How does the 1150RPM compare to the SFLEX E (1200 RPM) w/ regard to:
1. Noise
2. Airflow
3. Static Pressure
Thanks!
Its 50rpm between the two, and the GT is known as one of the best HS/Rad fans, so my money would go to a GT, for case fans, there are better choices than either.
Would you mind elaborating? I'm building in the next couple of weeks and wouldn't mind finding a few more fans for both the case and the H60 that I'm getting, but all the talk re: fans seems to center around the Gentle Typhoons as of late.
If there's a more reasonably priced alternative, I'd love to find out.
The GT are "The" choice for fans for the H60, or any HS/Rad. You can see this in the testing done here. If you have room and they will fit, the TY-140 are great case fans.
Wow, nice chart! The Noiseblocker PL-2 looks best to me. I'm actually looking @ the PL-1's though. Would love a silent case!
Not bad, those are the AP-15s right?
1. Noise
2. Airflow
3. Static Pressure
Thanks!
I just got my GT2150s from the OCN groupbuy. I popped them onto my Antec 620 rads that are on my GTX480s. I had some 1900rpm Kaze Maru 2 fans which are essentially S-flex fans on the rads beforehand. I couldn't really tell the difference to be honest. I think that these GT fas are a little over rated.
Not at all, the numbers don't lie. You are comparing a 1900rpm 140mm fan to a 2150rpm 120mm fan, you also reach a point with a rad that after a given amount of airflow you don't see any gains, no less on something like a 620 which has a very small low flowing pump. And with fans that loud, I doubt anyone would notice much of a change.
Screw it, in for 2 to give these a try.
Shame there was no Prime on that Amazon order. Funny thing is, standard shipping is 3-5 days and free, but if you choose two day the shipping cost for 2 fans was like $40 something dollars...more than the cost of the fans themselves.
So here's a question...I have an Antec 900, what two fans should I replace so that I'd see the most benefit airflow/noise wise? They're all stock, and also I'm using a Vigor Monsoon III LT on my CPU which has 2 120mm fans on it as well (I've been thinking about getting a Kuhler 620 or something but haven't done it yet).
Its not just at full speed. If I set them both to a point where I feel that they are quiet I also don't notice a difference in temps. I think that the gentle typhoons are a little over rated. They aren't that much better than a normal fan with an FDB bearing.
The HS fans, that's where GT's shine at, they are not the best (or cheapest) choices for case fans. Though they will do the job as a case fan for sure.
Must have missed your ninja edit, the flex line of fans was also tested in the chart, and fall a good way behind the GT fans for cfm to dbA. But you are talking about taking two high RPM fans, undervolting them etc, the results can be erratic at best, some people do not notice noise levels as much as other people as well, and some see it pointless to count 1-3dbA at a time, but that's all part of making a quiet system and well...People looking for that would not be buying 2150RPM GT fans like you did.
Hmm, okay, maybe I'll stick 'em on the CPU HS then.
What would you recommend for case fans then?
Dude, thats what the fan controller is for. Like I said if you set the both to where I thought that they were silent performance was the same. Thats with two fans in push pull on an Antec 620 on a GTX480 which produces a ton of heat. Make whatever you want of it.
Thats not what the numbers that you keep telling me to look at say.The idea that you can undervolt high rpm fans and have a good low rpm fan is a myth, that is what I am saying,
I know what controllers are for. And again, the 620 is going to be pump limited, after a given amount of cfm, there is not enough heat in the water for the extra air to extract. So at that point you have to increase the air flow so much to make any difference that it becomes pointless.
Again, thats at lower speeds. The rads get very warm when you are using a GTX480. So in very specific applications a gentle typhoon is vastly superior to a normal fan with an fdb bearing?
Got my order from Amazon today. Haven't used them yet because I'm waiting to get some other parts before I crack open the machine (including maybe some case fans), but they feel nice and sturdy.
What are some good case fans that I can pair with these that won't be too loud? The idea is improved airflow + quieter than my current Antec Tri-Cool fans.
"Depends on the case and what it can fit, I like the TY-140 myself but it will not fit in many cases as its a 140mm fan with 120mm mount holes, with the extra blade area it moves a good amount of air. For case fans over all its a bit easier, they are often pretty close with each other and the driving rod is often motor/bearing and how smooth it is or if it has ticks etc. Noctua, Nexus, NB, Scythe S-flex are all good smooth sounding fans, but can be a bit pricey, Slip Steams and Yate Loons are good smooth sounding fans also and pretty cheap, but this shows in the kind of bearings used (sleeve type, smooth but don't last as long). Middle of the road price would go to the X-Silent, allot of people love the 120 and 140mm versions of this fan and SWC has them on sale for 9.99 right now."
Lol, yeah I read your post the first time but the sound/CFM ratings on some of them confuse me. Some of them sound too good to be true...
Just hoping for some elaboration I guess. I dunno. I also don't know what the stock Antec ones are rated at and if all the ratings are accurate, because I certainly don't want to end up with something with less airflow and the same or louder.
