school my backup backup build
umcpgrad
how did you all think I did?
phenom ii x2 560be ~$100
msi e53 ~$10ar
ocz 4gb ddr3 dual channel ~$50ar
ocz 600w extreme ~$35ar
1tb segate 7200rpm ~$50
samsung 16x dvd burner dual layer ~$20
wireless g dlink ~$20
extra 120mm fan ~$5
cooler master elite 335 ~$35
coolermaster 212plus ~$30
galaxy gtx460 768 ~$110ar
tax ~6%
good build? ~$493
The most worrisome and crappiest part in the PC is that PSU. It's barely a 500W PSU. You did ok overall.
the 560 unlock fine but anything higher than 3.3ghz oc with higher than 1.4v bsod it is running about ~30c weird
any suggestions?
any suggestions?
You did unlock that CPU after all. So the stability issues could be related to those other cores. So drop back down to two cores and start overclocking again. If you can get past 3.3Ghz with higher than 1.4V with two cores, the issue is more than likely related to the other cores.
cool, never thought about it that way
thanks
The psu is pretty meh like Danny said, but you paid $20 for a wireless g? Was that the router or a card/usb for the pc?
Never unlocked one before so can't help you much there.
