Thug Esquire
- May 4, 2005
That's enough to justify re-calibrating your overclock all over again. First, check the PCIe voltage and make sure it's not too high/low, and fix it if you have to.i was overclocking the piss out of everything with the 7900gs, no issues.
now i have everything underclocked slightly...still problems
the only things i have changed are the video card and a fresh install of win7x64; previous was vista x64
Then, if you still have problems, reset your mobo to failsafe defaults and try running the system stock. If it doesn't run properly at stock volts/speed, some part of your system is busted, and you probably broke it by O/Cing.
