Seasonic SS ST difference
jeremyshaw
Hello,
I saw 2 PSUs today, both are identical except for:
ST-400H1U and SS-400H1U.
The SS-400H1U is listed on the Seasonic website, while I cannot find any reference for the ST version, other then a few vendors selling such a device. (UL page, too)
They are both the same, and I'm not too sure on what is the difference!
Thank you,
-Jeremy
Whoops, sorry Danny Bui,
I bought one, the ST-400H1U, then I noticed the Seasonic website makes a refernece to a SS-400H1U.
They are both on this UL page:
http://database.ul.com/cgi-bin/XYV/...n=versionless&parent_id=1073787374&sequence=1
and the SS is here:
http://www.seasonicusa.com/1u.htm
I just cannot find the ST on the Seasonic site, but it's there, on the UL page! Is it an older revision? Or just a bit of wierd Seasonic nomenclature?
Thanks!
-Jeremy
p.s. this review was the final deciding factor, along with some encouragement from the HP Slimline thread we have.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=131
Apparently Seasonic used to use SS and ST to distinguish between the noise levels of different PSUs. ST was the louder version. I don't think it'll make a difference in practice though. Go with whichever one is more convenient for you.
HaHa. Thanks Zero82z. I'm a little late for that! :) (purchase made this morning, only noticed the different model prefixes just before I made this thread).
I intended a 60mm fan case mod for this PSU, already.
I was very concerned SS and ST meant differing qualities/purposes.
These are both 1U server PSU as far as I can tell, and I only saw reviews for the SS variant, so I thought ST meant rebranded units (after checking Seasonic's website and only seeing the SS)...
ST = noise, huh? Did they remove the 'silent fan controller' part? (not that it would matter... those are 2 40mm buzzsaws designed for server use, anyways).
Oh, well. I will keep everybody (who cares) updated in the HP Slimline thread (where I frequent, due to both of the system's in my signuature...)
Thank you!
p.s. If anyone has any differing viewpoints on this, I'm all ears.:)
