and called it a PSU. Unless it's AX, HX and maybe TX and RM series, it's most likely garbage.
That being said. It's a massive upgrade to the Seasonic.
The idea originally was to SLI two 560Ti cards, so that coupled with the hardware (I calculated about 400w in total when all would have been done) I had at that time and a a good deal on a 750w PS warranted the wattage level I chose.
Dangman, I have the modular design. I have made my decision. Thank you all for the input.
http://www.hardocp.com/article/2014...970_sli_4k_nv_surround_review/10#.VOKn6vnF-0c
http://www.hardocp.com/article/2015/01/21/corsair_cx750_750w_power_supply_review/
So yeah, I would recommend a PSU replacement.
The modular design is identical to the non-modular besides the modularity.
SLI 560ti would have warranted a 650 watt PSU, at most. 550 would have been more than sufficient.
You also just proved my point. You plan for it, and end up doing something else. Meaning you were just dreaming.
It's not a secret that the CX is an entry level PSU, but we also know that it gets the job done and they are pretty reliable for its purpose. Like what the OP stated, his CX unit has been "performing flawlessly". That itself is already a proof that it is not just some left over crap put together and call it PSU.
, can you explain me what is the purpose of the CX750 PSU, because really, i can't find any!!"It's not a secret that the CX is an entry level PSU"
Since: , can you explain me what is the purpose of the CX750 PSU, because really, i can't find any!!
1)Since it's an entry level PSU, with low quality components (*capacitors for example), it's obviously not suited for gamers that need up to 750watt, meaning systems with SLI/Crossfire setups.
2)For just a home office PC, also it's obviously not suited, because for such a PC, a 750watt PSU is overkill.
So what is the reason of this PSU's existence?
It's cheap. It is probably sufficient for a peak load of approximately 550W, which is enough to power quite a bit of hardware. It is modular. Did I mention that it is cheap? I've seen these as low as $35 after rebate.
No one is arguing that it is a great PSU and most [H] enthusiasts probably will not put one in their rig. With that being said, it occupies a niche in the market that would otherwise be filled exclusively by the likes of RaidMax, Diablotek, Logisys, CoolerMaster, or any number of other manufacturers with even more over-exaggerated specs on the box. People will buy it because of the price and a lot of them will probably never run enough hardware on it for it to be a major problem.
Yes, but the 750 watt labeling is essentially a lie. You wouldn't want to run 750 watts of equipment off of this power supply.
There are better 550 watt power supplies to be had even at around $35. One is the XFX Core Edition 550 watt, a Seasonic-made 80+ Bronze power supply. Goes as low as $26. The XFX TS 550 watt Seasonic-made 80+ Gold power supply has been down to $40. Or how about the Antec TruePower Classic 750 watt Seasonic-made 80+ Gold for $50.
Also, as of right now, Newegg has the CX750M at $80 AR. The Antec is $60 AR. The CX750M is obscenely overpriced for what it is. Its sale price should be its regular price, and its sale price should be down in the 20s.
I can justify my purchase all day, but I understand it wasn't wise as much as impulse and need.-So the question remains: what is the reason of this PSU's existence?
So your real answer is marketing and sku coverage and because shit psu's sell and make them more money. CX line has 3 sku's in the top 5 and they all review well. So they cost less to make, probably have significantly higher margins, and they sell WAY more of them.
