the.ronin
- Mar 25, 2008
I have a CM Scout and plan on wiring a cold cathode to the LED on/off switch that comes equipped with the case. Unfortunately, the switch is built to deal with only two of the case fans it comes with.
I came across a post made by an enthusiast who managed to tap the switch using a micro relay. Im having trouble deciphering his diagram and he is no longer active in the forums.
And the specific micro relay he used for this application:
Which terminals on the micro relay correspond to which terminals in his diagram? In particular, the NO (naturally open) side of the relay?
