I just purchased a 24" Samsung SyncMaster T240 and I am very happy with it. However, I have 30 days to return/exchange it at Best Buy and so I am wondering if its worth it to spend a bit more $ and upgrade to the 26" T260 ?
They both run at 1920x1200 res, so I'm wondering if the pixels are "stretched" in the 26" version? If the picture quality is better in the 24" model, I will keep it. But if not, do you guys think its worth it to return the T240 for a T260?
I am primarily a gamer so I'm thinking the larger model would help in FPS games but if its the same resolution will it even make a difference?
Thanks for any advice!
