sanity check ***hardware issue***
Ice_Burg
Ok, here goes, I purchased ASUS P5N32-E SLI motherboard.
Upon power-on I am greeted with a warning about voltages, fan speed or temperature may be out of spec.
Hitting DEL to go into the bios shows all normal stuff except under the voltage monitor section
Where I see, numbers in Red for:
Vcore @1.96
3.3v rail = 2.4v to 2.6v
5v rail = 4.4v to 4.6 v
12v rail = 9.46v to 10.5v
so...I immediately think the PSU is bad. (corsair hx620)
Out comes the volt meter...
The voltages tested perfect both with the PSU plugged in to the board and with PSU jumpered to run while not connected to a system board.
tried the 4 pin 12v connector and then tried the 8 pin i get the problem with both connectors.
So I have a corsair hx520 laying around in another system.
I took the hx520 and tested it with new board and i get the same errors...
so now I have tested the new board with two different psu and get the same results.
I tested with and without with video cards, drives memory etc....
I tried the hx620 to power the other system and it worked just fine.
So I think it is a bad system board...I updated the bios and still have the voltage issues.
What do you guys think?
I just wanted a couple of other brains to verify my logic.
I have an RMA from ASUS and they are cross shipping me one based on my diagnosis. However they reserve the right to charge me for the board and send my original back if they say it does not have an issue.
That's so weak... hopefully they find the same problems as you.
talked to their tech support directly this time and told that guy what exactly was going on an he said it was 99% likely that it is bad voltage regulator on the motherboard. so i at least feel better about not getting charged now...now just to wait their 48 freaking BUSINESS DAY HOURS for processing to get a new board...i hate that...you buy a board and it is bad...then you have to wait 6 d business days for processing...PLUS ship time on top of that.. I let them know I thought that was abit long in the sail for brand new product support...they agreed and said we will pass it up to management...
a lot of good that will do i am sure.
but thanks for the replies guys.
I received the new board today...much faster than expected and guess what..... THE FRIGGIN THING HAD BENT CPU PINS!!!!!!! I called ASUS immediately went to ballistic. They issued a new rma for the board I received today, and now it is on the way back to them..They are sending me yet another board to test. I am to keep the original board with the voltage problem until I get a good sample. I cannot believe this low level of quality support.
disappointment....
I mean I have been using ASUS products for....the last 12 years and never had an issue like this with them.
Actually thats pretty damn good customer service, the bent pins- well stuff happens, it shouldnt have but it did and they made it right. A little searching will find plenty of horror stories of boards being gone for weeks and weeks.
I dont care for Asus one way or the other.
