Save flash to pdf
I need help with saving flash to pdf. I have tried cutepdf but it does not work for what I need. Any other suggestions from anyone? Much thanks in advance.
if you want that flash animation will be able to shown in pdf file you can use AlivePDF. It's an open-source ActionScript 3 (Flash, Flex, AIR) PDF generation library. It allows you to generate PDFs on the client-side.
You can use AlivePDF with Flash, Flex and Adobe AIR applications.
Hope that helps
