SATA connector question
Burner27
Not sure if I should be worried or not but how 'tough' are the power and data SATA connections on SATA HDDs? If one pushes the power and data connectors on to a HDD is it easy to damage these by pushing too hard?
Thanks
The real way to break SATA connectors is to snap off the connector (up and down motion). I wouldn't rate SATA connector's as very durable.
Agreed. Not durable really. I do find them easy to work with though since they aren't nearly as snug as IDE and Molex connectors (for the most part).
As mentioned, DO NOT put pressure in a up or down motion as I can recall a number of people actually breaking the connector right off of the HDD. Pull straight outwards and don't wiggle up and down.
I appreciate the responses, but I was specifically asking about PUSHING not up and down movements. Can any damage be done by PUSHING the connectors too hard?
Thx
Thx
Id be careful, if I were you. I broke the connectors off of a cheapo RAID card, and have read other horror stories, here on the [H] Forums. Its not nearly as tight a fight as PATA connectors are, but they shall have to do, we have no choice.
Thx
Pushing hard straight on it will likely veer up or down. The exception I can think of is if you were to use a backplane and I've seen those break when the backplane and hard drive carrier aren't lined up perfectly.
What is the scenario you're thinking of?
My mild "OCD" to make sure that the connections are 'solid'.
That's why I like the sata cables that come with western digital retail drives. They have the little nub that keeps it from moving up and down.
I believe the SATA connectors are rated for 48 N maximum pushing force.
You should not apply more than the force specified above... OK ?
Hehe. Dang! I was applying 49.525586685 N to it! I am screwed.........
50 N - hoooo doggies, you been working out on the side :p?
Have you tried using the 90deg-angled SATA connectors? They do make it a little easier to position the connector & apply force to it once seated w/o bending it or putting side forces on.
