SATA onboard ports question
ShogunCS
Hey guys, I was wondering about how the SATA ports work onboard on a mobo. I have the DFI Lanparty Ultra B and this motherboard comes with 4 SATA ports with onboard RAID support. The problem I have is the first 2 ports (port 1 and 2) are blocked by my resevoir because I use watercooling. The only ports I can access/use are ports 3 and 4 for my 36gb Raptors which I want in a RAID 0 setup. Anyhow, what I'm wondering is do the ports have to be used in sequential order? (i.e. 1 then 2 then 3 etc.) Or can they be used like a USB port so to speak, meaning I can use 3 and 4 to setup the RAID? The problem I'm having is that both Raptors are plugged into ports 3 and 4 and when the computer hits the RAID setup screen the cursor will just flash and I can't press F4 or CTRL--S to accss the RAID menu. I'm thinking my onboard SATA may be malfunctioned or I need to fill ports 1 and 2 first. Which will mean I will have to buy a PCI SATA controller to setup my RAID. Any suggestions?
You can use the ports in any order. Not sure what the problem is with the controller.
Yeah I figured as much... thanks for the reply.. i believe my onboard controller is dead.. gonna have to go out and buy a PCI one.
