SATA question
TheCommander
Would it make a difference in speed if I put my SATA drive into an external enclosure vs keeping the SATA drive directly connected to the SATA port on my motherboard?
If the external is connected by eSATA, there should be very little, if any, difference in speed.
yeah like Xeno & Hippie say it should be good. If the enclosure has a separate controller inside it that interfaces between the HD & the SATA port, it could introduce latencies or even throughput/max capacity restrictions -- but if you go directly with a cable from your drive to the MoBo, it's clear sailing. Oh try not to spill coke on the wire.... & avoid routing it near a microwave :D
