Seagate HDD - - Not Detected at Boot
craige4u
I have a 1 year old seagate Harddrive 500GB running windows 7,
Its was running great with no problems ever, but today my homes electricity went suddenly after electricity returned, I started the computer and it booted properly and then i used the PC for 6Hrs. non-stop.
I shut down and then i tried to boot... then nothing......I get Asus logo and options to enter bios... Even in bios HD is not detected
1] I tried re-installing OS, but hard drive is not detected.
2] I tried running another HD which runs great, and tried to connect this bad HD to extract data.... But, this bad HD is not detected at all...
3] I have seatools on bootable CD only... and even tht does not detect HD, so tht it can fix. (Is their any another way?)
Please help this HD has imp. data. (i had taken backup but then its 5months old).
Any softwares to recover/detect HDD?
NOTE: Another 2 HD tht i have is working so its not PC problem. This Problematic HD is not damaged in any way due to power failure...
Put the drive in a simple USB or esata enclosure and connect it to a running pc to see if you can access it.
Does the disk has power at all, does it spin when it's switched on by the PC?
I'd try to connect it to a completely different set of connectors and cables, like Dark Prodigy suggested, in case it's a power problem (likely). Looking at the bare disk to spot burned out components doesn't really work anymore, everything is so integrated now.
You can also try the freezer trick, if it's not an urban legend.
If it's not recognized in the BIOS your only option is professional recovery and that starts @ 500.00.
Sorry.
