I'm putting my trusty Q6600 out to pasture, and all my parts are in hand but the SSD and a PWM Y cable. I have a few questions since I haven't built in a while and want to make sure I'm not forgetting something. Here is what I am looking at as far as parts:
2500k
Asus P8P67 Pro
2x4GB Vengeance 1866
XFX 6870
Corsair TX750
Crucial C300 128GB SSD
WD 6400AAKS
WD 1TB Green
CM Hyper 212+
Antec 300
Questions
1. The Antec 300 has a rear and a top exhaust. I also have Antec tri-cools in the two front intakes and the side intake. I am going to push/pull the 212+. I assume I want to blow toward the rear exhaust as opposed to the top? Sucking air over the ram, into the hsf, and out the back?
2. I've been reading up on applying thermal paste to this HSF. Sounds like I should put some paste onto the pipes, spread it around through some saran wrap, then put two thin strips of paste before putting it on?
3. Is my ram going to interfere with the HSF on that mobo?
4. What do I have to do do transfer my Win 7 license? I can just install Win 7 from my upgrade disc directly, right?
5. This is my first SSD. I feel a lot like someone who is buying a puppy because it looked cute.
Are there are good guides on what I should be doing with this thing? I'm going to do a clean OS install on it, but is there any point in partitioning? I will just be able to move certain games and programs onto and off of the SSD when I want the speed? (does this even work with Steam games?) My intention is to use the SSD for the boot OS drive and my most used programs and games I am playing at the time, store all my music, documents, and other programs on the AAKS, and use the 1TB for deep storage. Is there some way in windows to just link the locations which would be on the SSD (like My Documents) to somewhere on the AAKS?
Thanks in advance.
2500k
Asus P8P67 Pro
XFX 6870
Corsair TX750
WD 6400AAKS
WD 1TB Green
CM Hyper 212+
Antec 300
Questions
Thanks in advance.
