VictorianDreamer
- Jun 11, 2008
Motherboard: Gigabyte 7VM400AM-RZ
BIOS: Updated
Processor: AMD Athlon XP, 1666 MHz (16.5 x 101) 2000+
SATA II HDD: WD Caviar Green Model: WD5000AACS
I have tried everything, and so help me I do mean everything, to get the SATA HDD working.
BIOS is set to IDE for SATA and all the appropriate settings have been tried, as well as a manual install, with Cylinder at 1023, Head at 16, and Sector at 63.
The F6 and installing of Windows XP (SP 3) has been attempted.
Even putting jumpers on the pins, even though it shouldn't make any difference because of the Master/Slave default of SATA.
Two different SATA cables.
With and without IDE HDD.
RAM swapped.
CMOS battery taken out for over 1/2 hour.
WD Diagnostic LifeGuard.
Read, re-read, and read again, the Motherboard manual, (and I know that SATA 1.5 is recommended by Motherboard manufacturer), and pretty much every single site that mentions a similar problem, without a solution so far.
The correct SATA/RAID drivers don't install properly, with the 'road sign' error of '!' next to it permanently. (also have same happen as a similar post, with the SATA/RAID driver being okay when the SATA hdd wasn't connected), and the message "this device cannot start [Code 10].
I'm pretty much at the end of my tether, and realise I'm going to have to go another way around this to get the SATA hdd working. Birthday is coming up, and I will be able to afford one of the three 'possible' solutions:
1. CPU Upgrade
2. PCI SATA Adapter Card
3. Second SATA HDD and run RAID (I'm leaning away from this because it's not being installed/detected though)
I need some suggestions of which would be the most likely to pick up the SATA hdd with as many opinions as possible. I've pretty much reached the conclusion it is just not going to work on this setup, and although I'd like to update the entire system, that just isn't going to happen now.
Thanks in advance.
Victoria
BIOS: Updated
RAM swapped.
1. CPU Upgrade
Thanks in advance.
Victoria
