Hi, I was suggested to post my problem here. I just built a computer and the screen does not work. I plugged everything in including the monitor but it just stays black. No screen pops up. I purchased these through newegg Here are my parts:
1. SAMSUNG 22X DVD±R DVD Burner with LightScribe Black SATA Model SH-S223Q - OEM
2. Antec Three Hundred Black Steel ATX Mid Tower Computer Case
3. Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive
4. ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler
5. XFX HD-485X-YDDC Radeon HD 4850 XXX 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
6. GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard
7. Patriot Viper 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model PVS24G6400LLK
8. AMD Athlon 64 X2 7750 Kuma 2.7GHz 2 x 512KB L2 Cache 2MB L3 Cache Socket AM2+ 95W Dual-Core black edition Processor
I made sure the video card was connected with the power. The power switch on the back is on. I connected the front panel switch properly cause I tried them all. The fans are spinning (CPU fan) and the fans that came with the case. I tried both ports for the monitor on the back and I used an old computer and the monitor works fine. Im using a corsair 450W. What is the paperclip trick? I dont' have any ddr2 memory. My friend suggested it might be my monitor. I tried connecting the monitor to a laptop but it doesn't work but I'm still unsure which part is wrong. I tried the monitor on an older computer as well but it works fine.
http://www.newegg.com/Product/Produc...corsair 450W
