Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Does anyone know what a safe voltage for an X1900XT is. I'm trying to maximize my overclock but don't want to run into electromigration. Stock is 1.175 2d and 1.425 3d on the GPU and 2.086 on the memory.
Really is the 3d that high?
I use overclocker and set the video voltage to 1.225 and leave the mem volts alone. I can run ROCK stable, not a signle crash/artifact at 700/1600.
Thats the reading I get while running a game and polling the voltage in ATITool.
I'm having some trouble running over 689 core and 760~ mem. Thats what Overdrive tops out at. ATI tool won't let me go much further either. It's a bummer too because I have the BJ11 chips.
try a utility called overclocker....you can find the link on firingsquad when they reviewed the x1900xtx. Basically just change the vcore voltage to 1.225, increase fan speed, dont touch the memory voltage. I can get 700/1600 easily. The ATI overdrive sucks....it increases latencies on the ram and also cannot go anywhere near those clocks.
I also put some copper ram heatspreaders on the voltage regulators on the card itself. I dont know if those help but they get HOTTTT. I mean almost burn your finger hot.
You have to kill both ATI applications and make sure they do not run at start up. You also have to disable an ATI service so that you can overclock without using CCC. Firingsquad article tells you how to do this....
go to 'run', type in msconfig, startup, disable the 2 ATI services.
Then go to services in the control panel, under administration, and disable the ATI service.
