SB build (most concern about MB, memory, diskdrive)
you2
Just games; turn on play games; turn off so lots of power cycle
No limit but thought was ~$1000
3) Where do you live?
Mass
cpu, case, psu, drives, mb, memory
None (maybe pull the xfi sound card; not sure of exact model but it is a 'good' one).
6) Will you be overclocking?
none planned
currently 22; but want to support dell 27 (high resolution)
Next 3 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Quality on board sound would be nice; ethernet, crossfire
Have access to legal (for personal home usage) wiindows 7 32/64 (plan is 64)
back ground
I currently have a e8400/8800gts g92 xp system which I use to play games (turn on when playing otherwise it is off; so it gets a fair number of power cycles; I use a linux system for web and stuff and that system stays on 24x7).
plan/objective:
My thought was to build a new system (running windows 7 64) and I figure the new system would accomplish 2 tasks; 2 to 4x faster and upgrade to windows 7.
The system I've been spec'ing (nothing purchased):
asrock extreme 4 p67 mb ~$152 or asus pro!$185
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157217
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131682
2500K intel cpu ~$190 (MC until this saturday)
seagate constellation st3500514 500GB ~$90
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148609
g.skill ripjaws F3-12800CL7D-4GBRM (7-8-7-24) $65 or Model F3-12800CL7D-4GBXM $69
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231430
(the second pair is rated 1.5; the first is 1.6)
intel x25-M 120GB g2 ~$220
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167035
(could go with oem version since asrock comes with 2.5 bracket)
lian 9f $128
seasonic x 650 ~$120
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
windows 7
ati 6950 (initially one but might upgrade two 2 hence 650W psu)
dvd drive ~15
blu-ray drive ~$50
admin said to post this when I am within 3 weeks of build. Since I'd like to order memory today I thought I would move up my build date; should probably build within 30 days of first compoennt purchase for easy return; also I can still pick up the 2500K from MC for $190.
Ditch both RAM sets: Lower RAM timings or higher speeddon't really help out that much to offset an increase in RAM itself:
$78 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
In other words, you're gonna see more of a performance difference with 8GB of CAS 9 RAM than with 4GB CAS 7 DDR3 1600 RAM.
Ditch the Seagate for this significantly faster, cheaper, equal quality, and larger Samsung drive:
$65 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
Ditch the AsRock mobo as it only comes with a one year warranty. For $152, I'd expect at least a 2 year warranty, average of 3. Go for either the Asus or this MSI:
$180 - MSI P67A-GD65 Intel P67 ATX Motherboard
If you're going for HD 6950 Crossfire, you're gonna need a bit more than a 650W PSU. I'd recommend a 750W PSU at a minimum but preferably 850W:
$110 - Corsair 750TX 750W PSU
$136 - Corsair 850TX 850W PSU
$136 - XFX Black Edition P1-750B-CAG9 750W Modular PSU
$150 - Corsair 750HX 750W Modular PSU
$165 - Seasonic X750 Gold 750W Modular PSU
$190 - Silverstone ST1000-P 1000W Modular PSU
Ok thanks I thinik. Surprise the samsung disk is faster than the seagate; maybe denser platters. Hum PSU is the biggest barf; Guess I'll wait for the seasonic to go on sale again.
