Salvage this
Fogy
My neighbors ordered a rig from Newegg in the Black Friday scramble. THEN they ask me what I think.
Well, here I come to [H] to find out what I think, :p, and now I think they goofed. Since I don't hobby, only spot research when upgrading, I've not heard of Sandy Bridge til now but and I would have waited. Makes me look at my own rig with visions of upgrades to come.
I'll show what parts can be returned and what can't, and can you tell me how dead end this rig is and what parts should be swapped out that can be? He got some MIR's that I don't know the details of, and I'd imagine the prices have since changed, so let's focus on compatability and upgrade paths more than price.
Database theorycrafting, WoW multiboxing x 5 accounts (we do our own 10 mans together :p) , standard home pc otherwise
Purchase total $1750, incl tax/ship
3) Where do you live?
Cali
Parts to keep:
Case: Antec 300 case
CPU: i7 950
SSD: 120GB PCIe SSD card
Video: EVGA GTX 470
KVM switch
Reusing: Various HDD's for bulk storage/backups. Possibly reusing vid card as a slave gpu.
Parts eligible for return:
PSU: Antec EarthWatts EA750 750W
MB: GA-X58A-UD3R
Memory: GSKILL DDR3 2000 3x4GB (?! The MB likes 1033 and 2200. Should he try OC'ing to keep this or...?
Cooling: Cooler Master
Standard DVD burner
6) Will you be overclocking?
That depends: The current memory choice seems to me out-of-bounds for the MB, so he'd have to OC to utilize the mem, correct? Otherwise, if the memory is replaced, then no need to OC.
Two HannsG 28" monitors at 1900x1200. I do this as well, 1 WoW on main monitor, on core 1, 4 WoW's on 2nd monitor on the remaining core(s). (I only have a core 2)
Shipping as we speak; may need to tweak what can be tweaked.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
We're discussing the pros/cons of using his old vid card as a slave gpu, not SLI/Crossfired. Since the SSD card is only x4, I'm predicting it will bring his slave video card down to x4 as well, but it's better than throwing it away. WoW doesn't SLI well anyway.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Win7 64, gtg.
Return the PSU and RAM. Yes your friend would have to OC to 5Ghz in order to take full advantage of that DDR3 2000 RAM.
Get three sets of this RAM:
$65 - G.Skill Ripjaw Series F3-12800CL9S-4GBRL 4GB DDR3 1600 RAM
Go for this PSU:
$110 - Antec Truepower New TP-750 750W PSU
Though the biggest candidate for return is that PCI-E SSD. Not a good buy at all.
Thanks.
I believe he's experimenting with the PCIE SSD for a boot / WoW loader. Is it the price or tech you object to?
@Danny Bui, excellent suggestions.
@Foggy - Return the Cpu Cooler. Get an ND-14 if your dead set on ordering from newegg, or get a silver arrow if your fine from ordering elsewhere.
950s, have a lot of range when over clocking, in the sense, that some of them need crazy voltage to hit 4.0 ghz or more. So they become heat monsters, and if he's going to be running multiple instances of WOW then you will probably need every thing you got.
I also agree that 300 dollars for a 128 gb is not the best use of funds, however, it's about as fast as it gets. The main advantage of SSDs over conventional mechanical hard disks, was access time.
Instead of getting 10 ms access time, you're getting .1 It's a hundred times faster.... that's where most of the speed benefit comes. But, it's still an awesome drive.. i'm sure.
I think I'd go with the COOLER MASTER Hyper 212 Plus heatsink/fan setup. It is what I am debating picking up for my i7-870.
