It nice to see someone of my age still playing computer gamesCurrently playing the call of duty series on my 226bw.
Grandpa ?
![grandpa.jpg](http://i92.photobucket.com/albums/l31/Elin-Julia/grandpa.jpg)
![tongue.gif](http://www.hardforum.com/images/smilies/tongue.gif)
...and ...gunner's settings look awesome!
Im sticking to it for now.
http://home.comcast.net/~audi-fan/226BWSpyder2-B73C72.icm[/url]
Thanks for sharing the profile with us gunner1, but it didn't work for me. I copied the file under C:\WINDOWS\system32\spool\drivers\color\ together with other .icm profiles. I opened Display Color Settings, I pressed Apply and Set as Default. I restarted Windows. Nothing changed. The colors are the same. Did I miss anything?
Update: I read that I need Microsoft's Color Control Applet. However, it doesn't seem to work on my system. I installed .NET and did everything, but it refuses to launch. Is there any alternative way to install this profile?
Update2: I found a program called xcalib that is also supposed to be able to apply profiles. I'll try it when I get back home.
Question: Do these icm profiles work for games too? As I see it, I can't select them in nvidia game settings profiles.
So I read through like 40 pages of this thread, and was pretty excited through the first 20, and then all this S panel, A panel crap started. Is there any merit to this. Whats the bottom line here, would anyone still recommend a 226 today over other LCDs, or is there something better?
I just ordered one from newegg, grand total of $388
but I still get 30MIB
I wouldn't use the Nvidia control panel for loading your profile. It will do some pretty freaky things with it. If you have the color correction settings changed, make sure they are set back to Standard Mode. I had mixed results with the Windows color control program. Even though my monitor is setup to use the profile by default, it will not load on startup for some reason. I have to go back into the program and reload the profile manually. It may be a problem on my end, though.
Also, something that hasn't been mentioned here yet. The instructions for calibration using the Spyder suggest that you disable Adobe Gamma(assuming you're running it), as it will interfere with your profile settings.
Visually, the difference between the color profile that Samsung provides and my Spyder profile is that the screen will turn a bit darker and more color-rich when I load the Spyder profile. That should be your cue that the profile loaded successfully. And as others have said, once you get the profile working correctly, you might want to turn down the brightness on the monitor. The Spyder calibration program recommends calibrating at the monitor's factory default settings, but jeez, that was still way too bright for me. I turned my brightness down to 65.
To the extent that this forum has made a big deal of it. No. It is waaaay overblown. I've had both and think the A might have looked better.So I read through like 40 pages of this thread, and was pretty excited through the first 20, and then all this S panel, A panel crap started. Is there any merit to this.
Would the 20" 206BW monitor be better for gaming than the 22"? I was wondering how much sharper the picture will be on a smaller monitor with the same resolution.
How did you pay that much? Mine was $325 shipped from last Friday.
Newegg has been changing the price almost daily. It was $359.99 Sunday, Went to $369.99 Monday morning when I ordered mine and then dropped to $354.99 later Monday and that is where it is now. I am not real happy about the fact that I ordered on the 1 day out of 3 that the price was the highest. They are still cheaper then CC because I have to pay sales tax but I don't like losing $10 to $15 because I just happen to order on the wrong day.
It will be here tomorrow. I am curious to see if is the famous S model or the dreaded A.![]()
I had my 20" Viewsonic vx2025 sitting next to my 226bw when I first bought it to compare the differences. Yes the picture was a smidgen sharper. However if I didn't have them sitting next to each other I would have never known. The 226bw was not as sharp but personally I love the bigger screen for gaming and considered it a nice upgrade from the 20" widescreen. Do yourself a favor and at least try the 226bw for yourself. The 226bw is awesome for gaming. BF2142 looked fantastic on it last night as I sniped the enemy![]()
Cheers. I think i'll be pretty content with a 20" widescreen, though. I mean, i've gotten used to gaming on my laptop which has a 15.4" screen, so the jump to 20" is still a pretty big one! And if it's going to look better in games, with a smaller price tag that the 22" Samsung, i'll probably be better off with the 206BW. Unless you, or anyone, could pursuade me otherwise, of course; that is if you can actually be bothered.![]()
It depends on the software package. The more expensive the more feature rich the program gets. However, I there should be an option to tell the program what kind of settings are on your monitor.When I did a calibration with Spyder2 Express it does not do anything to the Brightness or Contrast. Is that the way it is supposed to be?
The price at www.newegg.com right now is is $354.99 - $30 rebate = $324.99 final price. Plus, they are shipping the "S" panel, wich is more lovable than the "A" panel (I can tell you that because I returned two "A"'s). Now, if this is not the best deal ever on an LCD monitor.......![]()
How do you know they are shipping S panels?
I might order one next week, can people confirm which panel they got from newegg?
Thanks, its an S from NewEgg.
Third confirmation of an S from newegg
Hi
I just got mine last night from newegg,its an S panel.
PS. As I finished writing this post, the FEDEX guy rings the bell and delivered from newegg my new 226BW. IT IS "S" type!.![]()
I bought the first one from CC and got an A. I heard NewEgg was shipping S panels. I ordered one from NewEgg, it came today. It is a ........ S panel.
Thanks for the great info guys. Well I ordered at the beginning of the week from NewEgg.com and received a S panel.So.. it looks like NewEgg's shipment contained mostly (if not all) S panels, based on the all the replys on this thread about NewEgg purchases.
Mine is ("S" from newegg). I got it last Friday.
For anyone interested, I ordered my 226bw from the Egg on March 9, arrived on the 15th.
It is indeed an "S" panel.
gpilot
I've got an S model. It absolutely kicks ass....In any case, you're going to get S panels from Newegg.![]()
I just got this monitor from NewEgg today. It is the S version,......
Is spyder supposed to load the profile when done ? Or do I need other software.The instructions suck.I have run it 3 times now and says profile loaded but no changes are made.Help.
is there any way to tell if the panel is and Samgung or a AUO by the information on the box?
We should be striving to find perfect image not with Spyder color profiles on Windows, but with the settings on the monitor itself. Profiles should be loaded every time your system starts up to work. It's not clear if they work in DirectX or OpenGL games. Every time you install Windows again, you have to install the profile again etc. etc. It's artificial. It's not an elegant solution.
There must be a perfect value for Brightness, Contrast, Red, Green and Blue for this monitor. If we can adjust the monitor settings perfectly, then it'll give perfect image without loading anything on Windows.
I'm still in the process of finding the perfect settings for my panel. I've tried for hours with test programs and pictures and found very good values, but there's still some work to be done.
If anyone has found good values for Brightness, Contrast, Red, Green and Blue, I'd love to hear it.
