Hi new to the forum need help with a problem,
yesterday after a year of the wall brackets sitting in my garage i finally bought it upstair so i can attach the monitor to the wall instead, main reason bought a new computer which takes abit of desk space,
i put the monitor onto the floor removed the deskstand,
and then lay down the screen onto the floor so i could attach the back piece while doing this i heard a cracked turned it over and once of the bolts was under the screen, but the screen looked fine it wasnt still i switch it on that i notice the screen had gone and just werd lines were showing up and just sound coming........
i really need advice on where i can get a replacement screen for this, also i seen alot of 32" on ebay which are faulty but some have good screens sp would it be possible for me to buy another 32" screen even if its another brand and use that?????
currently am using a old belinea 14" lcd screen and its really putting me off from working,
i could do around 6-8 papers at a time and now am stuck on doing just one paper at a time..........
any help or someone selling a similar screen pls get in contact............
