Hi,
I have built an external HDD setup that will allow for up to 8 hdd's using Silverstone Bay Convertors. I am currently running 2 sata drives, which are read through a sata-usb2 converter from usbgeeks.com. And am powering them through an old 300 watt psu. Now This can get very tedius and expensive for the sata-usb wires, so I went googling for a SATA HUB, or the equivalent of a usb hub for multiple devices. I found this:
http://www.cooldrives.com/sahub5muussi.html
Before I run out and get one, i want to clarify some things.
1. Will this allow me to run hdd sata cables straight to the hub, and then one sata cable from the hub, directly onto my mobo?
2. Will i be able to access info from all hdd's simultaneously [if need be, ie moving data from one to the other//OR//moving files from two hdd's onto one hdd thats sata'd to my mobo directly.]
3. Will all hdd's operate at full transfer speed? or will it be split among the amount of drives being accessed?
Thanks!
Thanks!
