im currrently pumpin 1.95 volts into this sucka.
motherboard is dfi nf3 ultra-d.
im usin the stock cooling they provided with the motherboard!
is it safe to run this voltage 24/7?
Do you need to be pumping out that kind of voltage for something? Is your OC less stable or something? That's kind of a lot, and if you can get by with less, why not try?
If your temps are okay, then I guess the chip will be okay. But that seems rather excessive...I can't imagine why it would need that much voltage. That's a LOT of voltage. Nforce3 can get well over 300htt with FAR less voltage than that.
ok im back down to 1.85 voltage, is that too much?
cpu is at 1.5 volts, but it undervolts to around 1.47
i guess im feelin suicidal today
im running 300x9 on a venice 3500, my new toy
I think you're missing the point...you should only run it as high as you need to in order to be stable. Is 1.85V too much? No, as long as the cooling is fine. But I highly doubt you really need that much voltage just to run 300htt.
Wow, an SLI board from a small company for $129 that overclocks and benchmarks better than the DFI SLI-DR. I guess that 3-slot design really does make a difference, imagine what a DFI board could do if they used that design.
