Hello all......I have searched here and around the net for an answer to this question with no luck.
As stated I have a KW7. as I am sure you are well aware of it has the SATA I connections on it. I have 1 SATA dive connected to the SATA 1 connection. It is a samsung 250gig drive that has a jumper to force 150 mode on the drive. This drive is also my boot drive. I also have a 100 gig drive attached to the board via the IDE cable.
No here is the kicker......I have aquired a Maxtor 500gig SATA II drive that I want to connect to the board. I belive the drive is the 6H500F0 drive. It does not have any jumper to force 150 on the drive. And when it is connected to the MB via the SATA cable nothing is detecting that the drive is present. Does anyone know of a way to get the drive to be seen so that I can add it to my computer?
Also if it helps This is the basic computer specs.
XP
3.0 AMD Sepron
512 DDR2 400
KW7 MB
Thanks for any help
XP
3.0 AMD Sepron
512 DDR2 400
KW7 MB
Thanks for any help
