Seagate IronWolf Pro 28TB performance issues
DF-1
I got a Seagate IronWolf Pro 28TB from newegg. Every transfer I do maxes out at 125MB/s and i'm not sure if this response time is what it should be either (jumps from 0.5ms to 1100ms).
I tried downloading some seagate tools and doing tests but everything seems normal there.
is it normal? I remember having hard drives 20 years ago that did 250MB/s...
I'll start with the obligatory change the power (try a SATA power connector on another power rail if possible from the one it is using now) and data cables and try again. What port is it attached to (AIB, motherboard CPU, motherboard PCH?) What OS? Do you hear any weird clicks like the heads trying to reposition over and over in 2 second bursts? Is this a completely blank drive? While reads are slow they are relatively stable. The writes are sawtoothed which usually means contention of some kind. Turn off any antivirus temporarily and try again if the cable/power didn't help.
If none of this helps, do a long test (I believe you already did the short test) in SeaTools and see what that says. Please also post a SMART listing.
I got a 26TB Seagate Drive (ST26000DM000) for ~$250 late last year, one of the last true deals before prices went crazy. It's not a high-end drive but it has worked well for me so far. I get 230-250MB pretty reliably when copying large files. So your speeds do seem slow.
Even though it's kind of an obvious question, I'll ask anyway since I did not see it stated. What were you transferring at the time? With a mechanical drive (and even SSDs to a lesser extent) you are generally only going to see speeds approach max when transferring a single large file. If you are transferring a batch of smaller files, then that changes everything.
Definitely need to know the type of files being transferred and where they're being transferred from. I have an 8TB Seagate Ironwolf (non-pro) and when transferring from an SSD large, contiguous files I'll sustain at least 200 MB/sec for writes with reads being higher than that.
What does Crystal DiskMark show?
Sure you got it connected to an SATA6 port with a new cable, not some ancient SATA port you found in a drawer from 20 years ago?
Windows? Port on the MB? New cable?
Install chipset drivers for the motherboard type.
Its not super common but happens, the port and the drive negotiate a lower speed than they should.
Chipset drivers will fix it a lot of times.
If that fails try a different sata port away from the one your using on the mb to potentially put it on a different controller.
