Scythe backplate padding
Feileung
I'm moving my Scythe Ninja cooler from my old setup to my new C2D. I finally got the backplate off but the protective/sticky layer is totally mangled. Do you think it's OK to make a new one with the plastic padding that the motherboard ships on? Think it can handle the heat w/o melting over time?
If not, does anyone have any other ideas?
A better bet is to clean the heatsink base and either use thermal paste/grease or you can also order new thermal pads. Personally I'd reccomend using thermal paste. Arctic Silver 5 or some such.
Cheers
Croaker
Cheers
Croaker
I think you're talking about two different things. I think he's talking about the foam layer that goes on the backplate underneath the motherboard.
I think your right.. and I'm not sure I would mess around with trying to make a new one out of a mobo bag... I would look around your local HomeDepot or Lowes for some high density foam.. just my thoughts..
This is my one problem with the backplate mounted devices. It's way too hard to reuse the backplate. I had the same problem trying to transfer my big typhoon from one motherboard to another.
