Samsung 2253BW Xbox 360 Help....
fuctfuct
I bought one (2253LW) for use with Xbox 360 only because it seemed to have 1:1 pixel mapping.. problem is it thinks every resolution from the 360 is fullscreen (weather i select widescreen or not) so it shows everything with black bars on the right and left. Only way to make it go wide is to turn 1:1 off but then it stretches 16:9 to 16:10 like any other 22" widescreen monitor would :(
I'm using the Xbox VGA cable... Any ideas??
are you using the option in the 360 to 'stretch' the image by any chance?
i forgot the name of it exactly.. but it is an option under display.. x360 tries to confirm to your monitor by doing some upscaling/descaling routine.
Not really sure which option your talking about. Theres 3 options in display settings.. Resolution then Widescreen/Fullscreen and then reference levels.
When i use the fullscreen/widescreen option the monitor changes nothing just shows black bars on the sides.
There are three options for standard, intermediate, and extended, but that it actually more for black and white reference levels. Ie. if your blacks seem more grey that means that your display can resolve down further than the standard setting, etc...
In regards to this, I hate to tell you but other than the 4:3 and wide settings on this monitor, you don't have much control over pixel mapping. I took a look at the manual.
I'm assuming you are trying 1360x768 resolution? The closest to 16:10 is 1280x768. This will fill your screen but it will only be about 6% different from 16:10 ratio.
Regards,
10e
I tried all resolutions in wide and standard and they all are shown fullscreen (black bars on the sides) except 1280X720 with the monitor set to "normal" .. And even that one is stretched to full wide.
I am aware that 1280x768 is close to 16:10 but with this monitor it just looks the same as every other setting when the monitor is set to wide.
I guess this moni was only intended to let people play 4:3 PC games properly.
Gonna go return it in about an hour :D :'(
