I'm having some problems with my ram, or at least I think I am. Lately some of my programs have been crashing randomly and windows will blue screen blaming the nvidia drivers for messing something up, this continued even after I cleaned out my drivers and re-installed them.
At the time I was unable to run memtest86 but I found a program called memtest which could be run from inside windows. I ran memtest, two copies of the program both testing 900mb of ram, and one of the copies told me that my ram was damaged. So I decided to try running memtest86 to see if my ram actually had a problem. First I switched out my supossibly broken stick of ram with a stick that I knew worked to rule out the a false positive caused by a faulty motherboard.
Test ran for 1 hour, no problems. I took that as an indicator that my motherboard was fine, so I removed the working stuck and re-installed my old stick of ram. Started up memtest86, it ran through one test with no errors, and a second test, and a third. Right now it has been running for 1 hour and 30 minutes with no problems.
Could memtest86 be wrong? I have been experiencing crashes (A good deal of them in oblivion, which always crashes with 'memory cannot be "read/written"' errors) so I know that I must have some faulty component somewhere in my computer, I just have no idea what it could be.
Is it possible that my problems were caused by improperly seated ram? Could dust in the socket have caused problems like this, that were cured when I switched the sticks around?
