SD Card Recovery
kopekci
After I have formatted an SD card, can I recover my data in it by means of data recovery programs? If yes, which softwares do I need?
Maybe if you don't use the SD card at all after the format. By use I mean add any other file to the card. As for software, someone else will have to help you with that.
Like Danny Bui said, if you didn't put anything on the card after you formatted it then there's a great chance of recovering most or all of your data. Try using Recuva (free) or GetDataBack (shareware).
You can consider stellar card recovery software as it will recover your all data it doesn't matter you have photos videos audios or any other file . Unknown file formats are recoverable. Try its demo version first. Download it from here Formatted Sd Card Recovery Software
