1) PC will be used primarily for gaming, movie-watching, and other everyday activities like web browsing.
2) I'll spend on what I feel is good bang for the buck, but let's set a hard limit of $900.
3) I live in NJ.
4) CPU, CPU heatsink/fan, Motherboard, RAM, video card, possibly a SSD (not sure, convince me), new DVD-RW drive (I think the old one is gonna go soon, plus it is using a huge ribbon cable).
5) Reusing the following:
7) I use a 22" 1680x1050 dell.
8) Immediately.
9) I don't think I'll ever go for SLI or Crossfire. SATA 6gb/s would probably be good, although that looks like it's included on the 1155 boards I've seen.
10) Win7 Home Premium (making sure to use 64bit this time
I'll be hitting a Micro Center on Sunday (I just happen to be going to a party literally 1 mile from one), so I need to order any parts that I'm not buying in the Microcenter immediately. My thoughts:
2500K @ Micro Center - $180
Asus P8P67 @ Micro Center - $160
8gb 1333 G. Skill - $90
XFX 6950 - $310
Asus DVDRW Drive - $20
Total = $760
I'll probably throw in a couple SATA cables and a couple 4pin->HD power converters. Any recommendations on a cpu heatsink/fan? Like I said above, I won't be going for any outrageous overclocks, so nothing extreme necessary.
Normally I would try and go for a more "bang for the buck" type video card, but I'm really not sure. I could go down to a 6870 and pocket the almost $100 in savings. There's also the newegg Hot Deal on a 5870 for $199 (including $30 MIR, would have to order today). Looking at some recent reviews, the 5870 performs just a tiny bit worse than a 6950 at my resolution. Thoughts?
Edit: Can probably forget about the SSD, I can't justify it at over $200 right now.
3) I live in NJ.
- Corsair CMPSU-650TX
- HAF 932
- Assorted WD Hard drives (1tb, 1tb, 500gb, 500gb, 400gb)
- Creative XtremeMusic
8) Immediately.
XFX 6950 - $310
Total = $760
