SATA II or SATA 150 ?
AllLiving
This motherboard has SATA 150 compatibility, but will it run SATA II Hardrives? If so what's the benefit and disadvantages between the two. thanks
SOLTEK SL-K8TPro-939 ATX AMD Motherboard
sata ii hard drives are backwards compatible with sata. you wont miss out on anything by just using sata for now. sata ii just has extra bandwith for later when you can use multiple drives on one channel.
mostly just servers will benefit from it.
also, sata2 supports ncq and tcq (performance enhancing modes) and i believe that sata does not. seagate drives and some maxtor and hitachi drives have these modes.
very truly yours,
politenessman
Drives today don't use all the "bandwidth" provided by SATA1, so you should be fine.
one of the things you have to think about is that SATA drives are nearly identical to regular IDE drives, (the only difference being the control board) this means that the bottleneck is the hard drive physical drive systems, (you know that arm and the platters, etc...) instead of thinking about what type of SATA interface to get I would recommend going to the manufacturers sites and downloading the datasheets and comparing things like seek time platter rpm, etc.
The connectors are slightly improved on SATA II drives as well. There is a clipping mechanism.
on a top line board ,eg sata, sata2, ata133, ata100, 7200 rpm the main factor affecting performance is usually platter density. i think 1 or 2 manufacturers now are using 125g per platter drives.
very truly yours,
politenessman
out of curiosity, since i've got one of those aforementioned Seagates with NCQ, how do we know if its active or not? NCQ, that is
look in device manager. dont look under disk drive. look under nvidia nforce4 adma controller properties. find your drive's controller and channel see on bottom of list "enable command queuing? if your drive is tcq/ncq, this will be checked. try the speed test with it checked and then unchecked.
very truly yours
politenessman
