Slartibartfast said:Yeah, that brand name doesn't ring a bell, so I'd label it "suspicious."
EnderW said:
Get a clue.Hvatum said:Personally I think that's a silly argument. Of course, your experience with a drive does not represent a statistically significant sample, but it's still important to know which drives generally are more reliable. A large survey could accomplish that, which storage review is doing. Why they don't reference it on the above page I'm not sure.
One could actually apply the argument you linked to to cars or planes also. Like: "It's not really important to worry about how often each model of car or plane crashes. Unless you're driving hundreds of cars or planes at the same time you won't see those same statistical results necessarily play out. You could buy only Toyotas yet have them all fail, but that doesn't mean that Toyota is a bad brand. So based on this logic there cannot possibly be an importance or relationship between reliability and brand and anyone who thinks there is is an uneducated Pleibian."
The point is, whether or not a car is going to fail depends upon if it was damaged during driving, poor maintance by user, bad oil, or lack of oil changes, not simply by the brand..EnderW said:*useless ad-hoc comments removed*
The point is, whether or not a drive is going to fail depends upon if it was damaged during shipping, poor handling by user, bad PSU, or lack of airflow, not simply by the brand..
Bah, they're just trying to get more market share. Sorta like Hyundai's 100,000 warrantly. Doesn't make the product any better. Both with take some losses for that.Also, any company that is willing to ad two more years of warranty to their product then all the other companies must know that their drives are better and will last longer.
protias said:If this is your 2nd drive in 10 days, then maybe you should start looking at your power supply and not the drives. Yes you could very well have gotten 2 bad drives, but that is extremely unlikely. What is your power supply?
swatbat said:I don't know about this. First drive failed. Second drive is prob a refurb from seagate. I've had nothing but problems with refurbs. When I use to work as a notebook tech I had to deal with refurb drives from all the vendors daily. Hell I've had 5 drives bad in a row.
My personal view on hard drives is if one dies I just buy a new one. They are one thing that I don't trust a refurb on.
Hvatum said:The point is, whether or not a car is going to fail depends upon if it was damaged during driving, poor maintance by user, bad oil, or lack of oil changes, not simply by the brand..![]()
unhappy_mage said:I have 10 seagates in operation right now - 8 320s and 2 IDE 120s. The 320s have been running 24/7 since August; the 120s have been taking a pounding doing everything from boot disk to scratch disk to torrent drive since 2003.
I also have or had 6 or 7 maxtors, and one or two WD (I can't remember what one drive was). I've experienced zero failures when I was using a reputable power supply (remember, nothing kills hardware like a Deer).
RE drives are not recommended for single-drive usage.ktk said:i guess i wold go for a new PSU and a new RE2 series WD hard dirve when i get my pay next month....
maybe i should buy the lottery since the chances of 2 conesctutive screwed drives are so small...
unhappy_mage said:RE drives are not recommended for single-drive usage.
Use the serial numbers of the drives if you do buy lottery tickets![]()
Sparkyy said:REs are meant for hardware RAID controller because their TLER (Time Limited Error Recovery) is different, instead of 4 ms or something that a desktop requires, they are in to full seconds of waiting until mentioning an error because RAID cards operate differently. You can run REs as a single drive but it is not recommended.
Sparkyy said:No you still have it wrong, RE drives have LONG wait times then non-RE drives. Meaning NON-RE drives wait about 4 milliseconds before reporting the error. The RE drives will wait about 8 seconds before reporting the error.
Q: What is time-limited error recovery and why do I need it?
A: Desktop drives are designed to protect and recover data, at times pausing for as much as a few minutes to make sure that data is recovered. Inside a RAID system, where the RAID controller handles error recovery, the drive needn't pause for extended periods to recover data. In fact, heroic error recovery attempts can cause a RAID system to drop a drive out of the array. WD RE2 is engineered to prevent hard drive error recovery fallout by limiting the drive's error recovery time. With error recovery factory set to seven seconds, the drive has time to attempt a recovery, allow the RAID controller to log the error, and still stay online.
Sparkyy said:Yes, and nothing I said went against WD. As I said, a NON-RE drive will take like 4 ms to fix the error it encountered. However a RE drive will, and I said 8 seconds but it is actually 7 seconds, fix the error on the RAID card side so that the drive can keep going. Meaning the RAID card will mark the area as a bad sector and ignore it and the array won't break.
Not exactly. The TLER means there's a cap on how long the drive will try (7 seconds or whatever). Without TLER there's a much higher cap - it'll keep trying for longer than 7 seconds. This is good for desktop drives - when you've only got one drive, it's the only place to get the data from, so it has to keep trying as long as possible. But with a raid controller and a redundant array, there are other places to get the data - the parity from the other drives, or the mirror. So waiting 30 seconds when the other drive has the data is counterproductive.Sparkyy said:REs are meant for hardware RAID controller because their TLER (Time Limited Error Recovery) is different, instead of 4 ms or something that a desktop requires, they are in to full seconds of waiting until mentioning an error because RAID cards operate differently. You can run REs as a single drive but it is not recommended.
drizzt81 said:I suggest you pay a visit to the drive reliability survey over at SR. While I still think that their samples is too small, you will notice that the same brand can have widely varying percentile scores.
If you look at the Baracude 7200.7 and compare it to the 7200.8 both drives have hundreds of responses and completely different percentile scores...
oh yes, to view the results you need to enter at least one drive, but preferably all the drives that you own.
Dark Ember said:Geez, I haven't logged into the forums in 2 months, and nothing has changed.
For the every day user, ALL BRANDS are equally reliable. The DPPM numbers are so low for any given manufacturer, your chances of getting a "busted" one out of the chute vary by tenths to hundreds of a percent. If you get a broken drive, it is most likely that something else is the cause - and it's usually handling damage or power - like was mentioned above.
The only exception to this is situations like the IBM 75GXP's a while back that had a design flaw - and we all hear about big problems like those. Companies can't afford to ship drives that are going to break all the time. The margins on hard drives are too slim and the cost associated with the warranty returns would kill them.
I'm sure when I come back in another 2 months, there will be a similar thread. Sigh....![]()
2 months? more like next week.Dark Ember said:Geez, I haven't logged into the forums in 2 months, and nothing has changed.
