- Oct 29, 2000
hey all,
I'd like to see what I can learn from your experience in all this.
With an x79 Sandy-E system, does it make sense to use Nvidia's "force-enable-gen3.exe" to enable PCIe 3.0?
At first I thought "of course", but I have been seeing a lot of erratic frame times in game, with my two 980ti's in SLI, and I'm wondering if this is the cause, especially since the high frame times seem to not be related to GPU load (I'm adaptive vsynced at 60fps and 4k in some titles with as little as 60% GPU load when it happens)
The reason I am suspecting that this might be the problem is this quote from the link above:
Do you guys think it would be better to drop down to PCIe 2.0?
I know that in the past PCIe bus speed has not been seen as a major impact on performance,but it's been a while since those tests were performed. Would PCIe 2.0 even be sufficient to support two 980Ti's in SLI at 16x-16x?
Appreciate any thoughts on this subject.
--Matt
GeForce GTX 680 and GTX 670 GPUs support PCI Express 3.0. They operate properly within the SIG PCI Express Specification and have been validated on multiple PCI Express 3.0 platforms. Some motherboard manufacturers have released an updated SBIOS to enable the Intel X79/SNB-E PCI Express 2.0 platform to run at up to 8GT/s bus speeds. We have tested GeForce GTX 680 and GTX 670 GPUs across a number of X79/SNB-E platforms at 8GT/s bus speeds, but have seen significant variation in signal timing across different motherboards and CPUs. Therefore weve decided to only support and guarantee PCI Express 2.0 bus speeds on X79/SNB-E with our standard release drivers. Native PCI Express 3.0 platforms (like Ivy Bridge) will run at 8GT/s bus speeds with our standard release drivers.
--Matt
