[Scratch Build] Project Zero
Tymofar
Hey guys,
my realname is Benny.
i am building my first own Case and wanted to share it with you.
I hope you will enjoy it! =)
My build is called Project zero cause its my first scratch build.
I have made a few little modifications throughout the past years but now it is time to
make somthing big ;D
Contemplated system:
Hardware:
Mainboard: Asus Maximus V Gene
CPU: Intel i5 3570k
Ram: G.Skill RipjawsZ (4x4) 16 GB
GPU: ???
PSU: ???
SSD: ???
HDD: 1x WD Green 750 GB
2x old Samsung 1TB
Watercooling:
Rads: 2x Alphacool NexXxoS XT45 X Flow
Res: 2x Alphacool Eisbecher 250mm
CPU: Alphacool NexXxoS XP³ Light
GPU: Alphacool NexXxoS GPX
Pumps: 2x Alphacool Laing DDC310 + Plexitop
Ram: Alphacool D-Ram cooler
Fittings: Alphacool Eiszapfen
Tubing: PETG
Fans: ??? dont know yet, and dont know if i am just going to make a push configuration or go straight push/pull =)
Current status:
y3m9s3jCcVclm74zb7c6ACeOTH2e0nhDP7dA8pX3VygpuiOe8BKqMnIp_AGJwSnPr87gUUMHdzI03nncqZUfvlSlR3nH1r0jAYsdjFAjABqtE3wT2hx4Magd_qa0LkTqvUdR6sOINjROGdfv90p9YgFmaoyJbfJDaLuq0zkNzszpNc
y3mFP5CGokGjC7EtExTDxkFyMPzjBQOoq3hbhWKsZ5bOdEOPz7QwBJ6kUxA2CDMp1HOciKBw01CopwGBM9miZyF6H04Xs-RewVY0Exq2qh8kUiYvwVxFhx1KpMg0fVOqIG1Jqxfvd85zpzGi-ntgYmbSJEFrAwzdf3KNoBVUrx2fiI
Here is a sketch of my Imagination:
y3mWNwY8V4vfRzb6l4jFrXUTvk7UPO7AG6rtX0Y7KURMUkEQ8EuU3_Mj29IBJjPO_vBNdXG-TeIGR_HgDeMt4XV3nrr41dA8bnkKx-slDwL-o_jjYco122C89OtMzftyppxv0DoiiQ0FiYRT1xDc4VDSqOdc3GNUZTnZPLTVnlLLOA
A friend of mine was so nice to make some renders before he went on holidays. Due to the lack of time
he couldnt finish them, but they will help you to imagine what i want to do.
y3mzwQ2D45JTihZS3cFWK33qMdwOPPPwYzr1K8VeoYDJLPuXpDhMdv9a4X_4LVuA7FlFhqXHfXjKxoPbCfqtcb2AhBcyJiyPUdMJVOBxJfPB2VMObnBSFzH4ciKmVVLBLCtfrR6wFrIn8vNMJG2aNoi9pB9XVdURKVji0XAbScROjI
y3mDR8_s6_dK_YZusbpAKvnANNRj2y18J8pz-g9bjxXzv4zaYqbniVspRW9O6FQPZCA_jJ7__APtI_vvm128uJCsxVyizXkN_fMXefJ9eTbn-XlNBPZKOtP3gz9OTVpLLPwpbV3xXoCnjQNxBBMeDTNHCgRjsDB3CrVNOEHRE9ufC0
Thanks for that.
The finished Case will have the following measures:
64,8 x 64,8 x 25,8
Materials used
aluminum slot profile
aluminum plates
"Dibond"
Plexi
So again, i hope you will enjoy it.
constructive Criticism and Opinions are welcome.
greez benny
Here are the photos of the slot profile which will be the frame for my case.
The profiles are 20x20 mm
y3mG_QblHtgaAskkOwZOIQHjfTcIal-6GphBMCnuv0d3hrzZ_vLJu_y2fDDRIM5I4mSMAxeMvwP73g7v3hdLkcFr6rzCKm7X6Oe8tfCDJNKk3wmAniQuQyBTMrqHVq7y52-6qZdmx2U6fGcZl8KCVkpKvEJWLq1UaaophfqtJdBEb4
y3m3qbef2MGaUYVN8EHtRfYJvtA3cGuEGC1uoT9_arXkOwVs4gN4jibQzHTMPnhyz4UhpQSf83cQdulo9YpFj9BCXqXu3CvgkgPYfDA-iagupKWsLOO9POkmpLvsr5ktYWNFgqG3tYZXvhNvPPDB1x2ByaTcM2e1yMv4z0c3zNQxxI
y3myq1rOFTHv0cPrL7VMObpxrMyd6yaZE4ViNTfOiGuiYqf9wbh5cb0rK8YXBDfewwTzgPvrhz1ue1UGOUK1ISUt-NbCNTezsqkCPH60pTYrK57Itju3xn76MTNkxTcWxBUErFFVjTztSo2pav770skf9h5TBbRTrnQyctr9sXHe8U
y3mA_0FtvMumMwX2BnvmLwZz2nGOwyp-FhqDQvAHSaNXK2MloNf6zmxaoMqPvCJ-DOOyJgzmoFo2z2mPlroFGFGhCoGd3KyCMFOsnaKYMWXr9WTqhJF-hzYpAhUoRSNFa44C9_qv_Jso3g80SHt-gBvxVnnOYBcykk0nsNKKzNLt0g
y3mHW2uyNar9vl3vrl_nsRycVw48OdjHl9m86A_yTMvfeTvwoNR2aFJ3qUw87OC5E73ExS53s8CExtJY23qU_Y7EsaLoj9hCUCjXsUBU36wa1qAE6WIIkm80R2J40KS7Bf5yQrO_iha2ejRJZpI68htE_ungkcxA8W7qKgFgc-nrb8
y3mvb5VgQrp1fThTWLTWN2xa81arxP0_y7KbOVDn3eaY7kPJBrEdJgv62fpFqLsi7YyFm-woDwsG1j2FLylU514qLlbGeca0oKXKaz9vyGHRBWNKp5Sf2E6CdqOf3apQAQHI8pFPvziJ-2dQbupJbAdXcuBrhWiNUIRub4JmXn9Jm0
y3m9ptJug6eMrpnQGmjuABe8B9zBt-AGI0dIzhUfy76hc-054ZwID2eFGVK3EMl0EUO-ON6S03l2xq4RmbWVZ4gM9KjYn2TnOZcvr4zKllyUPEXdshmgXCAoGJqyOlW0DUnByChcwktE9SI8W76s3Q-3enqkYf8MvRDwp234c1JrpM
y3mAVANxN9xb-PdVIVbl3N7a-QxHhBCOWU71-1l-YL6ii2geCJKb4UKhJCGul1slnkgGqw15kzHCRh0SxQuDbn6IkS_LGJ7ugRI4l0xdKY8iUudvN_-rguo8XmaZPsMXAprNT-Lj8LgNnZ4mpzQwCR5uFjCvmQB2moHWA9yAfJzEic
Some new pictures i made today at my parents place, of course i took the chance for a sunbath afterwards ;D
First the assembled frame.
y3mQ67hWwtmiTEbkw1MBvnE5XYSUGIBNTL4kB184K00hPKUth9C9svrPk0Qgz8D_KuqS2HQtQVoaVG153AQM2_yynXNCQ7aV6t7hM98Kii0x92jJn5amhEGXhh3R_IMI-cSVOyCEGwbZu3NBc5UzTnPZ0hk_IhxJ6nscZLFtT-90mQ
y3mv1fjMUg0M_WpMAuFFkvtS96MH43dpNPuNNrR7FxGS5rE_BJKWkmwxLG7bWXs-cGqJLY3r9cGiV8yNoNixbm85D-9TN2RTdjMUOYvmPXdk_L8aoPUzqHZr2dKVJAczL8HpCZtdXSM3cmXj_IC6VJD73mchU2KJvnJXrPcRpyfKqU
y3msMGYfBDknzECYuG_FMBQFXTJV56YzZ9BMh3GeVIKLdXBL8ie8ZOblPjAzL0OWSEEJWT17s6lX5gL9kWsMCk8DRo114TNmP2xqBARq5bYno_Mjt_LMEv984-VA76mcEH_IQOPpBn7sVfrjLTQpk1rhWQ_NVHJa5oSASLdg_YK2CU
y3mb-CkTWgs6CnuitVtU5fXvbiufWKE1L-9rtcRe8FHkY0Tr23MDjyy0ab5aaUqIgpvigPPRF6bNPk6PvfgEevUHrp-7RQNkp1UAngudK2WBfHcWbk5Z5q0rscIOBBs0GTDSpySBMAiaFMLIE6Lx2Bju0Mp7c3H3WZcyoSVb2sN4V4
y3mm-NIoXxOXDo3oOoBJFk4q7Eluzc6ZGto20RPg227-UbZMGbdZ9BidaUtR-71oaCDKZv_Pp2jp6oTJjNIC6WCsgArBcrHgOpyEchy7cBqrZfYSUZy2Sd4wPHquTV0OKyVvQHBUflggn-ZsLRVJfpiP5SnQhdbu16pWZ2n7-jlFHo
y3mPMf91JJ2QRnY74-9z3_sqkDxJF_lHu84XXuMOoYycOM1ZrlCDMyFopj9j8JzEmAjG7m9wpzeZ8EtQsYLGbecr4VUZWWxHhpRAK5UzdAH1FT0m-wcOwziAqOkKwkZPOch_W2SZ-Bw028axnxgk29knYpEQhAIWrJdpFm-RuBTfZk
With the plexiglas and the Dibond on it (of course there are still the protection films on them)
y3metAcv-o1vG4EWtNpjDkBUztuIZ0Ts8BnH5-W8ZGhnYrBsjaSf4Fd7jxYvqpwL8f4iOEZvGHcpGiSdKnGZqt9Bv149QGbE0sDboef1xARza-AOp6xF-32eMFoKCkrjmOM_k3AayeScZpmuCiVIT2B_7LSjrJdFhe6R-c5UgRetP0
y3my_RearIbiAR-zunLE_v_LXUb9k76rUf2koYwp7bSbLHDCmdFWJb96bMwm1T7GouUg4qYDEk0fUyIUaQcOqOIfAkkBIC9m4spB5fmn1YMie9dkm6fo59Ubm81lUJPOu9wN9ysDfvnHMF7smz4VqEygK1hC11nRA7ZT3AEPU8uPPg
This is the Dibond which has a nice so called butlerfinish (brushed) on it
y3mGTwLBsyXPlCu65QvFhJXVW4okiXbS-g341sUJhb0ODdJJlR3AgAE6J1tGCAz8DdSdoeFdJZhupnmMTX9-FoyGCUjx67vb_ueqVg6kYc9CcbKUV4F0iIogxj6H6HLYRaBSbgIZ54rT7-YUU7LUbHFyyODxpTYMqFhJyrBNT-2PqE
Some countersunk washers to decide which one i will choose.
What do you think, which one should i use for the outside?
red, black, natural or titan.
y3mMx1mIfckqONaKvNj1iXgmxyxoVdnwa-SgZDozJ3c4B7QEn93ZsXlEv9kJv7TXZmWOkXdG2AffSBaqQ2SxaBd09heBIP04NgTzycvObFfGNv7-v4Qjm9UssYazs-Iz4LIkFYihL1OTatPcSmPKCHKzWIB-4v_lVeIwU49eUyjLA0
y3mb5XXaKJbD5jMlBO2itoltaqCFq7ClZHHK8P2PsnS6VfCPTxt91gHUryuS7-yI8eVhoBOXvN-9olh86WiR9UDFSovp7g2-mI9Zm-bhradBMC4W5haGNziMg0wGfFBWyAESb-Bflu4eR2UTafyKjyLM4kxKJR_RGhoHmSZTDm9PMs
y3m6W3NSLoPmLACTwyqJJ0JlWoQ7DCn-3YMq4uAakSGlrwSa6pyxgTW7ekjdKwWxBgcejT6CXMRJ_v2uB5v4JAyCTfUwjqyYbNO7lEXoYIaVoDzFDmtLXabcaRogZWbwO2DPgXZxjH1dnYSoYmvwopJvSF_CY4biTktmJGBX_NCaH4
some different screws
y3mFlQSRrA6Ljo0xZqeDqj0sNzDsOlayoX9_JJkPc7xdPagE8w70E0FRD4zKnN9zSgNOKe1LE0PxMkOEk4IzUmdGuKb-3AQ9QYzQgmaRBYZnUkTrpqRS_Bgg3AQVS20_EqhxFdoAZucKXkjT59oMHgQY6nOHMHzQkNfiAemr7eWztI
and a Cablecombo piece (also just an example)
y3mhTO6zYuhjMX4asP7dOzykWrXCoXJuN6cL9ru6W_es1nD14RDCuahnXSB-XU9FHGykHiqY6YWhX21a9gnoBeBt7lq_JRzzBM02_y7BG3L20xihf8vECSBW-tKSZuJwQWeOaAWE77nFasPXdYKa-hKzDOE33gv4U1f0atDea80_0c
also i went shopping ;D
y3mZwN6VV80a7VrqdbITQNIXObpSkrHicb07ZT_U2CzYI-Ke4U0LpfuNCFf9cgl6HCIdwyo4sw4NIiqMYZGGXyDNw8zsmf47D8TTDwsIsdSBnpWRLJLA6RhxDy3Io2WxTi1kSxyfr67a9dr_YyRmbXZqd8OUxU_dwaHsQ-5Otst47E
and my Paracord for the sleeving arrived =)
y3mhzBGmghTP6WzBruZ8JC6qQNwm_ltRRBksuy1O14ZZvZAkJZnHx5LJ_-6MEoNOjHHg41fYnUHtQW7o3TrYVlGR2UwJZumMbgpxNoBB6u3yYg-HCHrgDKTJMh9ZVgPwolxWKPcQWOCZ5QEKnhsbU1kByFeqMDwRCi8WvpbDhH8Nek
y3mClyrpaZgx7rFSpt9ylW4-jg2oQvF9D7CyBOVW8iGwvJFWTQJSlWaDNmP_KQv3jMDFBIMxwi1S35DggaVWBA_NDE0y_KBuuu9Hjo0I3kkcP3zoFVeC0fu8UOEpp36elFvD6V7Nnk2bRclNOU-yZn5pC3lmTm7zVvbNtULamcKbnI
y3mqMn2B5hLMlpLUPnQy6_aQuftBX78_5JbMH5ejS72OmsTq2ECoRCA2wPpcezdQ5-bCnBYuFaZ_bzQlhoD1IKyxtOk049azgfjBxVS4w28ciciVywIqZHSIp7I9qYzt8eZQrcpFAUPtedYa2Wrh3xG6jA-fWXorjvDrPDHzKe_7CM
stay tuned ;D
Good luck man, love to see you incorporation those aluminium extrusions without them distraction from the build
Thank you =)
Progress ;)
i got my hole saw with a 114 mm diameter.
y3m34Q9oB1uFUVylLSU9wsRrgQ_b4kqiEJCwdH9lZZ0uh-PqMP2HqVJZtFGN6W6mFmopm2GEf3sYaR6wq_zw0vEJoZR1M7Ca8r5nHKwZHYSha92SXrNYN4B1xm_oOCoOEdCe5LMuGbkVNP6GCNKw8LYOf0smgz8vx5duS1mOwnyzMc
Cutting the pieces:
y3m7PmyA8ETz4WFglHh_wDDLSr39-1SAS1c6TvFMtLxDw0EuSA3YgYls6LDaCFz0Tc3YBJjW6Vn7I5DG2KbsNre-Zc6IAVslMb3vjOqe_STlX7tmP7gAuU3D2j39tplZv4uepjaNStUhDwR-4kAo64Us9TEdHaX6W43eTF6BHLw7rc
y3mi-YtNQDc21GqIXUvJM6hkV-3AROrfswZAAirwXve5uipoMXJNEygWQ4L4KcqBplFvZIagU3UElOj6cKpmRf8r6rVPBpP2ajr_lJwuLgEVhagypm1B6F1CVIDU4Yo5gxDdB-WnI4suLz8taPBBqHwRBtlDr6uqCY5zJPknbgAZwY
Made me a little helper to bend the aluminum
y3m97E6H58gfXbILMROvTzgK1ts-dJFua-AR5-1B-At9rNFcVoNEgfsgN1ytr5hLqv4f9RoasnGYs3WYv2hisJO3u1sdYtFUBw7TVHdfdLi8qBpXdc497CTjtb2g2YvmwHYOiS553NQp2IT4aYr6yCRYrgvvoTOBmoudHZZx2XrDKA
y3mQyo3EviTxduY4mSNyfy4vOEkH6tVEHxBLzpDOiycyUz5zoD2h_q_r5jMswBB-IG0eqj-Bd585-1fMvvnZAQxNW2lGP_Y_np18gX69U-0EEKGIh9QiiLE_8mFEWlzj58Z5Usv-aoSDb2TDv6EYi3r6CQ2AVAqABL7M5J4VgiI83w
y3miVjEP0vy0cCH6vxIExYg4Qbw05PP5NyPGcnS9Bbi1SW2UgPP7WEi2mdGevAa9dsIpt38kdJFxiuuPakUNcsAlWv-VrPfkVP9VkJgN6h4a2WYiuNHAnIURB5QiHppUGRiOA-ZrY0oD_NquoNpXkIl_uaEcqbKMzkLKkbpACPtJlk
y3mfe9qhQ8zlW8EfBzS5AaNtxNZBnot9PwvjaoCxi8zeCfe50XfK8psSDW7MvO5CELBBAqDwH4_5qbmPviKZBPMAd4v9t2wP3gAz74axN8bt1m-ecbdha6D4I7sezruHisr_IdEoVrzpZ8Q_jG64tEoeIwenv86FSSeze81gsB_B0s
y3mOrQ_an8Fj4hZYdx3HxLDfnbB_KxpSidmGKWNuaCvvU2Hme07FaW8Sax2_PHMRZDxotImT1oWtpX_CEnQ25-zuBtk1VVIWhmVsDyXwXBZZMPBPy_GRD2YT2jNnnv-zmNbqgoM9qP1UcWxJ47Y5EkzVGHp6FolIOMOvqKp-oC4BAo
y3mUzPPlhPqWyhzPEdJ6mww7pVIq2PzPRmVkZM8TmsQUYC5s5cNdyf2pF7L_t2invh5EhhmmfK1ImXWzqn9RcNVYjs5n9X-qnXLb9h__-Ej7uucN7ii1KT1yUo-pyRiGYb_1xcSbBCnEuVzZ5QRP5jqV7V12AGQjMThuwh5Y3oSPr4
y3mcTfsPKYN4pee2n8yr3L_3JCZ7pxfTP-GeRSGd5z8ERv0zH_hV2ly9rZtSUsYmM02qljrhbuY5CA6I6VQtMxhb2VrBKV9ARYjFP8WYCVObzto7HM8oaJgMFcRWCGFl6QHUTtVOUwkjchzQyOi9j9Uq5EKW11oaQenEnAKjN5cGNY
y3m7xTLafk4XkFoKl7dOUI3Ygb2qdMH8R0QU4uBMfmtRYAaoTGHeUhC88Fa19Ub2_OSa2kr6Usmt_VwqwuMAqwpNQQWwsYrtuscq9pPeQIiSCAPtuMxXfwascFOeTnSPobjXlpLzmelgE07CHPTlDY8wg7uKl2SujNxeSi3aCkVY_M
y3mzhNYrizc6IZe0hmTiCjbjmmXRJXJIXHabD-MsEow1uwddQ8ySdm1rZgi80afbq9o2kO4imuvn_ZfA9i_7vhjWCsGBV_AR4yz0y-V3qWPHPa7_0bZZJM2d8G-0Hni5uVzO8wlN5fvwmSNz4EKl4yPcHZi7b8anuDw4CbYYai5314
This was a heat test of cellular rubber (which i later use as a vibration damper)
y3mqK6G8Aiwf25fEyNAlO8T8BOUl34quby9YVQuutRnfwL1goMYf67Dmvdb2YfEZg9_aNAOXnC9FhZUaCd9sYThI1-pTzyTSJGNDdEpt-fJp-K2vH2BRa1iWIwydAznrwDCH5FHG_PF5qHL9MeixMKIDj7mQHEe8m0NgVnROHRr4Xg
it has passed =)
preparing for bending.
y3mMismayUEOziDsZdYsef2iW8jyUkkc7QWkJ6KGBsBUEolpPxXE1cwuPr-VUQ5XBT72OIaODPx-KfKugaYC90uxjJG-2j-Sj6jQBHN8NvU33Yqf3hRQPbVPO1dhinTJFObvvyVjuZ19W6Pvf77uZ1mbFirEDVcrck3-2UqBYjNuiA
y3mwkLxC2UIvxJV-y0W0cL5WEqdpXW0yrcN2cKvrtMMxWQp9uFa2r_Axh-s90ktJegtf9giSbQQoJsM0B-yxK7ByxRDnMzrczYzhZZ3u2YrVm4ltmzgjX0ml3p9S2PDwyYMyLO01GODm1VTIoNgdjtqsSWqbp3G7s-Jp_1rM1sVfrY
y3mVD3tZ3qwJyQnrmMsRE1yTNndCauCknroRg1gd8odRdC7Xea_LIlSzNjY5sZDk1poq8NsU6dVo2eRo8MG-tJsfJkBMoHU7RFWLJVMFPMv-rgo1KEhxKv-L7F7zPlbAcKIh7aVeu_FBC1PkXlZBhjEtyMYqmRAAyqyezVZYr1elOI
see it works fine
y3mzT72UbI2SVZxrsFaxvZl29btkgNcXpoy5xOh_FZNCR7DTBomVNAqD-PXqXjL3hT7t8Fu_nv8Ho1GPU7e7LMu2OhqnUKwaLQCLtW2KBQSqm0SWJm5KTwEQL0etsx_-1SfrTqJDf8oukfiEAzNmtYIt3d1l_9xebbejCtVcknDqT0
y3mGfwEAd74UJvt5YfR7SHpQzLnns9akiIOSlfjAJdWw8fJNBCfaiVKRiU3kLtAjX9Jveknw6O292bzr6wvUeA2va0sqj2VXo8zmLhV3HByGtlzX8jGU1HVi9uiPiLcnQVnhpfCynjq3QYaHEfNtEy1iUZ8WjuJbkGCgby5nHgujd4
y3mey0qV79jEgZeWJ_S7llBJ0_n67QO_Jy-dBZm9zXGwfFkx58Rx8yjurYduC5mm395lizjZ1XWsaT-a0UY09jJ7E_MVPZsJhCv0SOD1oYs6C4yGJRuHZ7VenhQr1BcJWQPxZfcgjV-0nWl62hwLgVPMB4pJKeLI5lW0sm2lGGa1DY
y3mTSRHLwMiuDXuu_0OSTyrjZj0x5glLaRWTPPY3OCqXKnQSa5VDIZCmsoDyySQm2NhNRYZVZbFtTEX7jNKGktSij6HK09wbrMmEWlknDEJ7N_LyG7-y-1qIeBHxDEWhOySIilQXbygnm9HTl1YP9UaIdpbsj2lhmP3PmtTP-YqAp4
y3mXcg1Rwxl4W8z8mbMe07IFz9anNNeNEOa4YazusAOSe-EazWQMfe1rXf5gXjIPNj4F2T6jsko0scczsgCIPr66R6ONlDu-UYSkmjLg1oxc42GDmD0Ka2EIYPrjMzTtPWk2FqI8YKUGmdu9Q39eU0rnHXOVMr0qoANu6jZy1_HLgY
y3mJd4K2v6Sl_GY8ZDHdGqU9hRIsfU-YTJ3z_lF6FTfiqPDUqodEhtIvC3BZsBgS5IBjg6SHB0CHUnEC5XfTOOQxSsRmrCxx2UragT87qjNR671mX2y35_iVxOkpCncQkkhN9wjdV8BWmhrtBrofBXelBPdgzkyoAlf2XnITebKo6U
y3m80KixNaKdFW4g1fe5EqXzViLZuPDMUfVqr3Fl4obvAlN9nABA7FbzC5cGAP33wpSdsuQogCGTqHOYjnt4ygVmUvy-hZO5POHflPhmkXMeLXD4sZ4MVKdoFIPNdvbc5LxHA_P1oxFOqscBaZCHQm_8o5Y4k1vFWHx47d0-KplhfE
of course i did the other side too
y3mwdzkSITg93nwEv9c-cxvH-UnShBEbOya-Lq_x6JjsFAWfPZquJobtZFe3s_GxbUVpqJ8iNDj1qjpr3MtPGNiHD2nMx03J9fJwOxLy21sM0cotOwVo73aQMy6CX_PMeiJJL-tvrr219ZW5NosKkP9rorB8Wr1ekcZLi8VHdeLOTc
y3msBbw6gkOqfwX6jEeoeNijXzSEhI1t9YwTq8u0DBNKDER4f-t6_O7NgcmvsHgOKiUYHS2G1RBh74-1t7cxhNf9huCrMBIcrSkuxoS_ipjZ5mjLErzcVtgtSHUbp5RDtx9slQBXn3appvtdTLDjgbzi5uTIHzexXtLmzUmdhbUVXU
y3mE0HYXHk2VmwGjnQR4WafD55IiKfy_qgnbT2bb4p04dEQatKZ9HisFuWfuYi_3msMqR4GfN6MbeyzfJAXJg7uHBnbVWupmthQrvitXokJI84xu6m-8EfmPx6ZgKrVdSxgTHxt8gcnzpFu8DSH5p4szfZlvIgEf9FqjOi9fxW_fjE
y3m1IGs1vZ_vy5JFZf3k-0uPHeNmOVE9YZkQA3-ndR3eUhbG996TodQaHbv76EWokPq-fFVOqBBFt78x5oEYi7bYwANf4wtBepYCUK7QUi78a7aiaIiV2_42J-6Z416WyHUiq4fUomtkbeNQDqu19eNwIxc-xjd4wKX_Pgk0IJ-aNw
y3m0ZK22Y9kpIkgBvqSsMnHO0Ko5NEJeaBBteR6VjOxI4UjoN93aAn5nVOpKGlNfOcgABW1hTcohK4EFwGEUzmWA28tJnduaDj84aadmT3akaBcfQhMH0rXhZFHH4c-hK6xJqeKhYpwZ1qA4ecCb2KPHET0-aUaemfFLln-z_1R61Y
Sorry for the the quality of the last couple of pictures, dont know what went wrong with my camera.
so...bending the Dibond
y3mT5fNMpjkxRHy-HCUXCM2xKG3qYLVKH3gNL6zVxzAdqnmTpinliX2s470O0vg5Qmx5OlLWPY4FQpYE8bK0ZbkC2slBJ5WcTSdum4DuOcsaAydILrS6byVTt46Ehcw51UO6Kaww8LrGZ2XopvGx3Z-B5WJxy1j46wrWjNf5a3zWSs
y3miD_fplGjT_Rk98pmx5Zq5wZ-g13Uot0yD8SzMy8Xb8JeHsU1qDJisOQ7144-Z7Fakw9f7Ocrzb1eDu590ndPKfTeZra2aLHxg4q1qrwc629YOttDWCSeY0Q2j2gX6HIifed0VXNpQNlO8INjc7vDqo6y9DaTW2ETfnjgoGU_u6s
y3m1D-DlhFOAKJ6RVDHk_n9owcOfRgW3Q4LHp5IouC4X1Y_y5jaWXAi8urce9D4jtWo4N0NiSC0ww4Bhbz2fxUP6Wn1yKjF5H4IwBeAeO81zUsUlWMB90SzM46suzhcBegisNAftZ-LwH2YQB5u8kN-8bhSWoQtOZqkL_dhBqv9EmA
y3mB2L8jXRlwz64gjw8k2tDyQyXVGUJ_cJ893nhrB4Nk8KBAmWZPeDHdjNYtJiE4y8WRUANqUFUF_iQ3zihHBvyJ18Uyp5Xo1W8-YQBJ3Y_9MKyRbiFZMAzOFq-ydwYfx6VM0a1OtSG-keMAwtyIWrKUjoAXpBxn-f3NLMDkwEMRx4
y3mShwfNrjKveaQs_2O_OETctcGV7niUtVYtkmYXPT1iOZSKIs5TaDwsc2lUEYB65fczwupZu-lzFuStuIMD84XK1pPZjxARHddCtF-wPDJQmLmvjJfW3UL8X1cwXpDcMsBUFS3Dxq8RdtOh8nmbh0MXGrOY49Te8CQ_BfX0m7TadM
y3mqNVSLV0AgfpWhp8Qsqka-XB8iozPRepQ6QGmRdESRaz546tjqX6F0kD-u_FF_Y9hIDFFlVMn7Qmdyo92F29vTzaY-8MSTbQ4rzimUmKuahK32xOVjQgKEv_e-oDK8_XI_DtvlIC3xBQ7vZEmG4Ih6m1GDu7WyltxD3oWHgHmaeo
y3mM4rvkErJPR7aPhvH88plf0LZ7tPFZyb238DxTwNeyIDsbpyLDs4O1fKNIrIIgRvYxYzr9FtO-DZ3lBLaycw7FpuJjghDRkoLynWUY4avNqEUJkFecFAhCJ7VE7zZSujvfIGgLm6VVrOrL1z5JhGckm1g_iED9ErsZGRuqJRF1tY
I failed hard at bending the other side... :(
so i will use it for another part.
Now i have to wait for the new one to be delivered.
y3mnm1y80mK4SSCFGFND4CWJApdGbX2IaLbKvDrhuB0TzjK4ppmfKq86EbO8iLyqRQOJSTWDTrARi77fSFTTz_NqOb9ToCDChXhLNbNpAVv7lT-r_CHScxSkkSDcOwd4Bp0et54fYFweLqMgdc7kbEv0yvVAj_P2YrWfqWY01EvTRo
y3mgQd-5ubnWuVaAV4GGhJOWI9hKdxGXmz6ykMsIulm6Ek9LS28ZWmad3EJ-wDV_TEBT95-5QkwrzK9b9lnB-cFZmiYu7ySX8RIKOlM4oLsMuxuM_iWs58b2WUtG2P6ZBYanOGHcqrhPeUaZzwppapPxbFPfKf0uXKA5y-0XTXR4fU
because that pissed me of i made something else in the meantime.
drilling holes for one of the top parts
y3mpax92ta3jyNrEEqWpGKIkrIR3kS2n8gRqe0o-gvdhxDuuLiTwErLoLlKpkTe7B6OCSFF-i6fAAFSVg4UYTVIhicy1kOmuKnhU78ToGBnTSSGwDKo0MfsqCpGubp2TAi9w1yxl3mPJZ_MkFizRiBniOVAfjxXfDS4ClYPtZfMjoc
y3mi-Cw3wHt8TAquOK5Qnnb4g1YeF1jOmhvwPMgzZCubRzvtmnrLIN_9eeCDH4yizXeQQQUN-FID2GntM1X1cS_w1D9qItdEEidXNE1H1hf_CRzV2nVJc3iUhuQLFpIxBpeSJCxli6hyUlJxAfxPR15D_TaCQ6pYzLSyuLS6ysQcmk
y3mgaJvILEQkK251bbT40-L_bCYSg63RALaXMACzK--IbNGjxF0q9olrYBr2R2QUTfThcuKKygscPOg-OEVUb3OonuZ17A_2N8oWoK26sY9CrbiYeEzRROcBcS_MYxTwpxIKhJWa7OcoqVrrUfi9TJgLQB-JPNkGNQGPERof0dsWSQ
back to the other ones.
y3m121au0SMjGbSlw9aUDMW6XODom-Olpw257CARYLegcm84iScFjSNQGoRa5dtwLu-i50I35BQXju6P84DjtCfHHSmL9j12hfFAT4JWRMZoHjTtaJODc4v5SxZkE2m6WKY5T3EMOl7MeXyuY1ojYe1cng0Yh7GaTlQOUke3KZuAiY
y3mC0GKMl0CR9sjpsmyqjckEHnf30nPEG6SqLa9QpxlGFcjmgYCAgKq4KSf3jZS45uSC8Mo8dHfAab67-UFi28iaXSfobB_vZDMWgX2UUk3tv11NmiQKpCxwYi6zr7GLeQSVzcJQ3doL464oRtNjpazHfe9NFdedYUDBYrQt8xAzEw
y3mIEQUzWEeTVK64K6WeOALbBz6E61tqCW7wQU5NbsFdBy9CXSyPEPdnD_1JALCinSj42BsHCOsrfJQ27ypSIxHEV-sxO28Zr8YZLCcyEpjqfWnvi32UEd3siMb8tNHaYPrA3rcL1XAJ03yPvAv73IRKcfDW9qxM66szXoB498naEc
y3mJ7Diz1RV1AkbK5u3ntwQX4Bd9DNy7fFS1ahGuSftKVR2rkWERjWlzusMFjdynJJYfuMSf4pcaqR8lVT10RJiDPa5VNh06NpX8zeOqA8MsAxq6IVZSvpoqmYtSPylVRczI7c3N9zof31r12hd34k9KbmQ39Aw24xIRYzQmybY_Bs
y3mMlC38WbmBHecP_qzN13EYZdGBFpEzBbNqhYceSk3F2WDKekxTzmixb3vIuNwxJlh7gck03Pp2fE2rfZeAESwUk67g3hQlxTBHWh5e4Xn8ocIubkasEppYSvaY16oi5fHCTLsh42Hxyk6rHKeKIH7HuDrqI_ggFFbBjOB0RGbbB0
greez benny
Well done on the plexi bends. That part would have scared the crap out of me, just for the sheer amount of material involved. I like your simple solution for ensuring an even bend.
Thank you,
yep me too ;D first time i have bend something. But after the first worked out well i had confidence.
got some progress =)
my plexiglass and the new Dibond arrived.
y3meWchODQk0SVLCM8yaf4x1s9RbjMCAdqIqbXTONk5ooYOZhXT7xHm7GBIrLCvMnxqeAUWF5cCPZ0nJxqDa4Ew175KVoXeAeoZYWhaUGKNPcuM4oSZHSjLASnesmbLlUi4DmH9vFE-vIT6p3WzhiakETBVsBT5mfP2hCsqIpWwO-4
y3mMOaWOSk1Z-S_lm2LbfkYMQg6UJ1GBS0zs1gJ1UpAnNjZBdZoxLHLXQCL-7CkVAEJ81xuxWQguNECMEIR8xnKc2TO5r9TDfRL7ACfKKO45UV0NlZDUSVxiV3D8Z3pjf-f7mHdOANynfG46yhi2yvHY67m2m__Ks-N8zK7b0IaCZE
The cut outs for the bottom plate (black LED-plexiglass)
y3mitdCHfxcAhypFsHc0KLIm2HWswlkVBA9PLt8YRHlVk-Vsi7KxzV_VNl32QfX6Pcv_tqsGyv3-llTAedyKTXM5qI1b_aLIJPrjh5Lv4h0y_21TiFmb_6_2dz5MULa6SO4-4hW6cIgzVbeOzxaxSCYGAhl_okt-a1TxqsZELemq58
y3mbQcoeCWJ-sBPKcH4R0QoL6NSaSVUHG4fAHtRdU0VEISOLQPQIJURuIQeB3bTz2S4Zs1gEpF81ZGK33fww10tRUcDsK1YmoUpJ7haZ1Wn3GxgyynDNgYmG-SWxbiqjZyN0GLZxlDaC9xonujNgTpeVcvNpTs4QGzNeS4YJoPRAvI
y3mPr3LGJ75VYKUyr5LdWcCYDee6y6yB6Bogf_Qce8UncRZNDRmNzpAoaiA_mCu-l3c98g0SPnE5QDtzN71vskYtIdqKdckedL_XF36-x_TAj4k6EosT1X7EOzJLkBKw5sYvyxlxiLXTRLVZYVyP2ubCj7s2pUlPerWXl91iGD305s
drilling the holes
y3mgP4Nl-J0xCkV3yGl0AYNsokT5I9u7u5BIVdP1vo58K002ER4cWmAZb_f2SflAcK750oEiuQjWtyxcmOnK0cntnzXX5PZKhOcNxyHmPV1BHfLgdGZve7apdEvlvKYTGREOFRlzp6p0lh-q5axNdgo2QwiGy3whvUujh5HToovPM0
y3m9v-_T0LXIdzIO6hUemA2VOINfgDe2cmLdCsis15Y2iXCdZOOhrQ9zvqZRq9aEbeI2N4UR0O4PMm0xf88T_ke5R88TS62gOKXcoL2Jaj4d5Lzy_5faSswXq4qqaLI4NfDOm0Z5HxfP3nM4h9NG1kQK8-I0xKuTqW3mw8wRSALNbc
y3m1YCg19H_obaqmZ9XJcdewU-XsP04nGz8p2NMXd-JEh4JuF2nPV0UOLBo9qqHO6LQqbWSAfRT69BwDuol3YqPQkpKqXThDZuG5pCXUmvrwXFaqN-s_lzxNLC9_q5ulrvrFUd4AJzD7g4U7S7d8Bj6nJMksGtON840Xb8HTCUq-1c
template for the rad and the fans
y3ma6tDY9RzQxbxDrv6ZKrSlyVdXyA6zw22tclTMw7oQJhVaN9Dx1y7jfkRYjcwN1kjgb1urgyOhE0-z7RVbtPTduU7GpXTlp2MXgY5TMVM7mQapMhd7J06tvt_VxmG_E_8bIk0XNGwkxL6GzorMR--AAsyvTyEP_gS5wjYNWbV60Y
making the holes for the fans into the top part
y3maQc8qLnk7Xv_oLt0FMZGB8Z4MItVHq9Cr_C4-6HmxmUc8zBz6t7SK_9hgqVwFVBvlBPLNLKI-TAh4gZ8mzHgI05gnzqMmL-nPAse5whFH0tsLazo5RdcpFj3vusWPWJAg-jwGvtUzXAUKp2Pxq6hxNadQXrnEvRvOMLYEscydj8
y3mEKEfgvB4jwH3hcL9M78u2ftLOwWo6-fJwif438DjDwTs64dqjfCFrecOI3K0VUljbThkQFAMuK-X5HTny9LWs2kPNteB1PpObXMoO-WrFS3jrDsnsIf-SBPZma6bPUX4xjfY7MSIjr8l9kFIqroZDB_D9hu0Nxkzmw8GQ2EohpM
y3m72rvoMUcnOD4LzHAgfymPQrc-Sz7R7VEOrwpTB3a9eyiOROY3Z3njLFL3CsVxG4dy3QbLgTQKzXww0IZtKEQvbqAjDQYCajS9LrhH-I0_wMv2mPR51ftlcU-zfWVWQDlOVDxouw_NL4o6XfIFaWNJ46P0pIIX39_XueiigA0v9M
y3m1PxgdB2uKPoUm-w4vcXw3o_I3izbXWgimqI27bShmg2q3diVJWgYJAJDl0aixJ7IM6S6s6mJWnq0tWzqx-pqB-qsMYC1y1RnOgLHPmv4Bzu48T2LazK7xN3IBJ9vOG7DUMicg16ZTx5BfsU6Yz1VKi1oSwRUePtNt8gXueT71o8
y3mlbBn6FxGp_05U03k6ZFNbrPO-FELJ5yI0e2ABSFTPOaHh9nrZWvcAIcOBjClz1dhh2C-5QkHDaTALhlS5AvbZq0C-e4PM2EpfcQWzGbUlbe7cXKc3Pl4DzVjUxbkmdKFsH5zAYLUgi_vpsrSMWabcJg2mQlFCPixKErUoqmuOOg
y3mrfKZUEwGXOJOZ7fc_RViItD2nfP3u_wICpU8lYWpQAMfz0ktaOfr9n_A8ENf2JSROZxLpxTMiMwOMLWQZoYJnMl3Ugygy-ZmtkcUwv9VbqD0bQCA0TjPobuKFyGu9aj3IlqWAZGnnTR-CANqNDalFwnSLR92CCbD0Af3MtbZeSs
so next try to bend the Dibond from the other side ;D
y3mYqhaQn0qy_9D2JR5nuC9dIcEzHz4_4t_0ta1brTC_QWY3y2t21I-ka6oVFe3s334JUTzYqJ9_rfyX4Z85y2DsHUvVemhL19FeQ_FHDtM_wtAl97Wq6GJEPK_539_7MiMqdDgdsq4q-Tt15TiuJLcUOPbdHmMrQ4dNqcaPaA2Hbc
y3m1YseKw_1az2SozcQ4ZgMEm4uytv_vHebApVBC-grf9xQfaFhqh_5cilzcjPhUxSoNdLIXDP5X88tG0ZhvDb-Un5jt-zbjYu1CpyAsts0iDxclcSdNhU3m9J-YSyHoYUnrmr_X1JQznJz_ZEWuLAwgMNRiT3eHmLSt08rflKiF2s
y3m8DkWCqqx8wPsNpMMbx2hSwOsk-iXNjX54gzeNKcdX-7IYsFHhqd6krRTdlqdoSZwol9cD_kjvkFzph_A0s-gu7R4EoringdAikapd7XmTKqWQB6uWH52uCV4qLUQNAI_ZpD2AtTQoKTq_WILmArZtdgs5nvYsJ3aAq9ViC6iUXw
y3mxRnO1jzf6gYBzkjrl11M_wq7guJy_7Py3mBz4_PtgiHdQiMf-04gsuz9LDwB5Mn5DF2SInKqG78HQJrgf6qwkfHbJV-mqN14xSojZwTq3nIWmsOZtwZ-TnXkPEf07C_E6EgEaQvhiqZgJYnv6s2yhWWLFaemDcVAw6ViKuIYPzk
worked fine this time =)
y3meotU2VaKPwsaqOafjImmD5TUBImhcAIJUd5reJgs4QV7At_iytUKnA5hIjkLKGF2cg89nPVNlSulOFDxhlT9Av-Yjh_SI4NI32Z9udw8D3QRaKS7PYXgh9kq90IQi9mU1SwySVHdEIKBf_zADMRQG952_gSiog8HQVyzFtDw7sE
now cut the side in shape
y3mt2wW-0vO2z_Uc0EwWAIWQU8dcwf0Q5Jg_AbKkhfwadctKZFwfs4Y_UbXxGEPfH0Zptb6_ceFNViKwSobpFtmumW-6v-ZyG92_osWmuCqthWFTPvv1-QxZlZiITk_edqvGWfZGxr9ofpIhtlJ0NS8fkZwq88pvullol4cuhCV6LU
y3mJ5q8rAlrX80LTyg_gmNtwVZq7PV0a1AYITmyVtoPnPsIluCRjoVJzYY0voE4-6K0qW2SyGEPjBA7N9tYDJb8ucR7ZSMam4XkwDXCJmyMKHZU4Eag1qpvZlgufGJaxW5PlTLH9V0QTx2QEL6UjE4oiS13j2FYmfxGUiYQfK63HNw
y3mt6QgGT1y4VTRw8DXgip62j2DK0xGOtm_wuHwEecRYwO_FCO1O1sblYMy6aORuqLPFwEm5coj4YP6zM1frPzJg5Re4D8CuayammxN1Uw-hBMVRzxSdfBu4qwuZJACzIyBV8jk_zi2_sFHoxVCqHQwE6z2xy064yFCVD7D8DwCDSg
y3mBshOTzCm5rPlH5jHlpV7l0Q09f4b26hUWy01cLqaTyzfznJ2dSSsMtKG_LRPFzTbaWCX65EgHQ5OQ5CW2OAEKtgqpRK1xUp9FUTHn04XhLYi8FCX1wdtorqog_QXNNS-L1l3mWme99_k9ekWkisPuc_h3-1zCu3L6n0T4GXc9V0
this will become the motherboard tray
y3mZQUfawemA5DDEyj9inA9QHOMWnCbEEOyBllUWvXwvlKdbZSZar0ot0zli0zLfgFp8L742X3YbRWHgFBbsgUQfk85TkqJFb4z8qbW96fAj353TuNzC1fSPrm3lfW_QSLW1EVEx1-XN1Xn4YTlDwkVbwBMZ34_OsMDKQD3wkS3CGY
y3m_9kblPUzUXzgvZW9aTrxP48l7AEyNKBQt1CwtJvTlLk6A1ya60sTeQmXxNcfafH2RVrHpt6LSzG2FCHiRLI4GL9TkSoTZTfCkCMJDYZPP1m-7se24edWU1dKX_h4BjD6f0l-fBkP-fis2e9SLrJnffoIkSqF6BWK4rE_PzegAtM
y3muMURRAszTgblhsgSUQp1HVOYSoQthFS5mGYqThcO6j4scrxVsMYS848ZzVtohpxd6g5pem1Y7k5nj28kEzJaaF1FbULnbJxYLIm5JtytC14Ly_s8sRGJF2nf4HAom3VDs9a4WKUwCxh6_sRZJyvNPSJ4ciU3AifYKxJJPOTYVfk
i hope u liked it so far.
greez benny
So i just updated my first post.
I listet the contemplated system and made a spoiler of the current status.
greez benny
Next Update.
Actually i did it yesterday but due to lack of time i couldnt upoad all photos,
so i decided to show you at least the painting.
the cellular rubber i used to bend the plexi unfortunately wont come of that easily.
y3mGBiyX6YS-YKSm2OOAwZLm9ofutHt2lXI7zrmii9HliRhmRzFSs39_GRmwNmFNuTr44yxDAhQb8k5Q9rJ8Ow5zjNvlgpHlBWpV5ulYeu5EjQ4ifk3OdQll6DmvOqQX8eMT3XErCkDfCzjWNPkiMTpRfTvMiSrQKU5-jLdkc_uSjo
so i decided to make it a little bit different and just glue it on the back of the Dibond and where no screws are ment to be (for now...see pictures below)
y3mnEa9Tgzup6RSvK44vqM4KuQIND0YzrBCnyfhjtONavKSPS7gto765SAeQ0JM1CH5TP4SyMIR6muaYgZiTgiJKEuqvchNvstEPYeTFL4QJq0SGAGCkGwOEFwFb4j9ItWusI5fb1D3Qpe1WVSQxhUfUWP4hlVwQsqvc4LWgcwJweI
y3mDBa-6K-TBbGTJI_JvAMwADgnT-kl4GlXsuaqK9RPE0ix3nHcXQeOX8nA25sWyi_yJ_BBzWhoBgkZqCVRAA3PxLuBuT8Z9qTTR9znlwUX54hwe_REtbAO-t4eEcTac0txgFMBxHZa1O2ZYD5YiRTob7dxxSrkZ7QBX5L8RD3Qeu4
y3mK3Z_be8BknBQFAMlVhfUx56kJqYzcpeymFTXhxtB7uWxueZ5hiwGdgJOl2tdIyhmb8K3bpjyw-Mqsp1OuTbm6P0DqpsTf9z6E9bBhAmcOdlzSxPRM2lYTKoRgEWCLvgMyp4aAt23rDtxw691XVBNPWBPUYuy-cUX4QHE3JqjNZ4
y3mLo9EXqzXimunXY994BhPKYpSb4WQgb_N2dqd19aNEw_HP_naDbMtr564tM083enz45P51P4BEI1vb2ARFk90rXmttzWfS_J7Vwx1Kc5Xqfd9bE3TZ-U0TkQL9XdsLyufHhJQRdqriGOFXzACLO-vQHQvgVytnY9k7NW8yrFyBxY
y3mnrCRDKYxL4y2ftaBhavzxWsLoqoizmMlkPxcBTtuQYhntrQloff1aEIB9kJEtDZvc5r8-kiLBh-Sal5yn-tNya-r57mZPBW6L9m2obtLddqrn2YzYL756TKQG20um8tf46mSQDKARcF_8gnDtMf2j6MW7LXbLcv-MCPxhT40Wfg
y3mKMOZX98lzqAakL_Amvsp7XvlsYD0OSb5nHyg4LU2juY0LtNGkhkQbv2hyy86irCKHuSyxAgGW5_-wFspbERWvA0vZ86jwJZBy3htobkjWrxqPGYPIbHuWe-pDXHiXv2lcK2N0bLOxVxBlg2tGqoMDp3R-Yx92mR_-Z1l3htdRnQ
y3m7pwCEYk7oX4JxpFnkShS2exJhWTWeYE0-7_oh0DYUMsuU-ounFLlVIfLQicxliPa5td_h6kiHnBnv7mepsM3IcX2I4RL9pAA24TsrRAI7Gd8vUgdnh1xrzDwc8Nf04buU8mytZjDRSwIke-lG7Xvcd-mORz1PPDMAWkfAU5o6No
so now i have seen i have to drill additional holes for the Dibond.
y3mMojoeLUleWhDKOtlMQUqWQqHcrJvIjC4DGZQS7xS-he6rxTUIERkCDgJSvQjvmau9mUekR2XLoNtXI1rz-W49H23KCUFy56r5im2JAyH_yN2UnK1GOzO6Gif90qU9_EoJDM6O2_RVPKPj_JhalFZjimz5LxSBwEILtdPhGyr7Tk
And make holes into the cellular rubber i just glued on...;D
y3miYhYdFox7Fu3pokdcerjbOpgmrhKeizycSfLcVuYBLghwDtuwj9HqkdoRC8Vpgdh7vKqO9xfrgZHraw1UoGVdo43C3g2NgHCIO3iRtpe3KJqsopomIYhgWd3cUS_W0d2NRRvIjFBv8LYTQfVpyr-CpB_hWFnaa8igGwuqMu2l_0
y3mGxIEpNV5PNsk3zMg-Exw1ISfsLK5fhHP4bdKi1WrUl-jC4yaFkcrS3zWLCG0UgHb1f5A0o-EDBECORSkyU62KW1NRouc06mvrLHL2xbCg_SEAWCeSyBBhF-FHW5dRMsOP-Aoc6oFoFaP7sXdjTUZZ_iQ5AF1kmSTHuejdBsF8uo
y3mmLot9dCzHo_DzG46uS-2lSorsZSAePZw_X35yoo2JxF151NfKyMcyO-IRiIyMF0Hnr8jgeGXSWCgPzS1yYsdiIxG2UBRsnoMDqQTVhrCVk6PvVJVr2n1SeNQgr8orAHWuSIPV5RkHSdmuCrWatWnzv-sr0JnbUL94A4of0a3UCo
y3mi-7hVXs8-VDGHloD_2QJ91ON78hgxcrPa6F2Ml08RXTVcWfb4tjPobVEf6NKXpw8ppmqql1HK0rH_vd83TEhpMCupoGgdIAZlpEXltlbTbo6-TNkSCjWd1QK3RG7aHDaOpAJ-aGEZkjwZ8w9kHNBE0RaGDngg7bDKNtrMUjXNHw
but this doesnt work for the plexi as you can see through it.. tested it on a small piece.
y3moCway8dT-lrtB2z2pDuzYRKH_Hm39nrEpVaCJwgXytkfPX8ne1fRqtERI3ZcM-ohjvVt7KCeN66Q337hU-D7tFQqYOr6kgI9YiOshBtx8zWA1C4Ii_YVJjdbYdfmDhH6v7xdIR68iAWOBb-hrw1XcPhKZvXWjgd0-PuAlEa2Og8
with background light, like it would be if the lights are on.
On Camera u can see it, with the naked eye its really hard to see it, but its there.
y3mqaJ8zc65dDwDYAHSKpwTQnXL5zaTb-DN1arGMN0eUwzhNwg3ksQfj0wRE9_E0l6X0D4k0Hh2DfrWInauDh_Gkpnl_39gUd6KIxXiVpdxFRD7eCnovtns0xyQ6jwczHRYZvSo0vEhF8ohDzwlXxBQGZq7kag6zMWHBPs7s8_s-1U
So i decided not to make it that way.
Stay tuned for more =)
Hey guys,
another update, couldnt work that much cause i am very busy at the moment.
We have a big autumn market this weekend, and i'm the organizer of it.
i have new members in the familiy ;D
This comes a little late, but for future projects =)
y3mtnShclTOBXDK3KuZkZxcLN9bspePyHGvmaoqbeerYglVAloVXde1ZgSjnWg8vFvO5ljBRsuKB3oQM_-5vcJFcNPdtbaGmU4dKxSbVrBJaziGnYAHeB9IP9p6r-Ay4dz3Lr5ckvSD1Q0gZB45EifalovB0zKWsX7M2PN59R33mhs
And i granted myself a new cam. for better pictures (at least for the final shots) and to make a video.
y3m_G4J5IHKZ6kEI_Nlk2LYS6F-84w3OIZJSIgUaNvNOH7_CdZOidB0y0CPpcODO7nbEMLPNAlOkDIw07mXsYX8sSANonKTjgUf_PpE9XYxhrWoAx1r1UsUIGBOXQpOY2PrneH497IT8V8rQCtja4ek77Ria9nokSB5oZd3yC54R9g
so here is the small progress because i was and still am very busy.
with the old jigsaw
y3mzy5oAUxdyHRfslgd2OzJZVD4QfzDbHFcvYvkL0X9CgoYdAJLzSMnZoZyw_oTO-dpGqlxkTqOc6d5f2xCQ7b9yfq786NuCJbHm3tCAlrTwA8SN4t82bWSrAE8FXtXLPXz0Fydb2xWBlYdzrHlKXyIXCCg4fQ17KqrHzBQcgODY4Y
y3mrxt7b5v8iMAMCHhJ2kYgOFqta5ZSY2f0a0e3kGPj6RV82mOVYEVx8CODq1RV8oksNRULSyTgsgQq2SkWFLWtQkTBvDaVhWQGRPCswpD3g7AFOXLHm_zAUsMD8D3U4a7zAuJaQAruZxI5_fCzqfpPmvZTBqFE6ogD9Cn7XH2yNa0
y3mjTFSilWOFytwwbKqOrcc-YudxSJNMgTizmEHy0yq08VnsNgbi0N0ppKuzSkuW5ULNy_retB1XC0qWJJUnaKtccNfekNnvg5iP4rm7WygNL-K4rw-YvqZq9t1CKLXdTz7d-076B6Yu-xTPbRsC89vToXiIoFGuPwl9VOekqHS-eQ
y3mwypEygG34pcpOaRaoc23Re5WYm4bJooWUdr9fm69w347b9DWNl-4kerTYCveQmJZZR52gymm3sV9ayqNh7QmaQzSEgnDuKO7giXmWcwc1yeYwogaU4aQC9oGYH7qM4XIfiXx9crWWmE3H3YWJJbI5BEYcHCn-FhRzYqQEqUChl0
y3mPHNMtEFs6vOcsZ1MskXdFS7RBHi5rmJK1FokPP7QHZmFmIEa8Ssb-uORGi7OggPE1DwM4n9j8b8KDKhMKeXOtnQcxywIaoE0JVo_GElFjG3NO4ozsG2ghimp6AWWvwyk9_q8yLqJosC-swQ0jeAqCPtL6WYyFGwJTCcEZuCj8WQ
y3mKlz-zzMURbx9aQdHKhYG5kqjiguq2MXVTNCAZCobQsmjy8uOk0Jsu-bk4b8a2-q0aJhoQUmKXMZLuBtTEW3UVeQbIwdjK-eGEYLbkDACCmAn-nrqYm9cYtl93gcHGUI3UADx9uBh9MpVMb_MqP3mTO6aZghUFJBsI9-WZYJLyto
i decided to do the back also, u wont see it but nevermind ;D
y3mRdhtNQHraUeJUxsdU6SxoW72xwZeP2LLPhJ1pWcLSLpmZjtNBr1fs840xS-lHYRNzIh6mFgX9AP0EP0KSWxJWYziRerq78bwhoPwqpj4XlvLrBasjiHYCR5f3gLTLPYS1rIWxgNcIzmtacA1I5BpBST6vSnCFC9F7FHd7fTT6w0
y3m2ZbmsvyHW8ieVq9DTEUkXGyfRTnWPaQuXuJk0mJDKek2a4dG0sMMF3_e4W7NYOuz4BWGwVVl91Iwg4AQ5qymvKL1SAHUq-1yDVxxPGhOcr1gxZEk7rtLLe2DOyTwxiBZm4ZLDMZniuX3zlaZajb7j8js1ihXkVN5atKHx9AwSdw
y3m5MGwHYqYVkbbVOW-pC3e5tTjCzBrvpCwSDL05HF8MLSNZOll4m4zfGyeSzSR-x3s8EuxLEHRUhjZt7rXIt-zZaVbvEKlmlL6sMi9UqYGhD8IS-35-ihAkmL6NYZaAHRw6C7a36D1MP2G_dTJlYH6SrXYm9iZH5c14sLKRQfJdgA
glued the cellular rubber on the fan mount.
y3m7IXu7OAoHC01NtUtWfAphaTPq3N80be4i55Wkmq6CBIB1kXNxQUJx5-SnCqUA9VELC_8JG7o-QAAi_7_LUwZ6_BmeuiEDj1Hlyk_nfbEHt_krBLu2rWclAMq1hB1wcHG47_G7o7EHxz_WdrsgyRVeRX4QPXnCYlXJko8u_UP-64
hope i got more time to work on it next week.
so long
greez benny
heyho everyone!
Got some progress to share =)
now you can see the reason why i drilled so many holes.
y3mIFKTQ_j-5G556GPPOaUsmbENEgyRmJdVdAur4yYjUgCFl3FPAvztE63f6MKxeynRr30hIoT6jkKcu9jwu8q4SJX80tEmTTtoaM44dv2XNSCqmeVmSAdcmDFFTD6vwKyKW0oEq6EzVw92H2CFQptPhKVpZokbqkHAUwf8GjC_T3M
y3mXUO5Vn44cV5fCKM-9MenqnGQLyuDSAGOk5UBQjQw0NDFGsmiKdgFtOtEntYNzklc99E5jKCzndRzvO4N2G9VBeiutHaXomMIIBSih7UthcHsgqiYoNXQRV3GdrMGxobNOK0fBaUuT5sZ1Y_7ldaxjFI67mmpeDPoARvZxHrT2z0
y3m1VwVKSPTXR1EHpifQZAc4JPAQ4hOebyLHTrkAaLC7jdA-jMksP1LEDxzkNfo_kL4quGfTz3v6H9x9Zz-clJhcMYojR9C6aIreS6FfRUUXDRSkZGHLWDZfxfM7dRAuWMiVyOJsdMibuWXbriK7tTAw4clhaTggRZj1wIPCyD6MuA
y3m_T0UZYOVtRy8luDgRwr56pCbAsiJK57jU9C_S0WOPYsKHn0f20aNTUL8mvyStXLqRnAJcs0SbWhSQoApqkgJ0eq_nc-IxMMLZECXPnjQSuNeDWam3z_KGtnfMy4sjqZtUm_lhimkSnbBvt-KswtfDDfXd6dj5qQZ24tt0Qohh8o
y3mhStOZo7CkrZkPMeX8-ZdwXxi6Xk2i4YsDAA-ROlFgbi6YQAGu5T9GxywIJbivTlz-GVajvMoyPuWOUF_SoIQBQn6RjNFkyqR7tK8m3IbgfRoc0mO9n0M2kVb_FQDWlGwosXCDICw3jZ8FJeYTKKazLQhV2W9U4ArxYyEXbJddeQ
y3m2SqaoUqv4vKmRDMKsCgEhQBF6rxD5GPWQTWmJG1Zkg_9XpPJR1rtp2czaRbVfJf2TeuNTrHggqe2p8-4esnSOhxw_d6cv2DRVWwZ5PykaRbb5xKB0zzsxdI1t246NLtJ13IO7PeAgGgtP9bUdQrTAon-ikxRPUYMydeAwGczbIE
y3mWLF_ekEHXnIJRwOk6Yt8-19sjdKy7U--mBiEW6fmLCqJKBqE-DFpTSLiT_Ok_s7-PMr6jEomMQH9wCooTPJvqvWd4UM6ZK2FcAbw3zeSIklj7izNx3Cnv8oyaT4dhmV1xILx0dIrElq9Ge6JyR5iQ-NDCf8tKwgeFtAgkgNdJ_8
y3mmBz1P_QkX2Uks6PMjGWbOZuzqojDo0OSRMiMxc7PuGIoP_GBh4GQF-lIfTIIP86ap7Cu7LVHhPeDys4rd3S-3y1vBEKU9ZV9ZDj1JzC0OUXC5bObT0J1jBb9zLvGO_UZLcye6w2FSEjiOhq-OfE-QbRS54hB2RrmpgSThP1rYyg
y3mkPH2HVUxH8PBchyPYWE8Il-Gnlcul-mH-ky0KJJD3-0k2nmS4pLSTcgslEX_fTGC7cVMJVme6D3Z1tiD9BItH0a92Xi7P_PomJNHpzG_M2PferPy0eyzr5VOs45N-piB0IT7v5VtjJeQx2qEnbIaaNsY_XodgeE1ISzmmqY-8ZU
y3mg_nRe_FPq3ydbwZeoGYselxC97OM0S0uGzcXeDcww6cY8aFkP3cKDnnHIfLxr895q1VF85uAxa8noSYTYVSQlYFxCzZR4aAPcLEpGxY9YfvctFagwExmK2nIUQxrbAYVblOxalZbbMYzSXfZxpDQZdMMa5J_r8s8hy2cyIX61rQ
y3moFYH7Jy23kNi1vOshmqNxhmFpC8eXI_Xm5xr58eYK1uUzEaXijgR5gIN6JnRrHgBbv-7iZXOXhpUTflSrIv2FHnY5DLWOzskHYMgCyyO_UGkB6pVuj-t13cMumxADeTlGithPdeLOEyJbZOhGD_sZ0m_mX4Wbw4vGQc-__oVnko
y3mXkQEve-DjX2uEW3hwJiyuM1zGa9EeW73yLuRWSxropmIrsnOHnGszjIp_tE0e1VUOiNXxfwKD1JymLBEKijmG3Fj4ptM4QPWJBEkOBKNIun__Wq33Jh5UihE6ooRQd39iiabAnKAnvNQKkueHrEkEGQDgY65tTrC7VmeT9kWJ4M
y3mrkKCF1ZWaTJAQXyuUMmd445fg_Fs60wiDE4L6UFsJol3mFIUn_fie7fywSTxqHLHWBtUVyqep4RePf6TTqzXIpNMml-W8yz4AI86Y2bb7tPeWOmyhqsQh97K5aPKMq0rDDfLKwjJFpH2wmjUXDqcdW7pmHh5G9bDnx7TyZIkoV0
Now mounting the outer parts.
y3mpRgieqwBpf6cAM_nB9utfAKwUH7QtOT-1ZuPJOq5x8Z2-suqIFIj3T8IIK9VNTKOMt6UDqYxstSzZo0WqTrO_PcGo7ubGLA4xzkZYI4UQMvFaacLT1y1EoAgc9KFjvgw46hpis3jYGkcZ_ca8jyxC2bUkVms72gncf5wrVc8Jm4
y3mgmnAJ3mfsnAzOoHet7YNZUnacNyD7Y1-_8cBWAoGlNpurdkys_sNKmw0d0WLr7D1JDdeFYD5CyqtN6ogLs4Qq1B2aGOP_8hRvzFvpEYRq1YEKy6Ch16fxqMQ1JiOpPCyq_5I5a2EDSpo2vkenUBYCVv3GPAWS9_ZQM80KMAN_IY
y3mj0Q0GTXW5yoCqvwgimdp29aujCLHhjOGa29dWuLFDuSuYFBQquCcSJKIyE_pRNKa4AfI_qtReSlqEC_ZNVmuFN3DJKVxmQfS_972sOSsG5WZ6FatWXAFFLbOP9nIbcuplq6rdHuTPWsj2akug5iuxTfZdycFezLAR-GIYzZLElA
y3m6bRTylVGlnpaRcqPnYikjxh1OZHxQdPW32TNeMSYkZS6VsTbMNJxs-yegWJ2YerfH-3ncFqxm6_jOUwQ1YmipjvDKtRlkgQaZgapklubvv2BhA4hNoIo_maxwShlxfeiEHrMYuF40C1Q4iFyPgvxtD7aElSPDpCvDFeT3CK1ndA
y3m5OBwsgeYmAg5o9LtDaG9hKho_SFqf31fPaVWqvWgE8U1T0USf19QX45y8UunVOv1vpoU1bc9Zsmryot9BB94qbDqDsygSoDH6DK_2ZhiPerEqi5bn-jH8DXdOh1Cb0eri9mF4JrSEkvQb9rQIL2rolaFvOyP9H3LUiAGDWcwL7Y
y3mWPTKEaftgqqHOqXraWHqSDx_7F-WzrSbIHCUiZwNcINV-G2jEOxhEl4FX81uxFlwr76iDjbyvb-fvfmH-2TrmVREpWmdMje3CYWn_aEgPpXezRrJc60Z9-e4gtMxHMmhw1fdMqoaxEajXSJirHZIdTL1NQSMfdqXZPL50a9zH4U
I positioned and mounted the screws first then glued the cellular rubber and cutted a hole for the screw.
y3mm1n1WhaTGHnZFQ6XBGaxu_iVo-dwTGjCq2bMTKt3wAAN6ZY3DhOVFOg6pIuHSY5z6Od69FHhPcPXg-OyM0XkwCzx5UmIOPitYtrhfQL-b1v5NOC_2TowQ5jYcR1CRvbJrsU4yL7bTmP9Fqofe_9ERw_WYPdCzOETaYjbc4CGU_4
y3mz70Y3cPe6pC9LTW1yock9Vku_JwCnQAhisy18YAGfnCJV6SRBA7WlMzw8nyihO1Sm61CcWLQH67cOPWNYXSoTojlH55UTslTbGyHhwnTFxSsaLju-ABnXp_53NSgiMOU_8yihd5tbIxYfdgUG4ks5YRj5E35tzCzFOZg4YjmXzY
y3m56_CrAsqKHl4dw8_3TCa3FbHK8Pj60vcYiQlyBkHbSytbEm8QYsgZBMR5CEKqwght7EDSH_OV5GI1i4iXafW64prywJOIcxR24mHC1UlMR05YhkfjWEjrGg5yw-6bz83oeHzLg9uGOfeaSKuffoN4Am3Vwbgpwti_ZwkL6CE21Y
y3mOx2ZzLvcw3DI-N4D0bFb35AellKQpQTeP8fbpzi14ioS7vO_YRnjuIZv3m-dksYWkIdRGNM3rtMXpVPLsibF1WrUGrwk-1-mNffFWvLCNF57ss4m6vwENOtPPIrO0udHWk32hCC9l5Wm9GuY11YMtFULWkN9FJUjlhRJEuNVfbA
y3mfa7Vowo5Sgy-mi18cgemBZ80_Cup1JvTVXBCRwGsVpLHwYYzwVqyC-Rxroj2WkYG_fUoegWz_syVXXSmFao552b05O1uhEE6fK9bs-X6OqD6bKRNao0jiNaH0DNRlM4ZRy8gzoYMB2cD3nTNS8uOoFfDCXnwztMC3xQkpSvG_NI
y3m2C9rVi8pMeAQGmFwKfuvbvO5iCcOu1MqZoO0icdhQCKGfvK-lbosEkYqhjKSsmsrfQGP0XWgXZAktbbIFn2oN8V1m-6UZoNYZuqzxzBfbHQ9wsYeqSjP4PGJ-WSX0b998a739UweeWpKXmSPaIsa2FZSfWnJ3DUGFync-FHxj2U
here you can see that the upper left part fell onto the ground ;(
y3m3FgUZJDAYEmn5kwlQsRWBaxf2KRvykqO9M9MdlaxV64kfu3OFBgkHDW38N60ryisHA1XjOkUmY-tmrrj8V1O8jSU9nFtj2j9zxjeTIe8jFZ4OmOppgQnEJtnVP8FJlUPw4HUwcemXqie4stN2F62YfYZ7ZO4kyp70TjL2mZ0Res
y3mqLa-JU8-3lfa1Vv8o-BlHoiALTp2rYQptkZ3u4-JIrGRf9VAULFzIuRWyWCrOkQuDsl_Jh9oLlDWl6ksN01Rag_xU49Sh7tQpvNivbpKT3wLWkMKaVj8e6cy8ol5DK-VByyDB8Ml7JFdE7Bqrup4PlfIWpi7FSUJNMs_LzdStYc
y3mMIavsW8mFJtfVSrD2PY_WgiApcpgdtqmhpZC6LfmTxo68mYKXwbBzQaW6VnqIaCoCxWy9R3AFJVq9joPgEsIMfwRGv2kj4oGz7nDkwJn172_HmfPTMVthGkHk_tKsb5NUIsRtwULgjtzReAhb8QFyLBfmBb_Y7oFZbgh6pFF2o4
y3mmYgfBRhZoeIGpYp0mhbvsYKlfCa_U9u3BTu4wwZSK6i0oKNWqjaBYgwEoRpR7lJzSNI_rlhNPxbE-CUyFdCeIKNs0jPpvZEHGwya5Nk0pz08gz8MGU3mOSJK9HYHCxdEDEXnPGdkyto0phB9_5bmid3CsMHbS6JvCX5oM8Y9Rms
y3m2XjljqEmrhb1o_EBKoyaEobNhdVpESf_tJQaDX8AUSyaz-f8HeBdNsvzhEugtD5Krs1awL73rkHMADIDDIq3V14e3MizxmjLY-y6MlMA0IYaRnIcyqEuunF4evUVtqTeNLSdYuDcMcn_-d7wYYt1BUYUcvSntr8AzsktscRkFlY
as the paint doesnt hold on to them properly i had to made 2 new ones.
y3mOFM4xUdOF30AiBgGtjHMtoZQHPj07hwFaxc9A8f91nzh2DUybfJy58WdYaFBuRxXLRjLrCvu-aHc1ULqdEg45UuRGNfVUXpvbWAofWu4qX4BSjUwU3xXytu-OTnM_sWb7lgciqm7pfyn3zRPdP5gN0jwohzxqjXsagkC1mm7_B8
y3mcomXz2zPBh_zR9Nr3v4u0IGvLqOzF7MOugiAxuLq4BO0MCNWIqgNKfQaHhg2s_mGtAZd8U8TkwCoNw_rNUMjU4nZXrMBz2UQNq7dn_GkBwVDLV8UznnLv8zI-Lz3G9z8fOnHWNwKqN8AIFt7b3t_FoVRMq75ETzyOHkYXR-ZhHg
so i took the case outside and made a few pictures:
y3m2C5jSbij8n4-jmWaEPpBeJRH0IpusEdtr8E_ZmjomxG6YIt_jQftnErW09hJTEzBxmZ4FU6gjuU2J8zJwFiqg0WhHBlA-Fhubr_cCgAH4hJzIuljzQx0m03AgXh-B4wql2n23lwdUaMyVU22Ew9LCm3DxlZ33Tvd7pFEivt89q8
y3mz7RZYVwrw7pP3eeDu0p2i6ygOhaJ7NCzysNAW2qtTCLptxXHH0Dh097ojMZeHoeZ3aqWBRVV6C1ls8p5nxpMM1MYrYIinWWbDC2K1UnfCodOyS6bYe06yN5SXErUOSB16xZYX9rGl7Kk6-DaPVBEwz2XIig1opRSigdtGuciQIA
y3mOEG04jcjP5EdSJ9nh43-mEFvtUftAdPqsHxPj7DULJZuxqjiPExKOYnmhJQZullSUjeLCKN9xYuOYb-zRUDZJ3HKtkCPKlswLsZu4zE6Ud4uYO92nIrYpzK-R1e3RNdLwvuS8lm_T-ZsTfCLqqK5ObGFtjmUXLhj5RVGR99mo6U
y3mFM0q2ZwEIVYxVaWO29xmVgF2E2hgxOkztJ8p0Dv_l-_-zaoBTNDKvtwkpjGR6tKLWyhYVOMUw94Wczdg1TORpndfOar_o98kXfFBV6qSLex2ewEl53cx2t3U9h25q9qayWEbUXjrJIcVveY7KgyB2eZAKVF3GuyuQrXZbI5DaQY
The big tripod was there because i filmed the assembling progress.
I have to cut it and upload it, then i will show you this too.
Thank you for watching.
greez benny
Hey guys,
for those who are interested in the assembly, here are the two parts:
Part 1:
Part 2:
part 2 is the better part IMO.
I am new to viedo editing, so its not a masterpiece ;D
greez benny
Good news!
Hey guys
i got a sponsor for my build =)
Alphacool and Aquatuning!
They supported me with all the stuff for watercooling my build =) They are awesome!
Go check them out:
Alphacool
Aquatuning USA
y3mmt0xt3c-qIUyUI90NYyj9Kedc1rurTAEZ7eMG9MZLFDHBekEVOJQK2VwDz_9n_xU21zK50nc41Fcg6w1Y14lopp1TwMwmZAa4KPEhZH_8-hPPUrQtL4kPgcuIpsfww5er5rqomt9Q6-SrhgFL8JkP-yk2M34YiqXU5idc2gS_sE
y3mWkLkdyLyQaSSFOaHmP9pk33YqembCxMvontD8a24g3tw_ct5sHFNxlNK8zasdzP47yR-9AcmSNlP3HDitSL2ekGkxhUHDeSCWbvL4uyQ12Id4aGXu2dR0eHvVp0HHG5L1PJawS2-Tj9fmubHM1u_TTAYuflXHmM-ioH6utrNRrI
A huge thanks to them, i am so happy right now =) cant describe it ;D
And of course thank you alphacool and aquatuning for your trust in me.
And a thanks goes out to you as well, Thank you for watching my worklog.
My build will look like this.
y3milPc7s_12_yxTYuTjSpH7xjYe2JX4L6mt7rpTbNywbdH0efzpyYQvaxZIj8wcR6p2NYkrI2sKYqFfOehs7e6oMBEw0Ern8bObaI5PuGeD-s1PM2kzsjzxMmR1izvOoyDeJYWtu2Jm9mfQ7lLTpYkzIMLXJNqgvqh584J3wBHilI
i will mount the reservoirs directly to the side walls, cause of asthetics.
All other ways i thought of aren't that clean or good looking.
And i couldn't resist to mount the Top "Eisdecke" onto the pumps =)
y3mXMsAJ-QB2KymstcSufpGAwOUN06QS_mn5Mhp_FhJewFlnfjlgOu76_phiEu0s27Dw6FG0zMr_nffPHHKjSdzEi_ZOuCZlyK2Ql7jgWrdAeJDQRw3gSWSloyJrhKBnEHBNWiNQ9m0kKFHcybmU5d8-pOeZ0BH-5Kh9dGZnWgWNoU
y3mu2msMa29KCikvUDzqJuSMCE43AW0rKFI2SJwlTbu16P9SotNRhL5-a0-PbwQmYc0e4oPKSKlksjvGF_D6J6_Xu92x91P14mOWBP4LRKyODz05MlgXXf8UsQ1D-tQ2Wk8GtffubxnPIt0hFKT7Td9DhaqLYiUShdNSiocKzdVe-A
so stay tuned for more updates.
greez Benny
Fantastic build! Really nice design with everything cut very accurately. It makes a change to see this aluminium profile being used for something other than sim racing rigs where it's quite a popular choice for the frame.
Hats off to you sir - it's easy to have an idea but a whole different matter putting it all together.
Thank you for your nice words =)
Hello there, got some progress.
i've made the front window:
y3mAtWsVdcE0_z8JqPx8angg91Dkh_9ZBJG7CywOHEKXhcKB-YBDFNNdTogY4WedW-_8IqFIbTp7BgMmXsRCkU6Vb-J__jwt8WurzvKYzle9goTBwNswVxtOIZl04wTOtOgG5X67WfLrtJIC4hITEgUjkUZGwaoSGCzwzGxPHRoHbs
y3m29n4Xv9ws2Zd8QUiUx-hUfV66mgOFbDSyU9QTXvJTaU_tH18kdRCNcvmNgjUT9QsAA7563Ub9Rpm3mLrqXCNzJpwNfAJm7dySb33j05z0T0QKk0rGYm-0N_Rg9R5HODTJBJ6ExoEJbQ23ORN4px-Pv8UUixWzfN7ISyvzE8QNjE
y3mTnH9vpqmU-ibXoiuoEVZrexIuHl00t_s06dEd5kVXP-ZlSttuw_z1eLfT2ePZiDB_QYMzKAnrTOzoZSNfA2ltsPoC2cA3ZNqZsaoIog-EIjUvoSNTphc81B1AI1GX3L3FRgPe_vSTawiLQagnGH1xdgoY3EfNNYjDKOqnMdCJYE
y3me7yj7CaYsEX6cmVGT3sbhqVIhiHxfiQoxwMPOz4GQKjF5ptndt5Cu1126e5adcHFdTWdjlfglNtzKgLUJm5VFPTNFGX0lYVE02HtiaASWKIFz93E-kGyzFIzRsrNPo9VXtgx-1NNJqADYVwXTA_lsDLN9r4i_b8BXHjJa2NlUDs
y3mCL_HCg_M9RuGw24HSZiOtmNGVqV4fyBL39QJjoz-bRiG1fabMpMZdXzxV_lJTrA36GyRcfHgg6_sRTCWe_27RYC5rh7j8fV0VE4sRUg1KVlUtOY5qgdDhoeGFsP95TmV0jal7tMrHJEDDNBNeObxZbmneiCIqJJdoidTVwS8rNw
Without the backlight (sun)
y3mbm_6CM7481OTU6Wb8SMybIxvNAnf5EbhSYFhbhXWLLDWBvKiF-9Ouc0rsIwDUi10MLtPM3mDUknsgDi4cAgNUBVemxgzSUY49h2yi-q8ndBX07gIyENZ__xsQ4X9jUlghGCQtqS6lwqO7XLE5_URHcpuN8GSl0Tazjsf4WdbTz8
Then i cutted the L-Aluminum profile which will be the psu mount.
y3mCiM6SFDvuGjopq0wobNqVPtOMxFaxlPH5df1qccnxwoSH6IIOCR8SK1eSZf7xOQ-j-_wll2fZcPvCQ37pvuzLe5-dFTHfFXNjNS-SB6R6XlJLZWpQgIX0VPUcVCscaIR6wKi2oIjnuDZn25HuA5Od6w9j9SQ9gPdScs6fGHCQkk
y3mdApgvFp2VSmNgYGwSdgnN-TGgSo4QWuuxgmF4yyAq2ZKcWvzVTiCBAoCeheTrOwMuNezjfdcYt43GXw9hh_Y6HnZ79826kvCNvgFPk6GJg_mWXgOZ1Lmae_KEqnIt5r60-uhebvUUu3YajFMPNDTcWQi6gJfInmOQjcuwGZdgH4
And i made a new bottom piece (i will paint it matt black)
y3mvSEuNY3jC7zSgVVRSiDuFhuMRYfsUJklEXgoVSAh6Ji_fd1YnHSktvAlTXmzb-rwnNgg02w5zDkr0XZLY4pM1FfpUuheSmCpZDo8p9T1kGMvq0-U3dUBGpUq0q8cvC7UeTzXHvmQSZRpqb0lp8bibRkBk3_2HtaiiQvQFuz17I8
the old one i think i wont use because it was there to illuminate, but since you cant barely see anything
of it cause of the aluminum profile and the massiv radiator.
y3mGJ5f-719iRW45BJg0iBAen5HjY1T3NBgSLiWB1k16Ajux_2BNiiS92nmQkFJVfZeLtka17bB80RVkDtM48a-nZ2j0s-SZbrHsUa6TctytQ83Xe_bLqLVBfg2ounCbZoLuryyyFQtn2ZyWoZJ-oMKmN5A334ngpCxUZLjV9LGn1A
a small update this time but still progessing =)
greez Benny
So there is the next update =)
i just drilled more holes ;D
y3mdqj3xM91WH46E5A8b74yxmA9zGUxu6Hqvkt9onnBh4Fn7g0GebbVwk7Oj0QbFGnoWx3SPEXYDjhVXOQQtoatrRJSMzBLy00AgiqsLnfvjfevwj4L2ReDBKHfrJdQHU1ELq9n-QU4CoCal5xL5A_frT1aW-r_bRuDoR5GfG0B9o4
y3mgQWwa7OfAyltzShuieW-ZGGP9rGiQarY8wZuqu_jlg6GLHD0xuI6RFv5EU-V3ZTa8_BDio9OAnXZ6SxXr1Nv3_WBCfVrx0VbEJWl3OF_5uVtyA6BwB7z2KqNIsYpxMQmAO1bmmi9uyHI5xP8ssL7GvOWoZdijUXUXfvXiP_dnsQ
y3mvXLf7QvE8f_q0hg8_pofC6peFXEdhZ1Z_6T3ZUC6kHqEomQGjigCTpA-DnPpyN-3ZQ4sWUDV7wo0BKAqoTW3HjWu5HJBPOherF4UEl4TNEMqYY2eEn5DSDSE3cpDdo_-4qE6OczhAHfLo-5CJ_alOB6-5wsfcspUe5leOSm_maY
AND even MORE! ;D holes holes holes everywhere ;D
y3myw5AZRcMPZ2TbHlshiq4m-_YSF4dYZD55SlG4AXCW3tnb1O8d3Y-akpx5NI7tp_fOk4_mM_SQuIjPRKLrZF4WgkT--Sz7BABA9vVvYYqCZJ3J7GQCYNWwUVqgsqrk6mpvdSwbzfJNQ82J3TLzLEl-nrD31wKrALPwfHsm-TdePM
I mounted the Alphacool Eisbecher onto the sides.
y3mYncX713FePamqPD4uSq2HlISDW2x2MnQR9fBTqqN12hIerud24l7rZPwLL35cAqqgrRdQ9TmNBvgB5kEiq9ke10sqaT9NVgHIYhEOjZ0Wte6UksKgLdI_Wr8U2wE9E-5eDXwOipWK2NTUJNSK9FFBzGculXFF1635xrJAX85aOI
on both sides =)
They are looking really good cant wait to see them in action, i like the lighttower effect.
(and no i am not saying this because i got sponsored ;D i wanted these!)
and i drilled the holes into the bottom piece.
y3mebZkn3Hg6DrCvN9rD17zhzm2AJYQClKPKHGWI6Uk1sIz_NIpx6dVinl3-DLJHcX7OnIonVt5nCTgxiyrXdxRlv_65jBcp1mtuhXQKsLCfxNodmmkQ-GpvMi0UFmki0UoT9xdhwOcIS5z3iGkBbkOIFtyby-bwCSH-LRCmsfUlHE
y3mYgS7gV5xpWu6ZnkK3359gtPHwjn7Ggrud04kjtsfidRIVKcBdXiNu0khizjB4S5LyjuIJ4xoqVvcjVtWZ5dcGQ3gOZOAu5hiF9RNsR0KutzYd160EZLpTS9oUmGzE-YrLNmQCDSvcypxLG_BI5DKNRZ49BW6m1Lh_zLXNo0Jys0
stay tuned for more =)
greez Benny
Hey guys,
switching back to the plexi for the bottom piece.
didn't have expected that the wood will look so bad.
This is not the quality i intended to have.
y3mUtEGfPgne6n9-973e3KP_FUt2eMMDEZS6lvaIH90eH2CCHg_7yDFoAAxn5I0oFh2AVI3SL2zdsOtXKVbXWOrOpEsTeGNKsHagiRssfsMIRlc33yjVk9CLMMIjdJ6jkt5uqZZCydUzug6qhtzC5IGgBFtAdkEWjlH_7UTV51qWDQ
y3mCxFaafRgzN0horwtZUT2dp5TytIebs5UGBrATUo_v43jrlVQMJ-Itl5seM_TOyl3D_nWV1D8ZIgSxeQCSggIqVxIhmGEE-LkNZApuXtG4kcOKx9fAX4MCscnKoybudY0qzqCMax67pc1F-KPIk9HEe_eJGHbBwbJI6TZzd13vK8
y3mx2xuP-KM4BATU_gLQs7y3KjhGhBM8Vy6Q_FCBsLw1Sq5jx8KNtGMciZdgog_Nf2_eL7wN2YW6jJQucEx7jTy7a0Ra1W9yzMOzBY2Di5ZMrtpYlt7c4qlEmcAyWmzmYM7CQirVcLhd1ttG1V-n5mM056m_i_8_MDxr4-2j_8H-J4
y3moVw04ZzMAM5YLu38tTG40TCGvqEI9Vs2wUNYD6Gd13e1KQXJGFzYUzx9L0lGTO2Ii-Sg0wMIq4kspHVH1aKNYLOJoUiC_OhZTmOUAFpQGRrdbzqc34BRLCGkH_AobbTi0quThEDv9FNFfjkSW9Wj2bAa3VMqb5pCV3LTdzNDy24
greez benny
Another Update =)
I disassembled my pc and placed it into the new case for measurements.
y3mpNq_yP5u-thtFVFzNy5dH8TutRd22srq5lr7WPPgiz1VlsKKh1OOkI-cvuZLGGkfOzv1r6KdNghCLJXL4EMKAVKZsQ9QRJbVrBx-5gd-51rIREfyvTmHOuyWO4xcMFsx7NtpA1e69J5J8DWrUcHQp1Ae86urmmTQJj-lsXxANqg
Then i nipped on an energy drink and drilled more holes ;D
y3mRS1x7E2ch7krkIcra52O6AvcY-tJPUo5RoZvk31oFzTRNd1HkpJNIRli8Qup9Jut_aksP3S86azipsTQc8JZEf6ZeKTr4W8Mb8PD1nCYfEQDpQO0JmBjZzhTVS6lau3ZQzDxKOHmewVVIbUss1fpaT05bJafNMAUwTTJ1JnYzqo
y3mZVIJ5esZo0D7-w-eUYkSNBzEAdRyGo7RM1lrOJbD2cIC_r0wmchsqBWeQLagPMY-XrEg--8fEULd4sLJCSnDrnYRtbPJ2DkGrAOLicNzMjeWvgNl4KSwxOADYSEjaSd3R9nDl-V93DMT-nrVxHD_MCuQkue3k_4lnsWF7xppfOI
There on the right side you can see i failed. =(
y3mujO87GZMWyWH4gq4uw0K4eR2Lz7akxQVgQrqx0ImEnGOpRwcrh9Z-7K2CQMD_wwl1UdKd8la8xBw8z4XoWFphF8geumArEyw3CDci1Wpf9hzCpO3r1Ny6I5Dk-x7-diHtR3cXSiTDjlh3HoKLm83gODe894oqIXtJ4FzEIJuHZg
Here i took a wider distance, so i wont fail again.
y3mJBudtDqAM4rvhCADz5SYH3oee1kv5I9CTZdNSRuGOEXvrndTAfVDUbQGCRIV54lc1ge8Sq1yPKWwSLyDTM8vMP-1mSmRY-zaG17TiYXX-KUDC_SUkTwLK5n2tcSLM2UFwSy6p1G-bpOQ0W51IJUVDX0At5Ky24OrhP1ju7Qfk60
the next step to file all holes. and fix the fail at least a little bit.
y3mM_JS1o16218Mkx-z6JlC1GyK09AJMRCc1yCw25J_YKD0PGf4snNvUe6i6L6fq_NYVLqWhpB12chqyc7UoUpQCbgZF0kVfy-dTCx9qBsaMQcnZtahMrGsXVcFLpIc_xqtn9diyX7js7yzx0srcwHA3pbGtvafKxSARcE-w_qIH18
y3mLy0ZKjSZ0Q3YNBUcdO_r-A66bh_Earu9ygo6Eke9d9hZ3TXSpL0PUuyWbBccQNXMIfk_2ATajUZBenL8QBYpTtASsEr7RxbPWRju33SBNIJWS3lYpNZDuKoB0vdeuaQE3hxW7nVzhh-OwfEGfuJ4gp2B73tcC1Iqr5N0Jlab7CM
y3mKNlNgJgQH5DdhkTUo-YO8R9AgwIp__D95gAy6Aastr22iXUHOOybAF2CT_fw4dpxUM2GGQs0u_iuo7cKfQneqDfO3AU-QzGzRkH5G5YhMgipPH7-7vV8uk4Kl0esiDWZQt-p0yjPFjGqmrpcePG9hfWzD41UCx6pbKjUYb7Ukq8
I hope that once the cables are in you cant barely see it.
greez benny
Nice. Not quite my cup of tea, but a very sexy-looking case nonetheless!
hey guys,
i made a new bottom piece. out of LED-Plexi.
This looks way better i think
y3mBMQI7yhss0MOtzM18AFds7hyUrOK1N_vuJZEa-hZTyatAmn4jltg82UeIhr7fppbfSZXXdh8lRBkDHbbWVWzt75Dq6Q4ffNaJEcw0m7Cu3t3rvLEbmIXX-s_v_ndaV51xIcqlXy1WAhIzzjdZczGDVDt_npYD0oMyro2c0Rwdy8
y3mh9tC6glZxHwwLtecLuYVbtzh8v6w0qeTXJ3HYTxL9dHzSJ7D0PjxP-h1bS5pu1N3aWm6tWnXt7p8IY8TUl55etUkps7uJMDv0LPztui9k9PJ33aHPU5-SeOTnRFAgL22FT4aeQolOBmUHsi0UoeFTKk2aU9inR8viV7Z92WiTqY
y3mKxC3onj4WaJ8TsmwE9_17m6bT_eaHqkpkRNlsRKB8ZYqtdwYG8SPiPU_AioTQmYI9rp9sQNzRdwqO70tFGgmF3uhnIC0SBHCNG8uggs9-EF3B3W-9JcT5JKZd2w-vZ-NjvMIJMKROh2fmtl2zCslPfUk8POO3CunDCTq9j6IoVI
And then i made a little light test:
y3mrpUSE1_qaQxSnUrP8QYbqUGthTKlEHM98Ia2NR63M0E0z9NApqHobQ39J-twN_tRXbZKL1xSv1FJh-o9AJxshoG101bT1zkVj3vQR5ILNGv8rFC1cr9FDTlcpNlFCr5zXaZX4XgV-uBItiGBxA7ZLAPI_Au3UZ0d5Km0-20Uu_A
Paired the Alphacool Aurora LED rings with their Eisbecher, this looks so awesome even without water in it.
(i just noticed i should have cleaned them up first ;D...)
y3mafHU0SHpP7VluGadydg-Xwb85z8bZbRmeCx9f7j2X65WpPe8QHQWFodTUVDL54-MlZR0UCqTNGxC0Lu4qWb13JentzZ6Ico09nSVAX-4ZxV3FLs-K8Wg4wsnDAucxzRK3OFSgUiS8mn-xN_CBS79zdWH58gRZJ0tYAfbocpE7KE
y3mK4VmoixptoMNaCAjyWFWTx79UvQgn2-IawyMur4XiXnhEmG-_IKERCHRx1kFYQNyieJ6rZM_jJAF7AFxSa96r81eVDcGj000IBqCTx4IxCHuuZXQscpLKXdNf8Gw7jD_grwTnyOm_b3aqwfN20jN1rCN4tYv9W6_DeW6i2SlXV8
y3mm8AMde19Th6ocVPAZPqD7jTzH23cZVe7-gQBx1zjYSg721WqqxGqluUpuV_Akgcxv_oeJTMn-BTL_GyD2Pji-WKBK7QLiwkw4gw7NlfR_STrECXWDXg0PjSkWh0f5X6Fmkv_EU1TsHVOGO_bLaSuiPkBlah_ITsdO89BhGSio1g
y3mSIeGmnj_rAty9YnS8BVaRilH4VCefsT53mDSBipwdrZvFEAJ0uXYfI4uYJyBh-emjvsjJ0aklya6NETXu8TMV0qTqUs2GuugoydBtgahUMAbzZn8kNCTArvDd14OnrP94_bSGr1m8bvzpoPBU7_cyU9xaCKUACZXQfz3WlRGLWQ
greez Benny
seeing that you use mostly hand tools, the exactness with which the pieces fit together is very good.
great looking mod and very well executed so far.
So another update.
I installed the alphacool D-Ram module.
y3mZH_euNkX2K8gPu3iKpYzGAscKbGK-8mjOjfq41nhFpn7hSuX48vzS-KjBSkF3fJi6W2-KQ-CuWVT1Mp2S8u4QYI9Gvca2WcN8c2-0Fu1KZurcegplZMZJsb-gKBH2XpSSgs8eOg3toFkDDnSlTQiHu7fzbLdrde6aVDvYVXG4Q4
y3mXXEaP0gEsWWlIdjT7OATEJtRAHV95KsHAUCaL6sDFGiqLXpdkCu1Agl6Z-UCD1h5hHbaiNQocVKZyntris9wlZmoLwnVEwl0x6LXjmV18vZc4VgakyfkkCItdS0Y3uSpMj0rIocrXeVAHXUyuioq8qGAxNox9TDCdNFe8Fm5fqc
y3mFK1cchMjACL03czWYM3arP6AZLYDQdayRX1y4C7lFawNrTe83C0s3Ih08Nz2MhaXa1SQ4nK1qJ2-Bi-WEEafrtfuBm8007FcNyF7l-t4CLaDlGPTWv8XSISoCbMsJh5i-R9oA8U0VV_eITq9RuSOCjgD6KxE0ygdpXGaHn_TJyc
And i had to drill even more holes.
I forgot to drill them for the GPU powercables ;D
y3mKEkWJoz1RwFANU3m6qeXEuEhROPUg9nHaQZolDcw_3nhdtnihRab_UXMBwDNofU3hAP2YGUG2i9YwsgtF5XSOngO3rqUkTyXCWprsUnXCZMjU2fQGjdQllx9WtYQtWQXwyNZP1HmGEjvZDZOI3gI_QDI7RlV1ITAD1MjcL2fzGI
and two more for the waterloop
y3m8zjxodChREOsXHBc4dSISEMGg61upO_AuD9h5J_oPESAa--D3zEYEeZTtoC2221CJrEp5pAkUjdh9WVG3rf8EeXLU6OwwQ9JXta1vqp6jjyEh4h-husb61ZcCPYL-9zJgedPb9qLuxeUNZrO78MoLl1bNvtEDYHj7GhCIXL91y4
y3mSwvbaKgziog0AfV-YZvcMSBX_w9Zw2uECJGvMN4Spc4O4hjsHuUZmcP0VM_jFeWQKmdfbRZTp5NkUnRve229F1tviLwsPJesozk1XZEKVaSyRM6QcSHkySHQk2mRYl9lnfhGRSyxAZ4VAmvJux4v0Jomkz-w1QoHDDYN8gGVDQk
a bigger one for the PSU cables to the back.
y3mjyKhEGmdBpSZmGd5iqYSyQXnk7pv8PftYybjHh69EX_mvePzReTwDjySjelb2TXR4cL_okzR3hWTiIMQxPdQnH3XHHRQOjGXZW1G-z-l4qNwUuCiIUCAbM93AWjtQYd6tZnwVRhTydQTIoiigNROOWTkJ63MnWOot3IyQZL3x6Y
and i clued the cellular rubber behind the red plexi, cause the pumps will be mounted on it.
y3mk9ACChtb58yJUwc_oIVcGRoJOTk3PyX6XBWX7BEa6-2YNwiHKh1J8IeE0BoqnWMe-EIDxG4iFeXeoGQN8hLNa-Ky0ouRnMNdqs4Q7QfI1dwx7_oWhAqIcrqfKULmxLOgex2uLnhLl1WJ2gp822m6ohbvFgv6iSMHVc3HyHdtgUc
Now i have to wait till Gosumodz will have their sleeving tools back in stock, to make me my own cables.
greez benny
Hello guys,
i ordered me some more plexi for the back.
y3mjYNQMxxKN8pwutCyXpOHX5yuQF4sfYMiHRTOla_IjHew708MeGdIZoossrwRckbKesPlXd5Mst_mlirZWrJEWRsV8HWA-WeXIY5HDST02a52EcZ8hOlI79tJ9VU6uWx_xEWKB4HeNyk_z_c3_s4KoJA7mwOxIJtvaH0G5F5PHGQ
and made a hole for the cables.
y3mVFxJDon4Y6r_xATG8ZdDV36dXmBhn7l_ZJW-bL46h6XKWdXUzFCeuY1fXf_iE5B2Aq4OSaDlYpt5ty6vKmOVCeTxCz-Lg1mT3GMMiBqW7JPluX_1qcsjCk7X-K61r-6SrnbGPImVwyf9QkOyCsGliemC4UqH1jrH96bnFE4HW_I
y3mreDDMY48OC7shKowBARniVuZs6RRoC4U7OVc_jVkk_BUGU5seIWQ0LXXLFsiQdT5_Jqzr9SFi3vMLPxpwXgJ67eSw1MykYP-0alA8BEDXvP4QlC0nTe2njWcGoYWPt6IeAef_JRVFuhF9zMCtpji40N7wZ46bnuCZo7Hcp0_wZY
And holes where the warm air can leak through
y3mETtYeh9rN0KYUXsEjN7sl3ngjMEdPWYvx2VRj4RgzL_fXWTcQVAWs0i7vCLG-eu2HQx7MWCK8vmL9DxNueWG7a8SG3fn0HQbjgxf0Nsh2OyQfCFnFSavDazpUp82TQWskALrXCg_b5oXNpABxTXVSFEjEEyUlvrm-oJGV9nHTsY
Let the fun begin... ;D
y3mbYVyb38yFmaZgkpuvBGvCSwIPsEeTPRvsItpsp4Hedn34_JnN7lw5fIUC-bJMpog-lUG-Muiq4fIy5_l54zXYxdleiXBsuLNX6BP4GUZ5N1xufrmk00xsPSbRYyRn0B7f0OHCRULalJbUkk16hIYEC_Eqt37v_66-kFekWqTlf0
This wasnt fun at all
y3mBWcyILENO0rvWDRMBxNkay7k-jWQjKu-YPhOOZFfZYv5POH3uxZRQWl-nyKJdFx0dzyrFfvtG_Cta_FNoHcwa6o1CLiG-RuLuIRs96f2b1IJ7UWhOItFhoG3O8J-p5r7G5WZjUp0OHH1OGEQdzOajGRq9x7c7XgPRLqCb4HBOWw
so i decided to go on with something different.
y3meJYM92nf0-zVY8saDiWo84oKneTQZKHmuBSxKA6IcZs-MdrGB5D5rKuVC2omY0iZSJ_1KG2Uz1S5G5qEj20xpJmYvy7LlYgZCjN2x_fVviXs4lbyQUhcbWXyNbL-koGoo3H4SlPZk6FxrUpFHvumydkarqclK7i-RoHv3zcXOJc
y3mGOXKFniyEQSZFlzzcqmODvH9e-EwY0fcRjz-dz8woN0glG5qt1pOjruknPrs-LlxYBjF71PioSsydx8tlih-pxh4pWlA-Z1xZZOdXB9tSkqTnT2-bzkjQ_IN2cyD2SRwYJivI_UL3PEliGarpuxj7RB_9a04L4A-A6DlttrPNh0
y3mTZG3thjrrnHjsPlcqLNpwt91KeGwcIrcCrZ_SDmdaRbRp4e1v5BdFki0baXe_FCGIwvXFb05oJpq8Dox5Z5qclFchOnTwv3KAKVtPIj4eLWE0NqH99c85pxVAjcU0yIZppYtaOdMyr3ejke5SP9d37rHJwjiciRThLNm7qCgWL4
y3mXF9VKP4JVs9b29lcThWslauNnni2Ih2ufi0m-eq__SdEoL7n-9QJPc9tPyrSZCAyLQiotnl4sDM59QEnA4PEerFjE-HaPkob-mVIxVRjTMv6i0aqtQWcTm-L5E7WoWqpFfLltuDgBw0t51osEnfqAVvIKRKqZiMTASvjDdlqDDE
y3mDSz9NbZk2OdGnvhNyzaGcbzsBwoo7MBmjqBPFAYfcKWwCLJDsDGTt5tqIPZbYW0axTuEkUT2_zTMaNimyza2ZE9-U8dUdX7tFjm1vvESxXa0KuFFoDUQ4lL8AryRaB20gTtGZ5_eT3D-ECbeFP83d1uxEbRI_L9mRmwMq5DrURM
y3mGRf5RCmXVHJBd-qrmgk8qsakTdJP8RYG3owN3Kz2RGdQIpLijfRirwFbRezYWnEG9or7t9ExAIJzIPTp1u_zukXPJPDYc4-YjV2aB-aIT2FU73WJERhpM_1ZhlugOtFJ3I9Pq1cCTYepDxbL8l7ThLTCWBkmabSgMSIUYT0ZhN0
y3mzoKJenH7HCBrXj04damT_Cn9btz8yo0SBn68abobgBddizbhO5LRugfSkJMavwUTDFQEGeBzwQVlIL-we0YZ4eKs04xlOq30HdxJeJqbSxe6xDQoT3xtEnCuL91f-Ksdbj5BX7L1_NVaWD51s3hcoJtkOsz4LQQ-W5AahrU98N8
it is a little embarassing for me that i made a mistake again.
It cracked because i was to carefully at drilling the big holes and used the drilling machine to slowly so it canted and the plexi got a little crack.
but i want to show you all.
y3mUGvGBtpotCQbtyGpcf0WZv6huDEbfgVIuBHPhBV6NPu5OKM8GVFr-F9-oL1J7jYWfZP2lBgcUShN94rq6yv7r-e0RMMwd994hAnyQdIDF-c6l40hRppLnn9_ZvAY0rOzvqmaG7QUOf5z9zl5BUoFYrpTtNLUZH5GNr_6ctwcmcI
y3mtGGbW7DSvA_Tn29FKYBZ7G-NFNjq3JB2kH9dDGLKtD2SnbOwzuvNoKDCdR03a-StQ_gt4QlxjxUrmCjhCFXxqEOHl-kGK6-4GAcWiwMoOhE6M0m214RpxpYwpkVRSoDLKGEzyTJ9prh1eK6OCWuFrHLG9nQNdYhhIvfUv75EMxQ
hope you like it nonetheless
Benny
So finally i can go on with my build.
Gosumodz got the tools back in stock and i could order them.
y3mfQhAfIGURDkJE4113wLn6AAzlZaC-jjMS0XZQgstO1WBJYYLnKAhkZaM7GbRXoM6cBE84_iLX-cm0s3MmfiayjNYH0OYG7KmP1uzBFVUPyPDYYs7cUkyLFrH_uPuagFvAV6-ZOgaOPaHEa2VaavDFABFRiZXHhJNl7fpCeRXfg4
my first time sleeving btw, but i'll give my best =)
Progress =)
i mounted the pumps and decided not to sleeve these cables, cause you cant see them at all.
And i made light test.
Also i installed the top fans.
y3mck_b3DBnkjV6U8jSHar9S9abtaX3b_QrOJH6lb1k6eZri1zl_wIwyc4SvT6SGrHJCnvgtGCayt2fJoZGiU-dFaEYokRKDIGzLXIuFuvIWKtetSC8bujgkZzzizpe8qvxAbYieFtqkdzxstVB8uo4iEb3Gj7zLCzUiDtzcyHGl3w
y3mLN8gXXjilkOJ9eNnD69kf2kWPo2U6yElsoNuUO2si-aMQ0F0JegFNFFGFS0dqoPbgPACQurBiO-44Ay67bkmdoKsTF8mzG_82YMIZFugkx91fb7nN1Wvkx14c_PGN4YxstgFv6y78oTQRfF-nsrSjPhkGbQwkA3nW3XmbA4axMo
y3mnSMkUZG5ZPdxOmW5ZWw2gKSpfpVYXLqQtJMMFrSmzTMB-6OTlTCu373wMFRmqyVUdQayoNi3S3MeT_jh6qgrOaO2BUog4kQ4R7KddNILo9lzilHoU2JbpeamIVyIyjmwaIKoZKPFYTwf6MQtfBVRj4HeBN3h4HUir_b56_5XVhI
y3mSIxH3k4D1b6Q2U-6LCrdI-6rRxgh_3DNrL_Sjd4O44CKSb8Ldf1_dj4mFe3C4rYvwXOB21JxnpF6WWbtHUYgPU7m4FGzYHH7V7Nm2f02DFMJI235bjXPYsor5JWOTJ9_q-cDmTjcVUPEWQs4kp6E3o3mhmAVfNA1Vcgc49jd9Ww
Then i began with the sleeving.
for now it makes fun =)
y3mVNnc1ysl-Le4xt0ola2y_wmK9dNtusevUlzkWgvAMXpPX_M6DRvKKnfx9huRWzQ03YwIeMyZR5qF9zqfYMnfMaKRGpvF-WXx-NIuc-eaWzxmOfPLTircQ3ZY4QJrNRwvaXi0nyRONrBHoYUCMrMgvE8H0WafnKdleLEPbSOTRQQ
y3mv_aJy5QiJ37Re9AsQcSeIv_5_M8jUEA-yV0LzDQK0DhTBiaYYyeX4JjrXB1tXmG3y6zeLLYD7OztLmaYX1NRHNUNSC9mzMgmj8IwGKqdpfCgxCv9t76UYfX50LpMR8NGL7Om8cHRTa7H0FI36kg_QteEB9Vs3aZ6MTpReLJI0rw
y3mR15qpb-Rqyo9M16GV_8xcoq75RYeF2qioX5SpGeKqmKmGE1ILEjqGXvBo5kTEGOm92NebpAXdQBR6S4vYt6vvZPtjuNtmus3uhwwyL_AgSU7dp1uWk9wP33_fcZKIOsnbVE6OXEj8bSrazxhA9-lU28NrbYBDMU7sVJbe9y4Hug
y3mXBl1kgjSjRjLSxp5tq9xvoAU0AGhkCYeV9ntlbD69hroBEpRjmF6mFivdH4RiHWV7s_Dy4lYEiuDLUIi1RhTwcaIWPfeWNn13hLrwwOfJhpPnVDnyK_sHxjte-N3pDut7dILf4sBbEhSutsr7zEKGmWEEZgW_vl25zwK5VT5h8M
y3mMu1rk9NUWnNBsiYrMyJmMjRcWX7EqAh4Fwi3UwUXyiTOfriccakF0wm8YobKM7f_Sk8gATB4lzE52jFSkNXROP2fQg1P9ZRw41-5CNjM4f4vx-CjSu9IApOw7R_hG2SwMwdrgKZADcQF2uqrHI_WPqymyQ7eExY50x9avGX2RsA
y3mrbBWOElMeFPrv_NWrpMEZa3FJsBMKuQFx69TvRjhKH6wbTJfSWJmE2QL7Q7N6LxSBhLnp0qAm7YZM78CUHs6G1KGWI2W9XSBAQzdr5KGS1MN28DFJRIoG0dg8xtdxcXRtKJwP7aJ-bmi_ms5rBj03OK_THVFHb8Uj4Nj_d9dTAA
y3mmb_Tprtt4mACD4rde4U2jjMxI58UG-hWUAIi_4-Fp_auA1eMvHG4d8-sWXstxSh2DBlv2T90I0ZeyEROFPrHg-d8NSohIqFE9cA8kOpeqVquoVEFNpdu4M7qodAQ8O94cHSxH0EhrbnksKqyUQDoB9sUZ80pBRo3zI-hSdaIRGI
y3mTQg5fpmqtP94pVhV14ejmMfmMv8VZ2s96LpWltm0T65ljwRIscNgytuhodj0GamzWSBPU0Tqs_2F-DjB6du3eweKG9y_HNWDzBfHcxvud-T2SneueqbaMJ5nnT_fjg-5PNwB4-wu0Bv_VDcSFXGqKgaZnwU-LPDNZXdxC5WF-Ow
And my two SSDs arrived which i bought on cyber monday =)
y3m7YqQ2vQL2POinRLNjX6j0FlvJ2fL9yuSX58KuyRWDhqG-jv5I_KayjhlytfNX4M9GqT2NJ0uZoQ05LXoSiepaWdMuj7blBbJxLIUS1w3_nc182vSFstuJfDcPnr0qS7Z6jS8QYgPZ39dsvsDtoH9-sQD5FioAs05r-iWUoqYsW0
stay tuned =)
Finished the sleeving.
y3mRR27hmccAL60TllkkmrVKyPG_E-wM6LYC0bGhcwUCY6C5nCdFJC6pU6IAUAVDr_1dgbpim-O1yKU30K4YwShRqHBD22TSf4xJgA7bAxMmizXxaMUwP69FRAJS2OQr-5mozuRiHspEZmrvdXkg73S6sOqScfrVtsn7-vxouosUmI
y3mc0nO3fsDB4dZ1BPdWOe8rIZEqA6Ctfzu0z6h1MUwhjCqw4F4bPLS-BL3f4ZzJzDqTfREdF8aFrSyxGJAPGSrf-WE9wxmbLirV0eCLJQUeAxDeeH-hBWaTRpmn7LVyZ59SQU07qkx7DJ4MxkXb7mzkh2Ay5RPpayV1qdQ1ZT3LYw
y3m1LAGlYX7hfpsUX9eCD8n8A9rkGbvs0OsidD9pHMGaZ7a_2ybcFHRbMz5M-rbaiXWLfy5qXlI1X0PIeVu1s6jZaiv8E4bSmx_RhR7a_5C0spKrqmnlZomkAYL4xnm_tdQOTDCWVjXUHexsqIhTJHyYdzPG9891pfWrxg4pHkM8Ms
y3mRXt4NzHTA8b6EUmeiKq1UOZcNevsrLY8cua80b-JxAt8Ggh2U1pQYGvTxggqWT26LmA8VsYepk4X-WXMQk6vm5HpMPH3T2sD3u0V2O-zsi0YfbD7-H19Df5cXLmWf4J6HL9na8e8jtAtR1vl73mwXjZZxV3R3DRoidUJopvf36A
y3m4k__x1FYmp6HlPZT26Ed3Y5Pnx1t0DPNSKhLV6L8fml3RGzYdhg43KhvQKVprvOXktTKROKhKt7rN4SklMWwS_v0WZvpAOOJtEmRk3WQuEGz4kqBfiMSohBGaZUUGrpXEyAGaVqvmJop3fC1Mpyjmfu247JZk1n_zG3X901dsf8
y3m4QIWUz4mwPbtyiBVBfav3P8pPi5CzRAth00jyOrK-ARmk4ASIS9Box1L0xlAiUO5KiGmjJLfbuBF0V40DlXMxCfLs7bfB6_joi1QI3_5EzZFfrq1vesmoAkM-aZ6j8t9Q8rfGw0PMON5p-b4E1f94-dgRzAnEiKnealulMyW374
y3mzwJBm3yd2zzkq-I2L2fDd8Yf7Vsgrv7na03pmcVzdk2r1zWZyzn1coKndyAE_iRYzCghT-QNnE_cqkJb77IXyWBqOTpMOSWjFds-llJRndrWd8nPjTb1zm_qd8Ie0eEELbvgGoFkLaNu56NErEYdwn6Be90ZC93kAZvyD_XV428
i have to wait for some cable combs =(
in the shop i wanted to buy them they are sold out for weeks now.
So i went to another and ordered them last Wednesday. But they havent arrived yet.
Next things to to before mounting the waterblocks and make the tubing:
work on my new enermax fans
flush the radiators
and think over the routing.
The colors are crossed.
Left side Res is Red and the pump is white
Right side Res is white and the pump is red.
I took my new Enermax fans and disassembled them.
sanded the Halo-Frame and painted the plastic parts.
The assembling is like lego ;D
y3mxJ9fzNdyXYIuT5TYqQ9Tx5oHYNWCEljrPIMlQyRSCTSWH1FlqozPgYoSnNi6trjK0ysv_84Sf00pZXzS8hKnRbpV1Ao4tZ-lbfZLbImnhdfrruOPQ8nTmqCw8cbHPd46VyXq-ZIa8IU5KX4CRdE9PjIf56qKKT46q8CuaeU_Yjw
y3mrm2kgV2KfMJYnAA1WhkBUDOoKpo7gzvzLENEgmgDVMLP4SG4kSMDNWYolw2iqMCTqIA3qewYIVcaYVZTRoPa2C7idw1PWKglXYBaIHA4-gOkziN3uKaEc_xwd0gEfn4qESg0HYqdKDPV7r5TIvmL6D-ILGnh_UaOdXBu-ns2DgU
y3m3a8C8JIPDowrgFsfjs6FZjE7v9-rWFXCLNAQT4fChbAgonYb2Kr8tFBEE8QblePpWSnbcx-vo76J4B2yHE81e9RwzpIl7CvrTXCdE0dINg_5oovY7PFER-7Pz1HDv8XyuhGbnq3kQ2-LX3NRdVKy6o4jjHwldxhxESQQZo9gkEc
y3mwVTYjpuWr0OREcfJ8QCMNFsAoXXfrZKEA3P-TzgYGfmqZGajBENw39aGhIQwiWtdxKG-YmL1imla4mftT1erhF1bk35o3zJflfiUCHZe9QbjkEWsXm2gByxroQh93Wg6ZJiJxXgUSmMxa-n_zr0OZGfFQ6QRyC6vQ6DfIRYbLA8
y3mae0GFee9CwdlYfnfSK0liVScZGJ2DEoR9XgMDGu7-t-9_IZmBAWU0r-W3p2SPXJQABLygSHS31GpzOyCg4rJ3ltFZe2VV7Ehweimo3_gcO-KhbJd0r-uVznPjw1LtWnWRSoXzYG_4og1jXZmy_7s3UKcmD64eUpFRzSm76uTmmU
y3m9lo0imgBkr-ePzkK2Sxn2HSVo1e_cOQLaAvn0sZ4ovzIwakJHfaPOHUUzTaCmNTAHTh4QC5MaWmjt_yjW_xj0szdYU0RrpW_2BAURMOUtt4YQUxW2JOk6Sj0UtWH2Ap4s92akuB2Ykt5lDv9GFR92Bx-YEnKYh0_LvGhibdJ1e0
y3mUGlacXjUBB8FZ9Ev0HEzPYzsqhgweRcGx2BqdX5kYb-KxLfEJ7y5zHUX8sjXSstYqsj0ls1ih_Q-WFqQ77FQ7tk_EnbZJlYuv2oIGop3LInpCDoV9rx_hKSx_mzpXllsVryon8Hf_tR0kT-7DWD1Q7RT-Jdc43i97hmdfv_HbDk
y3m4QYqvq-H1YCzss83STF5CZpHtyE04EUbNa2zWYtuTTc3qvre7zsjOUaZpn4E_zsdFtk5xBOPN9nXfh2uv_MJ8UZdZIDiPBMx4y1wLnKkZ54cxxeI2sW2mtaJrWLj0m_QanYCRHREmQehcztMCvAWvCgHI-wC3Tvld0OBcMBjn7g
greez Benny
Another update =)
I mounted the rads and the waterblocks from alphacool.
y3mIbSPwjNkr_JtqRvXhQvowsGx22LzqugvQ15znsdIilryFqi4gLXCt71AZaK-gxBzrC44_l7nuvH_KJQ6oY7dUHHcqSVYTik6uhCef-gYSR63bpteVzZF02OfOnePOk4XtpU23d4LCYRfrlEMrQg7prrvUugCktefHGbCRJSiD1w
for now it looks messy in the back ;D
y3m8yOG9qE0LiW-Rli-0CKNO_2jYNKZpxFds4uJzNI4EKNrU2rVTJtEyTUivzeu9nlHN-XG0k2eVXnxPGyZK0k16pnw19NRaI2G0M9dvADsV9LOyp0h5gDd9CsUlmTMEr4YKUaygSJ1o3dNEC1b6M8sgavbznA2Z0aFpreXR-oduTU
the SSDs are in place as well.
y3mIVjzCj5wH6vTHQ5hfpPsHpD1oyVfcW1gyhE0R0lxQJddQTZHEQdA0B4Pt4ycpoMckdIxb6ERKhdteEB4wEb382u3FCyyYvVB4OMgRBtp_YEQoD3XpBRAOFrMI4NIUAdMQe9L97ChttdAdGjrsI35lDMwr7ZjLzteTP5BSkv3gCo
The GPX waterblock with all you need.
y3mlRe4ImZOGo2xOhTf3x9CyZ6Os3oMA-mCTxuJ_AqfCli_jpwNlFunsFvw3ZocIHL-TfEU8e33zS6lxxH_0AAQHsVOZ6WHWe6ZA0ZZdG5s0BBGKNqFQmULp19LFBQUENRiW3mkyR70Tsb8tOzysvLapyvfHDrOQCAgB_BP7r5-lTE
my dusty GPU ;D
y3m1ePcXo74ogiZMRmyYc4ZT2rGamwbW3Cd0YDJceNzaOZbWR2kIjwoHVgqbbjxQFcAzTdTB6X1VPnB3KcJtKSeT6wZvnnu-CoQSJ6WIBLmaA8zi41TrXH3v0uvfYLoEjATnJdo9Ywz7ALCj2epQACzj7Fb_Rw0ATc5oL6_hctw_LI
y3mUAQ0AEQ3_rrPMvsoRVp3lzaxxqhxbFCShZ-FZtFQxgh518nhtGmznGQKXIApqvv9tcftLPmZEqaKe7jNzmV1iqoKgY3fyj022TGj6GjZreGFxxLl3e93MdxCZaINwEeMA7n-AC9O6hsYpi29HcnHgGdCn-ahV7LXOJcFrDzSjjY
y3mBT_Y3pqBbJRQPu58eNxbXr_Zyl8grZFlBzk4BYRZ02ceITQbINk1wWJQR7gTjRiwYLwbbemT9bzCN26Gs1Omr-r4m32vd18QCmDGJxR2NfXVVWqz0Sxi8rklVMNWBO7jd4xDC-LVxmm0XJ3ljG0TAMXmTIlhT0c_dV3gRHNL2bg
CPU block with the "Eiszapfen" fittings.
y3m_aUNveNCVtoS1T60DfJZAjQLeT6bcgwrRdhnBmWjMclWwVI_xuvA7TMFElKQM4VkaqH4SJgykl5KWKxKNxVpJBN8aKRgN-Jm40XV6aTfwquwfdE49nDuHXL6HWvRNSmgoc5TvjyDgS3hdLJ_pY6eqWzZdJnoTVe46bnzqmnhGF4
The DRam cooler.
y3m4lVVhb8W9Bm1RHxMi7Q6kSEMBmJRiRxhXUXYw5DSUHisGVCawcogPRsWxbADDbWr3GrWrxfZ3Q9mP9w85AIqubB-vXxToZOFArlvNukFAVaQafO2Qxn92Oy2i904ZTNwv30trNydFWqPXrZktb7lrP9xgoSifWVIqtr-pqQA8GA
y3msnodva2l01ZANUUO5bI1F6bMsO1CvdPnJmlyk8dL8o18UF_J8kcjIabPua6dSgs2YvQsFbRWhqVxqtrzrUcj8lz5ve22z1UuTtSMjCX98qdyOp8TAiI-n1FzYI3kHFrhp-KatItEp_51kFo_3tGg97sYUUKxHs5wFaT1d8eE-2E
the screws to hold the Mainboard.
y3mYrJyVJthMAQLw2JZsILkbq-kikhnSqHcoLDU5LB6t3S5hKk4Wnivgda0MHIh8nOeINEb3RHqU-3b-DaL6GjAsgxfwhAGAHD67y4QTC5bp4ykI1msHkzkCvPB_iSnVzZe5G0CzSeZdQ5dUnCWfOfKXul6clxvWouTkJ5MZ2gDB0A
y3mWqI7gJO_l8mRoyfVzBrP-9M7W-_9oKeilmRnvwlNGmVPmW-10S1-ds0zIN_X9-6UsfEqkf3c-3lwEXg7pTZ0I6sJiNsKOLNpygSZJSaTuoQb5ivrxKzyq_nEpsR664aRLKL9mlJPB7ylVGHDzyFKiYTGAVNts5jbchqeY8eYYNc
y3m_7v4ZqlEiKMFCXVZc14zRR26Rx0b7-w4G6AlF80snWjmSvr36bSbURmDhIyTTcrQd9OumbGXHUKJ4Fo6DjBQnqRNMZJiLKVVXQvxx01QOsUg2T8WAc1rd5luQfFnZmFeIczFkrTm5UnNU-Ve2Mjt6XlCaVl6rmoTKg6SHYRcz9g
y3mf4ZFh-348CoYjh73VRC0f_m9w-c69BoWUqSi7qOeMOlr1Y5LOPMUBtwuja6D69P2C7R44o0S9spyyu7MSll1J3a49OK8RZGT4bggo-eRaXSrWRwePO7ysFPVzMRudF0huTl2S9EXHaMQZsE8wSZH1evg13AotnkPOsAybXa2BTU
y3m3uWglCDSpSOWOncU_v9juL4bPV3ONQaL8H8OkqwU1IRTTRCCDSDv19ZEoUf4bi6QJfbISuSisFb-Zeg-k9fa2xIV8HI8vHUz9DM8CRwu5A_tvqXsXpfU5YA3ILdp6cfrCluO-c80kAmFdjN8GU2qcotTDtToTVxKSAVQ_C6Ikl0
greez benny
I'm back with another update =)
this time the hardlinetubing
All of that stuff goes into my case aswell ;D
y3mswc4bDUv4DNpuvCODuB8bW1F7JDW9R5RyFl89rCXkKN1xD_dd47u_WDXkeIF33NgRHvDVX6SB8E-RyR6RQyeHcS0zKsDaM-egQLJkHeZ9-3HrnTj2HR1bDycgDNvaxhs6n8Z595-IBfSn2h_pztQLhc-JfpjqDzZMZ-zZQ_zbUw
The first connection:
y3mYoBo8xnBg1L00Ev-euaxOmQhuSBXh5iqlIHpGp7w-SkE9LQRF92isB0Le41RQgHRDg4BN-YaeoZHaP0mamEfz2BoIOflIvKJ3kpB79rgraNOjSEigp-5g8RAXn69rNfmNkQUUS7OXzIvhZ5XKveTs73kJrXjJpn43B5A7LpM-Sc
y3mWPjDUEuolGLwxO3EIlYhQN3gF7fX_rJhWOz_Xs2Dck_exbRrfqp0xrQCzDhgsPI1jrqIgx1sEAeGiki84VMBEMDTqAwtmGyqZ0OqdDPVGNj1qjECdXMeA3LZr2N0DEWserQgj9vN0fb0fGiwxc2uQr_IJjrMF5YqWTiDpM2Dzjo
y3mX9ULNDUltyE3wdT4cs48aqRwKmLdzg2zsqFu6nIu8WL86lYpPbguiJrVXBsB-VE9tlsLrJpp_DZ3XZwue5DLxyN7B8NuOwFdhe3uoY_bFZXS-N4T1X6G5hBernjXiS0vDhqkw8wgOEQ9qNDZF_muQBBdIuQ1uX35uwzO7LnDu2g
the first unuseable pieces.
y3mVEAlNtqNzw6kaF1fgxynRdt7NKzgXRMLah8Oc7rDFwAAIyIbijP2uQfoVOMZG5sPu1vRVeGTq4eE7H6q7CcXXEfFKqIxQe1NqjkPzJgWRUZmG_Rk6urLP5yVLTGij1lS9DrJtvSMUukKY9Sirr6erHg3F0iRseXfwFepKBzGN1E
took a threaded rod to hold the GPU in place.
y3m6O3bb-q08u06mA6eW7-uOCvLv-u6QctURdj8v_r9KPMc0Qi_f8koHFd_WDVksvki83YOPEJFrxpaeO5_gy-yyuciDfqJEs_mZZ55R4OuHoCFhys5rEy6PsZm7qRzRGLtfNlRurWdjTXv7bZG4E26sVOGiffbdR7jxjFIMY59WCc
y3mdBAop9UZEuy69W24n6Ctzye1e9Vc59d9inM-Mz6x0vKh6hXb_p2WmFqgyQz2TiPFPC37PqvEVAxV13WmTvSHcmYUgYlTJsBlwYPKpNwnuhzSM5mNf-HHxpPrlHesbpHG3F0dc8Ez7l9eIdz4mzcLVMlHcD46czQh5q8Q6cLNDi0
y3mK6fzyIVLyePkYLjUMIeY6TCzoFDq5XpYX94XdEsOUvvhh0o_fgCJYmLWPjFWjXrP60i17JpEa1sYyka9VWuS082gQBr77OWtQgFnExxjO7S7lgngNEmghwMtIps5cl7kme-_bbduyVIu6JArxHuonGXrfxSEobH6YHi_yiSFrro
y3mPtRm9UtGk-ort1lrmvjLR8YndLMfWJWMZxtW4IcgnFWs4fOq20SEZgI6kNMoBSEZ_epHJgPysl4V7Kb5yfoFTxK32JgTIDQMMCC45wgCvglya7VcKiZQgZiBUnabu6F_7p8H7lP3r92WOsxdMOftuuSZM6-_yAfQdtypQosqh0M
y3mB1q_-dRse_eO--NVMYXIJgVt2XtZ1Jg47b_HWmZ92HIS1gBZU3HOeSrxbsjDgI6v0EkYOBxmgtVfmhnYHQMrJHZoYzsAe0QIxhie4KIiBIv_SGFFTXV7pchGQ_lqrIj-mrnbYMuFAbR5MnU5ALKePBhgbkmMj1CKtai_8teQX0A
y3mtu2pOVUHqA_6ZTVRz6eTCr9DqRchU56yUOeyk3KEjQpP5qb3vy7eD65uBIxgxEfUNIpkF9ZzlSuWALfb57hTE2PVyIk7XIZij4liGV0ro8slKbDscakszLGwc6i8ULyiR_oDtXV3QF_VIYd18Xm_f_Jn6HlyL1SxH9J9sAoEgik
y3mBPW_FVWIEpMxHlpGbPxBjQglZZ1imeIH8i806u7f8IB1BRarJJu5AxOeq_BPoTB58kHeVkSasYdql1C4Jq1T5CJGSynbMFUFRhoq729lZ0Nf_yXQeYJKS6SVHOxddu-zW3QVsVXqlK9hsnOvOym40zXDEMuxkMi-DBzhBL6g21A
This was my first experience with PETG, it was more difficult than i thought.
I watched several videos - there it looks really easy ;D
here are the broken pieces
y3mmXUBLeQhWPkF3xl3NEffEXGkLM5K4fInJ4rWJMKbeSEv3s8qjRsR0NufH4uWhW5sRhiIfk1sFqGKD8JRI7NjPjt2neGmZDqnZljsKGzjupuD5e6VA8V2ClaOlERI0VMTyqUSehikXzvJIoUdBvQ8KItmsuVRZCF2pI-hPXkMX0I
A leak test:
y3mr6_Jk1E7sHBfrZfGuoL_5BweL2dY6YHaMx0fDM3p6gKZpMuZ3oMTU7IYXuORsfK4efn1hB8x8SS63N3r8F5KITFzIA0M8QosoAc3Xp21RslBgChFXdHfbREHtUT8UtIVvwon-GWMXqvZBYRgpCDgcUrd8JtatGD2NJGvPslXTUU
y3m5kpcIdPhUZVmG6agyuSLEm-Jn7XbZHduYAP1JeasrDtut0EKt66Swa5eavUwQZvYDQhNAcuGJXz52z1qrM8cn0EODehSGC9TEC64QDJ33uikQegZgnfxQqO_YXqzcI02km3Es_6VLh1_8W55CSIL9AMjB7cFkNhnlViev5EC7Dg
y3ma1a2vKlwK-Dfq6emYbXu_QJ_476pyYfTMd5Qq57fX2SRTcm7Jl0ubInk_lnQY6NVs3CgvZm7-G_rkmMJKQAPhHD6PxrMob1JMXSKKsClr2X3QUUS1U4ACC0XflYGEzfgXfdGy86rNpCk9xoPNiudlAzKSAPsqRO7gECpm1GjKpE
So i've done around 80% of my Build i think.
Have to make some other things aswell.
So long
greez Benny
New to this thread, and just went through the entire first page... just wow... Damn impressive man! The hardline work looks great too.
Can't wait for some more updates, i'll definitely be keeping an eye on this thread! (y)
Thank you =)
Hey folks,
long time no see.
sorry for that.
But here i am back again with the final pics.
I made a mount for my Harddrives.
y3m0nWnJGrvd5EB5mSeUrV0WBUsx_A5XFD2SN82aak7n3iQ9KymPipaFi7R9RkJYP6D3g6QKhJXOkOWHCHrhrYvPj0ETwzHH05RwPA3InUn6DIoSVs7xvdVQVm568xfB8CD26k8HnEcD3s9ywsWQ70Wje4AETddTZwMR4VOcfkn8Ho
y3mFMm2Ob5S1yVYyTIG86BrXWj7NiqFoW-tsylQxcg3If-f9ZhJuQ6rOAi7RmRwuaMU2P-bJ_xlHLj2x7mYRdLXeQqtQqsW_Czd2l4NgGDoykLKUBoTQo5X3ZRwlCGdvOQyqf6hoX99EB_v6zb7nRAA2gGmW4BBITermPKzIqRifpI
y3mKTCipW6fFDFS0b16L-DW-aWY5q_47XonzemnMoned0TA1UZlNfr89v1PIev7CGbh3g80-sm6a0yEEJ8AaW6iyyqj7eEovmN2FsY2u21xO61uHq57ppiHHosz2_6g4Y5UYfyTdEKGPoNL48UG-DMKf9IZ9p962Anh5YzJwBz1HQk
And i cutted the holes in the backcover.
y3mdKVKBVfs9MKuTrZDKz23tzuNsc4oxhJcyW6fxMoDAJV2Wn_IMX84RbImjUV78r4tiqQd2uUah2Pk8ANcjujfUUZJQHD_vnUW1eCxxzo6uNUMyoKa0e7aHlwuL_PEXMRyWxh1ENer84NjWDnKcKF6i77SvBZhjvExahdfGbxpLME
y3mqHQq_PJ6ZxsjB5nEq9dfUskwoZW9DHqL66IvjhyvnrF9TBmiANaDglQKTViZFtB_9fjKXK8Tm5zXUh_m39a787eEn8BNqK78nnsoUqO2flkKUEokZJOpaf-1-VEDYhEArjWRYhiD84L7UDpAOpJIVZt7NHhaOrDE-ReAgh1dC8M
y3meViDJgCVFjePVtboNcle_CfCIIGdmxx5yqugHVZVTUxfEId5k8dCHC27qL96dWyMzPHgEIXEAy2rMUYW51cVGmT1spqIhKwH89Zj5c8xE5cDBTve6crR7sOe4DYFHRrtFsoyBwcoaMQonuBH-fnNR8IepNMACN-s0uqnO2hmbbE
Here it is placed on my table.
y3myW2Vh3RzqPxTee9Ens9NyRX9thKk9bjzshizHNy69Bzp9kz_QOe2UvmKCbJQgV9PZxUiYmT0VNn8MCW0M7ZwZKauhMmpTC34Hg3opa40qfHr84i5cVG9lnSefydMCm0pJiU0_9f8nmuj2mSUhs-QDBhz4TupjWdumhGC2xqk6ck
y3mv9UeueLGXUuvNNAa8LugPD1omGU2uX8lEp96QQvR46o_50zmjiQ5-mLU9D1XjklEPlkw-X5cqf5J-p-I5eETTrT1KLNI97hiu2jINxHg7Im9GfDD4NXgBc6vCfZHNIa7DOQbBcmL7pt-tFkF0YyoCPjTi8JwlMcjnSmyp7PerMo
y3mN-16jNmjd-nJiCKS1TxcbUXdj-mb1mN5beqNjPHLk1SGN-yke-1awaDoIsA4txj5fwm_Z2zZ6oLYshdMLFf7BzzY0fUUpBnB6Nwwn9xYr-aNo72jtTrxGX1L-uf35opjQ0PZfsOuOuQ2XnmtpUFqkC4f4ewB9mffSV7xfhFMEBI
y3mRL5hJ96w4pVl5Shdx5NEA2Q6oga-0yN_4NOgj4ivIXp43DrxiWmpm71x3hvDF2ELvRCeRBcVR7CE5UmZpwdXm7E_3BWHN7TEB_46h6kumQUJXpexmv0dcua-iZNodQWZtYyH-pC7kQQMHjv0yzm2YuCmPQRqTfXSV3LgWqbVLFU
y3m1M8kwi6nlAQTOJH_kbnHgKr7K5eGn1LN2X6Hl-yd3VVZx-CMY14ZnL0oQLPwircLLTv9wIqpYgNfDhk5jt-gIYmAR79ygUu8y6115u4Zk0-UprET5c8XcfJBM-jIO5tEeZTZLEt-BUHipnMvf3_QTxh32UK4zpq-3UthousgzYg
y3mAknSXjt52Rb81F-tUgcY9lLpGKF1m4znebxQ_JbnUtmE37kPz7rGR0-5Oba3oe1d4b6I-We1VN_kvHK5Bam3ToH-hgfhcNWkWxHL9hf9lGw2qXct1qbuao2u-cfVYSjwkY0vQ7GVHxPhD8O9dP5RplYXE1ELcsWf4WVTd66uH7U
y3mDm4dMFt2zWdC8Xjx8FAO8phXfNxb01LGMy-U1BX-gjR8L2sYypmld138_agV8qBAFQWF_KpuAw4EkvWH4PfDjvshgLYEQlIa6hiKSu9HNsQmJdlDksnnKwPI6cvoPr7zd8WE7_HsLuZk_0SA33Q4SWZThEzOFJl4lns4YEiydrQ
y3ms3-TqOw5-0nVW6S12HIqWYZeIJMzvKauY0vrBnfw3iOZTQm7tdkRg7DsdBQP6PgnMaDDo5ntOAYNfW1OnbFKkjXl87HpJb15TEqouMAoZOEif8Q1RqFb99OnknrCijym9YPSYf70wS2NgidEXZ_TkB2Dw5hJQuJ-oHJCWPl7T4w
y3mi-lzxO9z2aLIneOMw6EQtylxzik2SpPueOa17uKFN1ipiQYBGl0f8Q5w9_8uoSLNjmo_oTbBzyAnOHdXkK7C9zCKa3muCo6CBm9DNH2Tqt9O1hE7X0DldPfY9nClGDghswQZw6W7eonu7qmK4y4JXhM0BrvShDyM_n2ZePNSE9o
y3mLRAZbvk2GUIG6L1cKuACcja7-qFi-CnsUN60qaeNHva0uXViJIjs117U3NFDbt9Cw-LKNpqJ6dy11NdMD6QbAL3cStRFbkOflvK-izNXZ6UZPO6ID28lbBvy7177fV5C0QDHrUZGf3amIOyEnCXMiF8SUCFyGZiYNdpY4Gait3s
y3mgu6ZKHi2FJqJK3K5HaD3hzBPf_P01Izz5LLktRSWtn2Fc_vZ4KdovV1FmV0lF-gmnWWSlpauBeMS7sGieXFHJ7ZtJodpFr-EX19jAlhR8ZTprib-qv2UrGcYTnsNLnm-Ysq46e5YUM6EPVO8v2Ojq73B8VP1vzR5VrF8aJQ5iZM
y3m4ELMi-wfnCm7F3h0ZX0kJwuNyHLLrS8F8tHJZJD7V0fvQF7DWSmrqSQC6r0YOMdfExpgCUbOgmu370-y0n4OuNa4RN0kHfEHEO4pIBj7sYq-7oMf-UFrZx41NOeN2WrpJPvd3iCV1auVRSObrQqqIMytbsAmFb6OG4dSW5hk1gA
y3mHHbWFGy2UaM72LeXEfnN66OBs_tb-UiCKsn8J2L0Bw4Qcv3rkwpQv1kGUHYUTzmspTNVTGvDA4pPdVM1r8FdEgIOraSxQKAlOlh3rOenu90FTfXuHbiL9Lc-9fJTI5tMg-G3cMjzGTuItDShEqY-hqnVaukqzMmC2Ogu2mcpGzo
y3mibtpPfZCrp0hICHRi9n5y8g1aC2d0UUzu9JAsAFUWPXMfXscgM-FeY9oAyWr2FaqeXIrM6a6-OBkYM-zCmvuUIkwv-N-8E6tIjDBQIQCwLLL1hRwwclobraaHA5ydGeEjLaX9dSVUStTwn_w_BAWuqVWdl7vz2BzOmcF_-ZLJFA
y3mNN6QhAJS0slyc3CiCbS5Z6GNmFYBD6qKzSFUMiarBEFruj0PqsaIrygOIE2kxsm72azdcPVM0WAhJpS5E6mU4NsoBDHuGuUX4xy5t2hfXgF6GddWpuAS8f_QPrp4KQOQzyGQEfED_wehCwUbzYG728QkQrJTVafL0qxFRe1Msys
y3muTi0fNJ1ByKPHJMhluOTqwFUu3fMDAnarOvTZ8OLLxYNIkr4I22fVkT0oMB4JGaJByZq2aWEYzbBn29Eu4eM7VI3r_1d-UQWkGF2LLtVcUF0TToBHFB1kgCnKexzO7z5SgsD3lJjPJCdpKPriPEJ6vvLpCQnvPOwK1XoX7FtGko
y3mvuFf1tSSIu1dtICE7SyE7dfgb25Tk3dbH1nHqAV0_JQbLeY4Q_x8OnS2ZyRfg9QVyLYGRzPXZYvUh33U2vy3J1GR0smbq-6fCJWMAeeSikVA1OCz7xZNP3pDjo3IID7SRKMUcZej8dhr9ezvRBC0NlCU_GwjFTS2KEGcjkmSLP8
y3mScgSO9Im6MIgKxi4WsmIgRvb1v1zxVLYKbnlNjmvU0ibU-AqmfBmNYD8nQdx74ngDzejRIRfTJyf6XsbV7dYPfTIV8dX9zRV8K8ukQfZM9mALVo6Lnn4CGqxznFJd30EzoSAGspk2KPxYPCpJnUYWCeGNVDXjFZOtJhomqs4Lls
y3m1XHXWg6Ushimmy0SiBuWwciJPCIkzNGo9hf8wtXBdYuJUsOm0c--MZtwdv-RUQnQh3LBy6wuT7nqCPAtOa1CV6ETMydqoRB5hmQ8FURagsWulKRng8uOaGM7H4FJgE-u_K1SU2WjCFs2dylNVRQqbD0xFA6TCucc4olpJlpyoCg
y3m6VOsIVEPn_zB52JcK1fEEXh4--S_02693hde2EHhPpMEJYBwCjvW0Mwq7v6TYQqZ96NXm6AZ05APosHLKm73Y6DoRecq6H2fm23JrXTUdsbfQRC4DYRcRkBTeq2M0xF3tFWeYumTFpQ9XdqmDD5jb2kfhfpthWY_lMVQCO3Pvus
y3m1RG7BxydApM66HNY_4qKs3KPOCE9K6Gn0-SjTMVlAxf15LTbvEp3aTG3kMgvVM4SNeLVNz0IGE9a6GBK5FkhwUABSKUYnBTky7GBL_I_gPDccd3E3qWwXyGH8Dxu38jpGwTp-jSzqYAzZQABdZxtoz0OUtY5bAB-tjG8emaG-yc
y3mLh-3J1nAmwZ-FhClKLxZEFtYEcot9QI6UPbk_jmEb2Uzxtka46KaNHvzKlOIofL3W6wu6JK6Kf-pXUQaNEpTVGFj-vUNXjxuTr-m-mk1p6bdf59t63DK3Y4rqgJrtZgozhPDGS-lcjs38w5Fc5wKu1hj8l6579CP1JIXDxFWhpY
y3mFfMz6yVeLQebM3lS7IVKNXl2N9FFyr6T8n-fsb7HFKJ6kAsRL_n8cVeAF8C5X2mXNed-QVN-BhX8uxoaE4xm6uzSPFPoB_AVblXbmr0En9PXN0OzPer5nO6KQWjWMU-qjcLwOeOOrwexPj9ZuprnB43xj7fsSrPSOOUy157UN_I
y3mXwFslepAB1PYajcUa9LPJvlD57X6mduHMbrfprLeWHAHZYGBCXN84IYr2UPmz3FkOUWFLF7MSugofRUFgfHuZz1yW_-C6VE1qaKBcxy5fEjRNwI1n56AY99nGVofUvzwiLtcb7zxVdZykIiLuyuzCukfBRGtP5gEAB5StydBBc0
y3mst8bQyQzQgpXYjhROcu-9-kse0F0uzvlrwy6S6ENFvgp4zNEV94Yje5Zvd-PLNcdyD5jqEE6miZU3TWQ75dUh0eMccVDXS_EtP4GA-WBEDpGxMvuMP_avOQrNUcJwej-HTXBSuGppcnO6i7GgNcGTYDpQFfcFvc4A0p9R5m-3pE
I hope u like it, and liked it to follow my progress =)
Have a nice evening guys.
Benny
